Dino Restoration | Page 31 | FerrariChat
Dino Restoration
Discussion in '206/246' started by omgjon, Feb 18, 2006.
  1. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    That destruction is terrible news, hope there is a chance your items survived and you were spared the loss.
    In any restoration you undoubtedly have setbacks that you may run into, but those usually are due to the car or your process of restoring and not by others.
    Although I did have a chrome surround to the lock trim that spent 6 weeks in Sweden when Verne's Chromer (El Segundo, LA) accidently shipped it with another order.
    [hr]
    In post #721 you show the sump pan for the transaxle and engine. These are a known area that causes leaks. Perhaps you might consider crush washers and nylock nuts? I found this solves the leaking problems in mine.
    Also in #721 your dash vent is the three holed type typical of Dinos with the A/C option - are you still jettisoning the A/C taking the time to fill in the A/C in the fiberglas but leaving the dash holes?
  2. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    Good idea about sump, I think I will try that. I hate leaks. I never thought about the vents on the dash. I suppose I could get rid of one.
  3. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Sorry about the mishap, not nice! At least you're organized enough have a list of what you lost.....
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I've used copper (on my USA) and aluminum (on Euro Dino) crush washers and nylocks. If you really want to get fancy, Newco sells yellow insert nylocks which was a Ferrari favorite.
    You've already told us that you won't have the intention of showing the car in concours events, so there is probably no need to deal with the dash vent - plus most judges wouldn't know unless they're die-hards like us, so leaving it as it is should be fine for your intentions.
    Although I sure enjoyed having A/C when I was in LA with my Dino - can't see why you'd want to remove the A/C when you live in So. Cal.
    BTW, There is an improved A/C compressor that will fit in stock position and increase cooling by 40%. TCCI purchased the old York A/C compressor division and now makes a Universal model compressor (good for R-12, R-134a, R-22, etc). I paid $364 for mine.
    http://www.ccicompressor.com/universal.aspx
  5. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Had that cover off 8-9 times before shifting was perfect after last year's rebuild. Big difference in gaskets from diferent suppliers. Big difference in ability to clean up before replacing gasket. DO NOT USE ANEROBIC SEALERS. Or any other glue. Except maybe a little red high temp silicone RTV on the gasket if you know there are scratches or low spots. Silicone can be removed cleanly and easily.
    Used gaskets from GT Car Parts and from Superformance. Superformance gaskets were hard and thin. Bad seal and they self destruct during removal whether or not any glue is used. GT gaskets were soft, thicker and stronger. Just coat both sides with bearing grease and they seal fine. You can remove and re-use multiple times.
    Key to no drips is the use of Belleville washers under all nuts. They were used by the factory but most mechanics replace with flat washers or do not replace Belleville with the right orientation. These special washers are cone shaped and fully hardened. The cone is flattened to provide a spring action that takes up temp variations in thickness of gasket and aluminum parts. Peak of cone MUST be against the nut, base of cone MUST be against the aluminum. Small area against steel, large area against aluminum. No damage to either material.
    Factory Bellevilles have a smaller OD than readily available US parts but US parts work fine. Looks better if you do not mix on any given part.
    Been most of a year, no leaks, just as the factory intended!
  6. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    Where would one get belville washers?
  7. dm_n_stuff
    Dec 10, 2003
    43,988
    26.806311,-81.755805
    Dave M.
    #757 dm_n_stuff, Oct 30, 2006
    Jon.
    Belleville washers are available at McMaster-Carr. www.mcmaster.com search for belleville, they'll come up.
    However, this won't address the other source of leaks, which is weeping around the studs. I don't get leaks anywhere else.
    Solved that problem by using a washer that has a rubber donut in the middle. When you torque them to 96 inch lbs. the expand slightly and form a seal around the stud threads.
    They are also available at McMaster-Carr. And Ebay.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=012&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=220019354767&rd=1,1
    DM
  8. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    DM great info!
    The ones on ebay have rubber inserts, is that a valid application on the Dino?
  9. dm_n_stuff
    Dec 10, 2003
    43,988
    Dave M.
