Dino "L" series | Page 2 | FerrariChat
Dino "L" series
Discussion in '206/246' started by 4CamGT, Jun 24, 2004.
  1. russh
    russh Karting
    146
    Northern California
    Russell Hazarian
    Freeman,
    My serial number is 01630. I located my gearbox type and number stamped on the gearbox case near the rear left side (drivers side) motor mount, and is only visible looking up from below the engine.
    The engine block stamping question is even more interesting, especially since the owners manual that is for my series shows a picture with "135CS" stamped on the block.
    Russell
  2. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,853
    Southern California
    Russell,
    My Chassis *00474* has the engine number stamped beginning with 135c. My data plate has 135cs stamped into it. In the 246 "L" owner's manual dated 1970 it shows 135cs stamped onto the motor. A 206 has 135b stamped on its motor. It would be interesting to have other Dino owner's share their chassis number and state whether their motor has stamped 135c or 135cs. Maybe we will see a pattern.
    Freeman
  3. Maeter
    Maeter Karting
    Nov 13, 2001
    136
    I have sent you an e-mail but I own chassis # 00512, 1969 built year. More than happy to trade information and help with knowledge.
    Pascal
  4. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,853
    Southern California
    Pascal,
    Thank you. I look forward to learning more about your car, its history and your research. I also look forward to other early Dino enthusiasts to share their knowledge and research.
    Freeman
  5. 1974308gt4
    1974308gt4 Rookie
    May 1, 2016
    43
    Thomas
    #30 1974308gt4, May 2, 2016
    Hello everyone,
    Can anyone give me his thoughts about 246GT#00420? What I would really be interested is what the engine or gearboxnubmer should approximately be? I am provided be quite some information from the first and only (!) owner but I would like to have it proven and compared. Until now I was into Jaguar E-type and a 1971 911 E (that I recently sold) and now I would love to switch to the Dino 00420. Yes it should be Dino 246 #8 as I found out ...
    so hello from a newbie from Austria,
    Thomas
    P.S.: how much "bar" should the engine have on a compression test?
  6. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,853
    Southern California
    Thomas,
    Congratulations on your Dino *00420* and your first post! Matthias Bartz might have the info you're seeking. We'll see if he chimes in.
    Freeman
  7. kjw9028
    kjw9028 Karting
    153
    Sylvania,Oh-Naples,F
    Ken Wise
    This is a really neat post. Learned a few things and lots of good information. I've owned 00464 for a few years-complete nut and bolt restoration, much more fun and better to drive than my 72 GTS. One of the last 206's built, around serial number 00380 or so, owned by a body shop owner from Dayton, Oh and Naples, Fl, sold at Pebble last year for around $750,000. $825,000 with buyers premium added and set high water mark. I don't know of any that have sold for more. That was a nice car, actually won best 6 cylinder at Cavallino 2 years ago. Lots of eyes on 206's and "L" series now, even with market softening a bit. Any idea how many 206's and "L" series are still around? Seems like there are different numbers floating around on total production, anyone know for sure. Thanks.
    Ken
  8. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,504
    Germany
    Matthias
    send me engine, gearbox and body no. (ideally pictures) and I´m happy to help...
    the Dino Compendium could be interesting for you too...
    www.dino-book.com
  9. 1974308gt4
    1974308gt4 Rookie
    May 1, 2016
    43
    Thomas
    Hey everyone,
    It finally happened this week. #00420 moved into our garage! There is a lot to learn and some work, but I think it´s not too bad, at least it drives! The car was really unattended and unloved the last many years. But it drives and shifts and all major things work. All oils are changed. The interior needs a lot of cleaning, but looks much better already...
    Thank you for your advices! Matthias Bartz was helpful and patient and finally lead to the decision to buy the car.
    Thomas
  10. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    197
    Los Angeles
    Jim Oddie
    #35 Pantdino4, Jun 11, 2016
    1 bar = 1 atmosphere = 14.7 psi
    The most important thing about a compression test is that the cylinders are all within 10% of each other. The test is done with the throttle held fully open and preferably with a hot engine. Disconnect the wire from the coil to the distributor and take out all the spark plugs to decrease load on the starter motor.
    Screw in the compression gauge and spin the motor. After a few rotations the gauge will stop increasing and you can stop spinning the engine.
    You will probably see numbers between 175 and 195 psi, or 11 to 13 bar
  11. 1974308gt4
    1974308gt4 Rookie
    May 1, 2016
    43
    Thomas
    #36 1974308gt4, Aug 12, 2016
    just needed to share: After changing the brake pistons, change the foam in the seats, change all oils and liquids, having the radiator net changed and the greasing of the greasepoints we made the first ride of 76 km´s without only one problem (alternator is not working properly). Finally the car passed the "TÜV" - test and will get his licensing as soon as the austrian government completes the paperwork - yes, the licensing test was passed without problems as well. Of course there is a lot to do bring it back to it´s total glory but ....
    What a great pleasure this fabulous car is!
  12. GermanDino
    Aug 14, 2007
    3,504
    Germany
    Matthias
    good news... keep enjoying your new Dino....
  13. pshoejberg
    pshoejberg Formula 3
    1,866
    Denmark
    Peter H
    Beautiful looking car. Congratulation with the progress. Looking forward to see more detailed pictures…..-:)
  14. swift53
    swift53 F1 Veteran
    8,553
    E.S.
    Alberto
    Thomas, how great! Enjoy it, and drive (a lot).
    Regards, Alberto
  15. 1974308gt4
    1974308gt4 Rookie
    May 1, 2016
    43
    Thomas
    thank you Alberto, we certainly will enjoy and drive it but probably not to much.
  16. tx246
    tx246 F1 Veteran
    6,701
    Texas
    Shawn
    WOW!! Talk about reviving an old thread and adding something new!
