Dino GTS suspension setting | FerrariChat
Discussion in '206/246' started by mechaniker, May 21, 2016.
  1. mechaniker
    mechaniker Formula Junior
    May 30, 2004
    608
    Germany
    Hello,
    is the suspension setting for the GTS different than for the GT (as for the 308)?
    WSM (A.Wallace) and Ownersmanual suggests the following:
    Front
    2-3 mm toe-in
    +0°15' to +0°30' Camber
    4° Caster
    Rear
    2-3 mm toe-in
    -1°15' to -1°30' Camber
    But this if for earlier Chassis.
    Is there any difference for E-Series cars and GTS?
    At the moment i have:
    Front
    3 mm toe-in
    -0°06' Camber
    4.8° Caster
    Rear
    4 mm toe-in
    -1°30' Camber
    The Dino drives very reactive to wheigt transfer, so accelerating goes straight and deaccelerating turns in hard.
    Should i set to the WSM and Owners manual?
    Thanks in advance!
