Dino Restoration | Page 28 | FerrariChat
Dino Restoration
Discussion in '206/246' started by omgjon, Feb 18, 2006.
  1. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,879
    Jon - where did you get the ventilation hoses? What is the diameter in millimeters??
    Do they slide easily onto the various vents (heater, dash, etc.)?
    Jim S.
  2. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    I would say that with the quality of restoration that you are doing, to leave out the heater cores would be a real omission. The weight is maybe 30 lbs. with coolant. The fact that you live in SD shouldn't enter into it. Just my $0.02 worth...
  3. racerboy9
    racerboy9 F1 Rookie
    2,671
    I thought of leaving the heater cores out of my hot rod Dino coupe for better ventilation and less weight but decided to keep it original and the weight factor is minimal. I would have the cores pressure tested before I had them recored. They are pretty robust units and rarely leak. If they leak at a later date they are not to difficult to pull and fix. If you don't think you'll need the heat you can skip hooking up the heater hoses to them.
  4. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    You're right, the heater goes back in.
  5. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Can someone give me a primer on hoses. It seems the water hoses are rubber and other hoses such as blow by are cloth coated. When and where do you use which?
  6. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Jon,
    You need the heaters for defrost to work. A couple of times a year you get fog in San Diego and defroster helps. And who knows, a drive to the mountains might be fun. Keep it up.
  7. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
  8. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,035
    Summerfield, NC
    Tom Jones
    Be careful with that brass water pump impeller. I had one that came in a rebuild kit but because mine didn't have internal threads to pull it back off if it got pressed on too far, I was a bit afraid to use it. I just cleaned up the seal surface on my original cast steel one and reused it with no problems.
  9. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #684 omgjon, Oct 11, 2006
  10. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Still waiting.
  11. 246gts
    246gts Karting
    Jan 10, 2005
    134
    cheshire, uk
    #686 246gts, Oct 12, 2006
    Jon
    Thanks for the great posts it has been my pleasure to watch your work unfold.
    On my car all water pipes are rubber and all other pipes are cottom braided as in attached photos. There are two exceptions firstly the take off for the servo which is a rubber covered spirally wound wire pipe and on mine the top feed from the radiator header tank is cotton braided. i am not sure that this is 100% correct but it was probably done so as to match the other hoses in that area.
    Keep up the good work
    Dave
  12. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    WOW- That's one beautiful engine!
  13. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
  14. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Hey! John, one of your rear calipers has a nut missing! otherwise 10/10!!!!!!
  15. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    The first part I lost. Probably not the last.
  16. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Where do I get the rodents to run the fans?
  17. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Marenello ask for 2x Topo Gigio's
  18. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    Hook 'em up to the exhaust for a twin turbo!
  19. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
  20. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    #695 ferrarifixer, Oct 13, 2006
  21. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
  22. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,694
    #697 greg246, Oct 13, 2006
  23. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #698 omgjon, Oct 13, 2006
    The half shafts were sitting around because I couldn't figure out they came apart. The parts book doesn't show an exploded view. Quite easy once I figured it out. Also to Jim's question about the ventillation hose, I measured all the parts that the large hose connects to. All the fittings were about 89mm. The original hose looks to be about 90mm and the new hose is 92mm. It does seem a tad loose. The smaller fitting is 70mm and I've found no replacement as of yet. Back to the half shafts, I'm getting them powder coated up to the spline. The assembly that holds the bearings, black oxide and the covers cad yellow, with new boots and clamps. I was told you can only use the bolts once, does anyone no more about this?
  24. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #699 omgjon, Oct 13, 2006
  25. John Corbani
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Jon,
    Bolts have been off mine 5-6 times and have held up fine except for one. One bolt failed at junction of full dia. and threads. This was before I did much of the work myself. Don't know how long I drove like that but found at oil change. I torque them and go easy. Should last forever if not overtightened.
