Dino PCV Valve | FerrariChat
Dino PCV Valve
Discussion in '206/246' started by racerboy9, Apr 11, 2013.
  1. racerboy9
    racerboy9 F1 Rookie
    2,651
    I am missing the phenolic disc in my PCV valve located in the air cleaner. I was going to get some phenolic sheet and make one but was wondering if a light aluminum washer would work as well. From my understanding the original disc was about 1mm thick and has about a 1/4" hole in the middle and disintegrates over time. The disc has to be light enough to lift up easily so maybe a thin aluminum washer would do the trick and last longer. Another thought was using a standard Fiat wire flame trap in the hose to accomplish the same thing and skip the disc altogether. Anyone dealt with this issue?
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
  3. racerboy9
    racerboy9 F1 Rookie
    2,651
    Well, That solves that problem! Thanks!
  4. racerboy9
    racerboy9 F1 Rookie
    2,651
    I got one on Ebay but their site says no longer available when I use their part number. Where did you see hundreds available?
  5. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    I went there last year almost to the day and they had a bag with tons of them inside. This is hardly a high volume seller so I would be amazed to hear that they sold out. The issue is that they are in no way labelled and I am not sure they even know what the discs are used for. I'm sure if you call Russ and reference the eBay listing I showed that they will be able to dig them up. I hope this helps.
  6. racerboy9
    racerboy9 F1 Rookie
    2,651
    I'll check it out. Thanks!
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    Go to your plumbing merchant and buy a small tap washer. It does the same thing and you should get at least 20 for a dollar!!
    Tony
  8. racerboy9
    racerboy9 F1 Rookie
    2,651
    Just got a PVC valve disc from Ferrparts. Arrived in four pieces but not a problem. I just wanted it for size reference. No wonder many are missing this piece. They are fragile! I think an aluminum washer would be a better candidate and last forever as opposed to the original phenolic or whatever it is material.
  9. afer
    afer Karting
    Jun 4, 2009
    122
    Uruguay, S. America
    Alvaro Ferraro
    The "dischetto" in the link is part Ner. 21061. In the catalog for the L series the correct part Ner. is 21080. Are the same ?.
    Can you post the measures of the disc you received ?.
    Alvaro
  10. racerboy9
    racerboy9 F1 Rookie
    2,651
    Look up item 110603393420 on Ebay for a picture of the disc.
