Dino Restoration | Page 12 | FerrariChat
Dino Restoration
Discussion in '206/246' started by omgjon, Feb 18, 2006.
  1. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    #276 omgjon, Jun 7, 2006
    Here is a photo of the brace, there is also one one the right. You can see the corner of the fiberglass I had to cut out.
  2. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Thank you very much, I'll check mine out and report back.
  3. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    #278 omgjon, Jun 12, 2006
  4. need4speed
    need4speed Formula 3
    Nov 3, 2003
    1,616
    Pacific Palisades
    Jon,
    I believe the originals are magnesium. Hence lighter than aluminum.
    Manny
  5. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Ditto
  6. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    Jon,
    That's awesome that you posted the weights. When I see pics of Dinos with larger wheels, I've often wondered what the weight differences would be to upsize. And the subsequent affects on handling and ride. I know these numbers don't account for tires. But it's nice to get a feel for the wheels. There are some 17" wheels out there that weigh as little as the Cromodoras!
  7. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Jon or anyone else who might know?,
    I am trying to get the front inner tub out of my car (74 gts) so iv'e cut the corners off to allow it past the bracing struts but seems to foul on drivers side on a combination of trunk opening handle bracket/steering columm bracet and throttle stop bracket. do i have to grind off the throttle stop and trunk handle brackets or am i missing something here??????????
    regards GP
  8. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    I had to trim about a half inch off fiberglass so it would clear the steering mount. There was also a bracket I cut off to the right of the steering support to be welded back later. It is a tight fit. I took a rubber mallet and gave it a few wacks. I also removed any of that nasty putty like stuff where it contacts the structural braces. Then it slipped out.
  9. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    #284 omgjon, Jun 14, 2006
    I decided a while back to do the flares as I have the original campagnolas wheels now. Just for any purist out there, you can document that this car originally did not have flares. I'm not trying to hide the fact. Am doing them the same way Ferrari put them on I believe. Which was to cut the lip off. weld a sheetmetal flare in with the edges pre rolled. Got one front tacked in place today. Measurements were taken from an original flares car. It was amazing what the difference was in a factory car between the left side and right side. One side was a half inch lower than the other and the wheel openings differed by a least that much also.
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Magnesium is porous, meaning you'll have air loss through the metal when teh tires are mounted/pressurized.
    Perhaps coating the inside with a sealant will halt that loss.
  11. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Jon,
    Great job, but yes it will upset some people out there!. Have you rolled the edges around wire as per the originals?
    Regards, G P
  12. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    Of course.... although there was only wire on the fronts.. none in the rears(on my non flare car). Maybe the rear fiberglass inner fenders take the place as they go into the seam.
  13. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    #288 omgjon, Jun 15, 2006
  14. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    I almost put flares on my car. But I never liked the flatness of the factory flares so I was contemplating more curvaceous flares. Anyways, to each his own.
  15. Kingpin328
    Kingpin328 Formula Junior
    Nov 7, 2003
    433
    Please don't do that to the black one :)
  16. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    #291 abstamaria, Jun 15, 2006
    The flares look well done and, if one already has a standard Dino, would be nice on a second one for contrast.
    Just to note - one probably doesn't need flares to cover the extra width of the Campagnolos. This is my car with original Campagnolos. Note the tires do not go beyond the standard flares.
    Warm regards to all.
  17. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Wow, I would not have the balls to cut off the fenders and weld on flares!!! I'm sure it's going to come out great, but I'm wincing right now!!
    Birdman
  18. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    Hey, that's how they did it at the factory-it's just metal! And by looking at the rest of their work I believe I can do at least their level of work and hopefully better. The only difference between these flares and originals is that these are symetrical on this car.
  19. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    I saw Maranello Concessionaires in the UK adding flares pretty much like this, stood fascinated in the doorway for about an hour....wondering what they were up to.
  20. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Jon - "...In matters of opinion, debate is meaningless..." I like the flares, and that you are modifying the front directionals, originality is not an issue. Enjoy your work. I am quite impressed with your handiwork. I could never do that.
    By the way, I am off the rotisserie, and the engine should go in today.
    Jim S.
  21. ferrari dino
    ferrari dino Karting
    Feb 16, 2006
    180
    Southern California
    John Kennedy
    Any thoughts on taking out the roll bar and making it like a 275 NART sypder?
  22. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Jon - engine in Stop No problems Stop Will fire-up tomorrow Stop More to come Stop
    Jim S.
    P.S. For those who have never received a telegram announcing a momentous event, such as the assassination in Sarajevo of the Arch Duke Ferdinand precipitating events culminating in the Great War, the first solo flight across the Atlantic, the Great Market Crash of '29, the election of Theodore Roosevelt, and the installation of a Dino engine.
  23. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    consider my grumbles heard.
    non-the-less, excellent progress on the dino and most likely at a higher quality than when delivered.
  24. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    By cutting off the standard angled edge, aren't the flares now too high at the arch peak?
  25. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    No they are not to high. I made a template of an original car and that's where they are cut. The flares do angle down a bit which makes up for some of the difference.
