Dino Restoration | Page 50 | FerrariChat
Dino Restoration
Discussion in '206/246' started by omgjon, Feb 18, 2006.
  1. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,881
    Jon or anyone - do you know where I might find the two banjo bolts and fittings for both sides of the fuel filter canister? They are 14 mm 1.5 thread and I cannot find them anywhere. Any help is greatly appreciated.
    Jim S.
  2. Edward 96GTS
    Edward 96GTS F1 World Champ
    11,129
  3. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    I got a set of new brake, clutch, and accelerator rubber from Dennis McCann 3 years ago. ReOriginals may also have them. Not very expensive (at least then).
  4. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,881
    Ed - thanks for the lead. I knew of NewCo, but forgot to check with them for the banjos. Looks like they may have them.
    Thanks.
    Jim S.
  5. Valence
    Valence Formula Junior
    Jan 20, 2004
    883
    Charlottesville, VA
    Chris& Brian Coffing
    Hey Jon, did you sand or grind the substrate (I guess it's primarily fiberglass?) before applying those fiberglass strips? Are the strips just meant to make it look continuous, or are they intended to do anything?
  6. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    Jun 7, 2006
    78,327
    Wurundjeri man.
    Arvin Grajau
    I don't understand ?
  7. henrus
    henrus Karting
    Jul 18, 2004
    128
    Bay Area, CA
    Henry
    he's joking.
  8. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    When I took it out there were fiberglass strips on all the seams. I don't know if you really need them, I just did what was there before.
  9. Arvin Grajau
    Jun 7, 2006
    78,327
    Wurundjeri man.
    Arvin Grajau
    great thread to follow and just read.
  10. nerodino
    nerodino Formula 3
    1,161
    Suffolk UK
    Graham
    Guess it is there to keep water ingress out, mine has exactly the same.
    G P
  11. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
    I really wish this was a Discovery or TLC show.
    I enjoy this so much, its just Incredible the attention to detail, the workmanship, etc, etc...
    PURE ENJOYMENT!!!!
    OMGJON, Maybe a the end, you can post a sound clip of when you first crank the Dino over?? So we all can part-take in the excitment.
    Whatcha ya think??
  12. J Ingram
    J Ingram Formula Junior
    Aug 12, 2006
    459
    Moreno Valley, CA
    Jesse Ingram
    I agree! I can't wait until it's done to see the complete finished product. I would love to hear it too and to see what bugs you will have to work out since it is essentially a new car. With such a perfect restoration, will you even want to drive it?
  13. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    Wow! you really have confidence. I was just wondering if the thing will actually start when I get to that point.
  14. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    I will definetly be driving it.
  15. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    #1240 omgjon, Apr 27, 2007
  16. ajmarton
    ajmarton Formula Junior
    May 3, 2004
    305
    Los Angeles
    That insulation looks great. Is heat / weather a problem?
  17. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    You get heat from the center tube with the radiator hoses running through it.
  18. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
  19. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    Actually it's just 3 day blinds. Verticle blinds. I couldn't think of anything else that would cover up the boxes yet be easy to open to get at stuff. I can't stand seeing stuff piled on shelves.
  20. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    #1245 omgjon, Apr 30, 2007
    Today I worked on a few things. I didn't have quite enough hydraulic line and my order came in today so I finished the lines. I didn't have enough because I screwed up the first couple I did till I sort of got the hang of it. If you plan on replacing lines KEEP THE OLD ONES FOR PATTERNS. I had to learn the hard way on that. I finished with the steering, it also is a little trick as there definetly is a order which you put all the parts back in. Third try I got it right. Be sure everything is centered as you put the parts back in. I finished the thermal insulation on the bottom, at least that was a nice easy job. I'm waiting and waiting for a fan blade then I'm planning on doing the fan motors, the radiator, the spare tire tub, then the wiring. I'm having a new aluminum floor pan fabricated then I can button up the bottom. It is all a bit of a challenge and when you think something is just straight forward it's not. There are lots of things I will do differently and better on the next one that I've learned so far from doing this.
  21. ajmarton
    May 3, 2004
    305
    Los Angeles
    Hey, nice key fob! :)
  22. boffin218
    boffin218 Formula Junior
    Oct 8, 2005
    888
    Philadelphia
    Chris
    Beautiful. Simply beautiful.
  23. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    did u rebuild the steering rack? if so was it hard to do? I bought a quick turn kit from Superformance (they didnt have the normal turn kit) and am starting to dismantle it. It looks like you need a special wrench to take the tie rod arms off...thanks
  24. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    Wonder where I got it?
  25. omgjon
    omgjon F1 Rookie
    3,573
    Spicewood, Texas
    Jon Gunderson
    I did not rebuild it. I did have it checked out and they found nothing wrong with it or really any wear. The car was a 24,000 mile car.
