Dino radiator foam | Page 2 | FerrariChat
Dino radiator foam
Discussion in '206/246' started by er72, Aug 26, 2016.
  1. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    Any idea which of the McMaster foams will work for this? There seem like some good options in that link.
  2. npwmd2
    npwmd2 Formula Junior
    Mar 31, 2015
    262
    Hudson Valley
    Neal
    Cls
    Go to DinoParts, they have a correct one.
  3. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    #28 4CamGT, Sep 8, 2016
    swift53 likes this.
  4. LM512S
    LM512S Rookie
    May 25, 2007
    17
    SE
    Rob
    Hi,
    What are the dimensions of the foam block?
    Thank you.
    Cheers
    Rob
  5. swift53
    swift53 F1 Veteran
    8,618
    E.S.
    Alberto
    About 2 x 2 inches
  6. LM512S
    LM512S Rookie
    May 25, 2007
    17
    SE
    Rob
    Grazie Alberto,
    I went to the local home depot yesterday and they had just 30x30mm. Open cell though, but too small.
    Rob
  7. BigTex
    79,420
    Houston, Texas
    Bubba
    I remade mine from Armaflex insulation (HVAC product as it is a skinned CLOSED cell foam, which will not attratcted and hold water..
    It comes in a wide range of thickness.
    UroTrash likes this.
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,353
    Norfolk - UK
    Tony
    Armaflex insulation would do the job but it is too dense imho. I tried it and couldnt get it to work properly.
    Time you have bought a minimum length x standard width & cut it then its possibly cheaper to buy the ones made by Superformance (£50) or dinoparts (52 euros)
  9. LM512S
    LM512S Rookie
    May 25, 2007
    17
    SE
    Rob
    I might be wrong but I think an open cell block is more appropriate. A closed cell one might eventually cause some turbulence obstructing some of the airflow.
  10. swift53
    swift53 F1 Veteran
    8,618
    E.S.
    Alberto
    There was not supposed to be airflow, if anything it directed more to the radiator, and not allow
    it to go beyond it.
    I will check my exact dimensions, not there right now, but they are just the right size, cheap open cell foam.
    I had an original, or at least I assume it was, in my car, so I just went to HD and got 2 perfect replicas.
    The gray color was right too.
    Regards, Alberto
  11. tx246
    tx246 F1 Veteran
    6,705
    Texas
    Shawn
    I will say for years, there was NO option for an “original type” item. And as for that, no one could identify what “Was Original”.
    The only real way to know is what “was original” or not.
    Can any ORIGINAL, minimal change owner post pics? These people are almost impossible to find today.
    From my experience, what I have seen is just all kinds of broken down, what we would call today, “open cell” foam types. I haven't seen a “closed foam” version of an old broken down piece.
  12. UroTrash
    Jan 20, 2004
    40,742
    Purgatory
    Clifford Gunboat
    Use a purple pool noodle and watch the purists have a stroke.
    lagunacc, TonyL and Eltel246 like this.
  13. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,353
    Norfolk - UK
    Tony
    The grey / charcoal coloured foam that's fitted to my car measures 60mm x 60mm x 700mm long
  14. LM512S
    LM512S Rookie
    May 25, 2007
    17
    SE
    Rob
    #39 LM512S, Aug 6, 2023
    From my experience we designed air guides and ducts allowing some air to "go lost" to prevent
    turbulence issues, and I think imho that is the reason why the original part is an open and not a closed one, letting as much air as possible go through the radiator.
    Rob
  15. LM512S
    LM512S Rookie
    May 25, 2007
    17
    SE
    Rob
    Thanks Tony
    Rob
  16. swift53
    swift53 F1 Veteran
    8,618
    E.S.
    Alberto
  17. swift53
    swift53 F1 Veteran
    8,618
    E.S.
    Alberto
    Bought at Home Depot, maybe. :)
    Missing almost 2mm, so 58mm. Think will do.
    Regards, Alberto
    LM512S and TonyL like this.
  18. tx246
    tx246 F1 Veteran
    6,705
    Texas
    Shawn
    That pretty much EXACTLY what the option from McCann was back in the day.
    swift53 likes this.
  19. LM512S
    LM512S Rookie
    May 25, 2007
    17
    SE
    Rob
    Seems like a good one :)
    Rob
    swift53 likes this.
  20. 4redude
    4redude Formula Junior
    Jan 13, 2005
    733
    Fungus Corner
    Brian Keegan
  21. LM512S
    LM512S Rookie
    May 25, 2007
    17
    SE
    Rob
    I wonder which is the most appropriate glue to use, considering the rather high temperature for most common glues used for foam parts.
    Rob
  22. pshoejberg
    pshoejberg Formula 3
    1,884
    Denmark
    Peter H
    #47 pshoejberg, Sep 1, 2023
  23. LM512S
    LM512S Rookie
    May 25, 2007
    17
    SE
    Rob
    Thanks for info and pics.Peter.
    Bought the one from Dino Parts. Sounds like a good idea.
    Br Rob
  24. LM512S
    LM512S Rookie
    May 25, 2007
    17
    SE
    Rob
    By the way, did you spray the hood as well or just the foam?
    Thanks.
    Br Rob
  25. pshoejberg
    1,884
    Denmark
    Peter H
    Both surfaces. That means you need to cover off the surrounding areas on the hood and make a test fit before you spray out the glue and mount the foam...You will only have one attempt to get it right:D
    Best, Peter
