Dino Key FOB - OMEA Style | FerrariChat
Discussion in '206/246' started by ajmarton, Aug 15, 2006.
  1. ajmarton
    ajmarton Formula Junior
    May 3, 2004
    305
    Los Angeles
  2. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    Hi.
    What's the difference between this & the 'beige' one you sell from time-to-time? It's the first that I've seen with a yellow field. I understand each represents a different manufacturer. I've a '72 246 GT (Euro); do you know which would likely be more correct/correct for my car?
    Thanks.
    'nice Dino Spyder.
  3. ajmarton
    May 3, 2004
    305
    Los Angeles
    Yes, basically it is a fob made by a different maker - OMEA vs. ICOR. I am not sure about the dates. If you do a search under this discussion group for OMEA you should find the information. I know WSPEER probably has the answer as he has an original. I believe NOS ones go for several thousand $$.
  4. celestialcoop
    715
    Coop
    Thanks for the info. I'll follow up & then check out your future auctions for one of your fine replicas.
    Cheers...
  5. tx246
    tx246 F1 Veteran
    6,659
    Texas
    Shawn
    the omea fob is correct for the later dino's. a 72 dino most likely an icor fob.
  6. celestialcoop
    715
    Coop
    That's good to know. 'appreciate the input.
