Dino indicator lights | FerrariChat
Discussion in '206/246' started by yakxx21, May 12, 2015.
  1. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Im wondering if this is normal....I have purchased new rubber seals for the front indicators and find when fitted they are flush with the top and sides ...but not possible to get the lower part flush...they stick out a little and its annoying.....maybe this is normal, certainly the weather seal is good but it feels wrong..
    anybody else replaced their front indicator light seals (white colour) ....and had the same problem
    any trick ??
  2. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    Same problem on mine. I have tried the white seals from Superformance and from Cicognani and they are both the same. I thought that maybe it is my lenses and even tried a new set from Superformance but it made no difference.
  3. racerboy9
    racerboy9 F1 Rookie
    2,651
    I had the same problem and didn't use them, they are too thick. Luckily I had some originals that worked great.
  4. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,334
    Iain
    #4 isuk, May 13, 2015
    I've used the Superformance seals on all of my cars and they fit perfectly flush on every one. My bodyshop installed them and I remember asking about this after the issue was raised a while back and they said they are absolutely spot on to work with and nothing needs to be adjusted. If installed incorrectly they can appear to be the wrong thickness. I don't have any photo's of them on the housings before being the lights were fitted to the car unfortunately but I'm sure there will be some in some of omgjon's threads.
