Dino Heater | FerrariChat
Dino Heater
Discussion in '206/246' started by Tabletcounter, May 27, 2005.
  1. Tabletcounter
    Tabletcounter Karting
    Apr 30, 2005
    161
    Cheshire UK
    The heater on my Dino is stuck on hot!
    I've checked and the cable controlling the valve has either snaped at the end where it attaches to the valve or become detached.
    I can't turn the valve by hand (Although I've not removed the heater yet and access to the valve is not good).
    I can only see two nuts holding the heater on, is this all or are there any hidden away?
  2. dm_n_stuff
    Dec 10, 2003
    43,711
    26.806311,-81.755805
    Dave M.
    #2 dm_n_stuff, May 27, 2005
    i had the same problem.
    You can get at it and then douse it with wd40, or some other penetrating lubricant where the arm slides through the slot.
    Then you can close it with a pair of pliers, that will solve the problem for now.
    replacement parts are available from superformance for not a ton of money.
    DM.
  3. Tabletcounter
    Apr 30, 2005
    161
    Cheshire UK
    Thanks... I'll have a go later and keep you posted on any progress.
  4. Tabletcounter
    Apr 30, 2005
    161
    Cheshire UK
    Managed to get the arm moving again with WD40. Reconnected the cable, but still only blowing hot. Guess I need to replace the unit.
  5. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    John,
    My heater valve operated freely but the heat would not stop. The makings of the heater valve is a rubber diaphram which seat (or unseats) against a "lip" which is an intergral part of the casting of the valve body. This lip had erroded so even when the valve was closed, i.e., the rubber diaphram was seated gainst the lip, hot water escape passed.
    Remove the valve and take it apart. If this is the problem I can tell you how I repaired mine.
    john
  6. Tabletcounter
    Apr 30, 2005
    161
    Cheshire UK
    I have ordered a replacement valve from Superformance today.
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    These are also used on Fiats and I've seen them as low as $29 by this Ebay seller, although this one is higher.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2453035968&category=33580
    Hot passenger compartments on Dinos are surprisingly common. There are a number of foam bits that seal the radiator airflow area and if the foam deteriorates over time (or restorations/painting don't replace them afterwards) then this can allow hot air to flow into the passenger compartment.
