Dino GT4 resurrection 10656 | Page 3 | FerrariChat
Discussion in '308/328' started by steved033, Sep 15, 2024.
  1. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    Dinoparts has a replacement that's a snap on. Further investigation into my linkages shows they're still a little sloppy (after 71k miles), even with the set screws fully in. The balls are in good shape and measure out to an acceptable tolerance.
    For reference: The ball is 8mm diameter, M5 thread.
    AMZ. be sells them. https://www.amazon.com.be/-/en/SOLIDfy-Ball-71805-Safety-Galvanised/dp/B07K8WKBGJ?th=1&language=en_GB
    Dinoparts part: https://www.dinoparts.com/en/parts-accessories/ferrari/208-308-gt4/carburetors-fuel-supply/carbs-linkage-more/14721/throttle-linkage-208-308
    Is it original? no.
    Do i care? no.
    will I keep the originals for someone who does? yes.
    sjd
    dyerhaus likes this.
  2. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
  3. dyerhaus
    dyerhaus Formula Junior
    Nov 4, 2012
    914
    Santa Rosa, California
    Christopher Dyer
    Haha, yeah, I've seen a number like that. Sometimes you can even see a faint outline of the horizontal Dino badge recess underneath the Ferrari badge. Since most of the rebadging (if not all?) was done by dealers, I'm sure they cut as many corners as possible in the name of cost-savings. Quality of work will vary!
    steved033 likes this.
  4. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    Been a while. I'm terrible at taking pics to share that show anything exciting.
    Carbs are assembled, waterpump is rebuilt, cams are in and timed. Engine should go back in this weekend.
  5. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    While the engine was out, I did the diff seals....they needed it....hahaha...
    Then I built a 22" longer bar for the engine crane, counterweighted it with a bag of concrete and the old spare, and plopped the engine in.
    Had a couple helpers... I have to rebuild the CV's, so the axles were already out. Went in super easy. Drop it down slow and there are no issues.
    superhen, LE06, Ferraripilot and 2 others like this.
  6. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    Today was finish tightening the front header, finish mounting the engine, set the shift linkage, 2nd was all the way up in the gate, and neutral was in the bottom of the 2nd gear gate... now it's all tidy in the middle. Rebuilt the CVs, cleaned, new boots and grease.
    working from the bottom up. Cooling pipes are next.
  7. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    Hunting around for a new grounding strap, becasue my original is 50 years old and very frayed, I found this one and took a chance.
    AC Delco EGS8. the holes are about 9-10mm (3/8"). It should work great.
    absostone and bitsobrits like this.
  8. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
  9. absostone
    absostone F1 World Champ
    10,237
    What is the thickness of the isolator gaskets under the carbs?
  10. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    Probably 4-5mm.
  11. absostone
    10,237
    Hmm I thought they would be thicker.
  12. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    I went and measured. 4.1mm-ish, compressed.
  13. absostone
    10,237
    do they actually compress? I thought they were stiff? or mine are as old as me? IDK
  14. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    Compressed to say that everything is tightened down. sure...probably a couple tenths of a mm....they're not soft, for sure.
    It wouldn't be a big deal to make thicker ones from phenolic or something. There is plenty of thread for probably double the thickness.
    not sure about those 1" spacers though..
  15. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
  16. absostone
    10,237
    This is what I thought they were made of or the phenolic. Thanks
  17. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
  18. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    Tune up complete, completed 4 laps of the neighborhood test track/loop.
    I'm going to replace the fiber washers from the carb rebuild kit that hold the fuel lines in place with copper. I don't like how they're saturated and weepy.
    sjd
    absostone likes this.
  19. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    794
    Omaha, NE area, US
    Steve
  20. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    I was told it was cool to wear gloves when driving your ferrari..... LOL
    In reality...I didn't have a tune up on it yet, and was turning it around in the driveway when I thought "ya know, this thing is running pretty good, let's go around the neighborhood." (it's a 1 mile loop/test track) so I did...and I filmed some of it...
    ChevyDave, absostone and bitsobrits like this.
  21. steved033
    Apr 12, 2017
    10,460
    Atlanta, GA
    Steve D.
    #71 steved033, Oct 1, 2025
