Not much today, a couple more electrical items and rear trunk latch. Image Unavailable, Please Login Image Unavailable, Please Login
I'll sleep much better, thanks. I'd hate to see the wiring burn up after all of that work ! You're really doing a spectacular job.
A few pics from the last few days. Weather is too nice so work has to suffer. I had a visitor to check out the Dino. Claudia Zampolli came down from Orange County, he made or makes the Cizeta. I don't know much about them except the engine has 16 cyclinders. He worked at the Lamborghini factory during the Miura period as a line mechanic. I drove my Miura SV to my shop when he said he was coming down. Anyways, I put the blow-by cannister on, the radiator rubber mounts and strap, started the ducting for the ventillation and put the front and rear swaybars on and a few random shots. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Don't you know that those two bikes are conspiring to fall onto all that beautiful bodywork and make you totally crazy! I would eat scrambled eggs off the floor of your garage, but you HAVE TO MOVE THOSE BIKES!!!!!
It's just a Maserati, and I already accidently ran the forklift into the hood of my friends car. No body damage, just paint. I thought he was going to repaint it to yellow, but when he told me he probably wasn't going to paint it I had to break the bad news to him.
I'm starting to think about an exhaust for the Dino. I had a Tubi on the last dino I owned, which by the way I just saw a photo of it in a collection in Logan, Utah. As I remember it was kind of loud. I really like the classic sound of the original. Any suggestions. I saw an Ansa advertised on the Dinopart.de website, I didn't know they were still available or is it a copy. Also, I'm about ready to think about an electronic ignition. I'm down to 2 choices, MSD with blaster coil or use my old Dinoplex with new insides (Perma-tune).Please all chime in to make my decision easier. By the way I have a new Tubi I was going to use but now not so sure. As always your humble servant omgjon.
I noticed that the front markers on the SV are different than those on Richards, is yours a euro model?
BOTH EXHAUST ARE GREAT I have a Tubi on the Euro Dino and a stock Anza on the US. Both sound great with the Tubi being a little louder/more "raw", especially at higher revs. A few years ago I bought a stainless steel Anza "Dino sport" for the USA car from T Rutlands and it looks identical to the factory Anza. I anticipate this be the happy medium between durable Stainless and great sound, but haven't installed it yet. BOTH IGNITIONS ARE GREAT The Euro Dino has an MSD ignition and the USA has a permatune gutted Marelli AEC-103 (circa 1995). The MSD does have a hotter spark, but I believe my permatune was a very early version and the ones today could be much better/hotter. In an email exchange last year to Lonnie/Permatune, they offered to upgrade mine although I've not had any problems. Last year I did a safety inspection before going on a 4 day FCA club. When I looked over the plug wires I found the MSD coil was slightly leaking oil onto the coil wire. Not enough to start a fire, but still a concern. MSD are readily found in the local parts store and it was a simple, quick change to replace it.
I put in the heater hose today, the 2 gas tanks and put in the ventilation ducting on the left side. It would of been much easier if I had put in in before the wiring, inner dash and windshield wiper motor. In fact I had to remove the wiper motor to get the ducting in. Next time I'll know better. Just add one more thing to the goof up list. I wish I would of kept the old ones for patterns. The ducting doesn't bend all that easy and it was just trial and error to finally get it cut and bent to the right shape and size. The more you put back into the car the more difficult it gets as there is not much room to work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Jon, Perma-Tune is great and works with stock coil. DinoPlex is great but the components are unbelievealy ancient. If they still work, the manufacturer deserves a standing O. Change out the DinoPlex guts under any condition. MSD is fine but does nothing to make things better. Unless you are dead set on running 1960s plugs. Then it is better than than Perma-Tune when idling but who cares that much about idle. Starting and high RPM are where the fun is. Change the plugs to NGK Iridium plugs and any functioning ignition system is just fine. Heat range of 7, just like NGK recommends, is just fine unless you want to track the car. No need to use magnetic, etc. pickups to trigger ignition if you will use stock distributor. You must lube advance mechanism every 15,000-30,000 miles and you can look at the points then. They last that long. Luck, John
Gorgeous restoration photos, this car is really coming along! I run the MSD with Bosch Platinum WDRP6's and it is great, even when above 5,000 feet in altitude on our high mountain passes. I have over 6,000 miles on these plugs and they're still clean so don't see any reason to change them although I do carry a spare set in my kit. John's correct, the Iridiums have a very precise elctrode and spark but cost multiples of the platinums (see Corbani thread on Spark Plugs with the comparison photos that reveal the smaller electrodes http://www.ferrarichat.com/forum/showthread.php?t=99252&highlight=Dino+saga). I figured I could always upgrade later but they've run so well that I haven't had the need to change them yet. The stock Marelli AEC-103A has no short circuit protection, I'd be careful when charging or (heaven forbid) jump starting a car with that unit in it. BTW, NGK 7 series is good for sea level, but might be too hot for the high mountain passes. Scott
Dino Tubi's come in Competition or Street with the competition of course being the louder one, I have the competition which sounds great but can hurt abit when on a two hour drive. A buddy has the street version which also sounds great but is more subdued.