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    The Maserati V-8 engines seal their valve covers with this same technique. Wurth 469-6 is the part number of the 6mm washer with rubber sealing on tthe interior diameter.
    http://www.geocities.com/MotorCity/Garage/6743/Bora/partsinterchange.html
    The ones "sold on Ebay" are from Jacques, a well known Maserati (and now Ferrari) supplier.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33580&viewitem=&item=220019351628
    These are the wurth product for 6mm studs.
    Scott
  11. John Corbani
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    #761 John Corbani, Oct 30, 2006
    Dave and Jon,
    If the oil shows around the studs it is because the gasket does not seal and the studs are the closest way out. Studs go into blind holes. O-ring just delays time for oil to work its way out. O-ring does not provide the same spring action as the Belleville washers. Once again, factory had it right the first time. Picture shows studs and sealing surface. From "Dino Saga 060212". Jon, take a look at the washers you took off. They are probably original and you will see the slight conical shape. Same washers used all over. Critical for water pump too. Black oxide so can be used again as is or clean, oil and bake to no more than 300 degrees to make them look like new. Or just buy new ones.
  12. dm_n_stuff
    Dec 10, 2003
    43,988
    Dave M.
    OK John, Gonna put your theory to the test.
    I'm ordering the correct belleville washers, but first, what size do I want?
    A little assist from you on this would be most welcome.
    Then, I'll take some time this weekend and put them on, torque them properly, and see what happens.
    If that doesn't do it, I'll get my mechanic to replace the gaskets, and use these and see where we end up.
    Oh, and anyone who wants in, I'll be happy to order enough of these for everyone, just send me a PM in the next day or so.
    Now back to our regularly scheduled program on Jon's restoration.
    Dave
  13. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    #763 omgjon, Oct 30, 2006
  14. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Yikes!
  15. dgrperformance
    dgrperformance Formula Junior
    Feb 28, 2005
    311
    Oceanside, CA
    might want to check the solder joints on that tank:)
    Sorry to hear about the fire and to think I almost flipped my lid when they lost one of my carburator mixture screws in the bottem of a plating tank. Hope everyone was safe, parts can always be replaced but lives can't.
    omgjon as you know I have several Dino projects at the moment so let me know what you can't recover and I am sure Tom or I can help you out.
    Zac
  16. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    I'll get my list together tomorrow. Thanks for your offer to help. How's the miura coming.
  17. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    The correct, original "FIM - Bologna" tanks are still around, I bought a spare two years ago. Since you're not going to show the car why not use the Superformance stainless steel tank instead?
  18. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
  19. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Jon, Shocked at your bad news on my return from holiday. hope you can obtain the lost items I remember that Maranello UK had a Screen trim last time i spoke to them about £500.00 though!
    Regarding the header tank mine has a couple of tiny corrosion holes in it. is it worth repairing and sealig it with an epoxy resin or do i replace it?
    ( would you believe it i was in Bologna on Sunday!) Where are the FIM tanks available from? apart from Bologna!
    Regards G.P.
  20. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    dinoparts.de
  21. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    #771 omgjon, Nov 2, 2006
  22. need4speed
    need4speed Formula 3
    Nov 3, 2003
    1,616
    Pacific Palisades
    omgjon,
    I'm so sorry to hear about this. This thread has been an incredible journey. And I've followed along every step of the way. I feel this as much as you do. Those are the pieces left but what was not recovered?
    Manny
  23. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    This is really a bummer. Between the various Ferrari parts suppliers who have new/used bits to replace the ones you lost and the FerrariChat community who no doubt have parts you can copy should originals be unavailable, you'll be back on track in no time.
    Hang in there.
  24. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Jon, A question, How did you clean up your fibreglass inner tub and inner wheel arch pieces, Blast or thinners etc?
    Regards, G.P.
  25. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    Used plastic media to get all the big stuff off then used a 3" grinding disc to finish. By the way I'm back on track as ALL the ruined parts are available from a couple of sources. I'm still waiting for the pistons to start putting the engine and gearbox together. Everything has been repainted, reconditioned or new.