omgjon, I must say this is VERY impressive. I don't have a Dino myself, and won't for a while and frankly I don't understand a thing when it comes to the mechanics of a car and I don't think I can ever take one apart and put it back together. For some strange reason I have read this thread from start to finish and even though I don't understand what the parts you have documented are, I have kept reading in amazement at your accomplishments. I am sure you and your son had a blast. Anyways, I just wanted to say that this is amazing and for a car that was made before I was even born (I graduated high school today actually) it is amazing. Congratulations, and I would love to some day see it in person.
Congratulations on graduating. Are you planning on college? PM me and I'll send you a "DINO" tee shirt for your enthusiasm.
I finished putting in the heater the new ducting and heater hose. I also put on the crossover pipe between the 2 gas tanks. I had to unfasten the right tank to be able to attach the pipe slipping the rubber connectors on. I put the rubber trim around the front compartment. My switch for the license plate light (fits on rear batchboard) was broken, so Mark my friend who is working on his Maserati cast a new piece for m. A question about the guages--they all work fine and chrome rings are in good shape. The problem is that the INSIDE of the glass needs cleaning but I don't see any way of getting the chrome ring off without damaging it. Corbani or Selevan must have the answer. I'm taking pictures of every electrical connection and the color of the wire as I go along, thought this might be a good companion piece to Selevans wiring diagram. By the way I'm going with the Tubi street version, seeing I already have a brand new one I got sometime back. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
If the rings on the gauges are similar to the 308 gauges you can gently pry them off with a small screwdriver (jewelers or eyeglass) . They will "pop" off and "snap" back on.
Jon - I am in need of ventilation hoses. Where did you get yours? Can I order a complete set for the Dino, or must I order each individually - length, Inside Diameter, etc.? The chrome rings are tricky. I have not successfully removed mine without leaving tell-tale signs. They will get damaged no matter what you do. I hate the fact that the gauge glass becomes stained/dirty, and that Veglia never provided for a means of cleaning them. Let me know if you come up with an approach that works. I think that John Corbani's is as good as it gets...cut the ring at one spot and then resolder. Jim S.
Jon, I think the clock case is by another manufacturer and I think my clock might be different than yours. I looked at the rings on all my other gauges and there is no sign of a break in the ring. There was one in my clock. You might take the gauges out of the panel and look at the back side of the chrome ring. If there is a break on the back side then the rings might be like my clock. There was a but joint at one end of the rear cutaway. If that joint is broken, the ring can expand and come off. I then ground the chrome off the brass, at the rear, tinned the ground spots and soldered a piece of copper wire to keep the joint tight. If you are quick enough, and the joint is on the bottom, no one will ever know without pulling the instrument. I like the stealth picture of the bottom of the engine. What are you holding in your fingers? Looks like something having to do with the oil pickup. Getting close now. Good luck. John
I got them from Newco. They came in one length and had to be cut and bent. Use your old ones as patterns! That stuff doesn't bend very easily, it was just sort of trial and error until I could get them to fit. The smaller diameter on the right lower vent (the only one that size) I couldn't find anywhere, luckily I happened to keep that one so I just reconditioned that one.
Looks great, things are really progressing! Would Mark consider casting more of the license plate contact switches? There is a need for many more. Thank you, Scott
