Dino Restoration | Page 74 | FerrariChat
Dino Restoration
Discussion in '206/246' started by omgjon, Feb 18, 2006.
  1. Argento839
    Argento839 F1 Veteran
    Oct 21, 2005
    9,103
    Zero miles on the odometer... Love it!
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Is the better head gasket the Elring brand?
    Thank you
    The exploded view of hub parts look great, quite inspiring.
  3. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I don't know the brand, I got them from Bill at GT Parts.
  4. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    that newborn mouse hide looks sweet? Jon could you get sealed bearings for the rear hubs?
    Rob
  5. racerboy9
    racerboy9 F1 Rookie
    2,672
    The new Elring gaskets have the silicon beading.
  6. Rustybody
    Rustybody Karting
    Apr 17, 2005
    132
    Langen
    Michael
    Oh no
    you're putting it together with the steering wheel on the wrong side!
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    What color are you plating the hard lines that go from the brake caliper to the flexible brake line?
    Gold cad perhaps? Mine are so dirty they are difficult to see.
    Thank you.
  8. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    They're not plated. They are sort of copper colored naturally. I can get you the specs if you want them and where I got the lines and fittings.
  9. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I know there is a thread, but can't find it. Where do I get replacement glass for my rear view mirror?
  10. ENZOSON
    ENZOSON Formula Junior
    660
    Erie, Colorado
    PIETRO
    Jon
    The inside RV Mirror? If so,
    http://www.fiatparts.com/
    Call him with overall dimensions to make sure. Vitaloni makes a repair kit (comes with a new mirror).
    Pietro
  11. Argento839
    Oct 21, 2005
    9,103
    Jon, sorry in advance if I missed this before in the thread but I was wondering if you could share what radio you are thinking of installing?
  12. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I had the original checked out an a Ipod connector installed. It's a Becker Mexico.
  13. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,879
    Synchro - allow me to quote my response from your post concerning brake line plating.
    "Synchro - I do not believe that the lines are treated. They are standard hard brake lines of the day. I replaced them with a copper alloy line that has a copper appearance. I would not have them plated.
    You might take a look at this site. It has all the odd sized fittings that you will need. The proportioning valve fittings are different than the master cylinder. They have information on the various alloys of brake line, advantages and disadvantages.
    http://www.fedhillusa.com/
    Jim S."
    Jim S.
  14. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    Jun 7, 2006
    78,327
    Wurundjeri man.
    Arvin Grajau
  15. Argento839
    Oct 21, 2005
    9,103
  16. Kravchak
    Kravchak Formula Junior
    Oct 17, 2005
    850
    Northeast
    Ken
    What a great Idea...
  17. swift53
    swift53 F1 Veteran
    8,517
    E.S.
    Alberto
    Hello Jon,
    Where did you source your radiator (looks aluminum), and is it the same for all Dino versions?
    I have an "L" series, and as I would have to ship it to the USA to have it copied, it sure would be
    nice to find someone that already has a pattern(s). Thank you.
    Happy Holidays!
    Alberto
  18. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    rondavisradiators.com It is aluminum.
  19. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
  20. swift53
    swift53 F1 Veteran
    8,517
    E.S.
    Alberto
    Thank you John.
  21. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Happy Holidays Jon. May this be the year the Dino all comes together. You will have a humongeous crowd of well wishers at the unveiling. Can't wait
  22. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I hope it all comes together. It has been a HUGE undertaking. I can see a little light at the end of the tunnel. Nothing so far has been easy.
  23. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    well...you have had a lot of unseen eyes & ears wishing you well and admiring your work & efforts!! Go get em in 2008!!
  24. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    A few days ago I started the engine for the first time. It ran a little rough because none of the carbs had been adjusted. No water leaks and no oil leaks. A problem though. The mechanical oil pressure guage registers 0. A call to Jim Selevan who graciously came down to check things out. We hooked up the idiot light which worked fine, so that shows at least 12 lbs for it to go off. We hooked up the original sender unit still registers 0. We took out the sender unit and oil flows well as the engine is running. Took off the line from the oil pump, enough pressure there that you can't put your finger and hold it there. There is no blockage in the heat exchanger. Ran an air line from where the oil filter unscrews to where the oil pressure sender unscrews, good airflow doesn't seem like any blockage there. Did that from both ends. Took out the pressure release valve and made sure it was clean. Bypassed the heat exchanger still no luck. No more time in the day, see what tomorrow brings. Jim is a great teacher as he explains the theory in all the things we were doing. Also got a great lesson on how to tune the carbs. Hopefully not something not major.
  25. John Corbani
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Jon,
    Went back to page 87 and looked at the test stand. Hard to see where you missed anything but you never know. How about pulling coiled tubing and block fitting and putting air hose on it. See if mechanical gauge is honest. Hard to figure that something is plugged in the block but that is the check. Hope you did in fact record the start up, that the vibration was not too bad while carbs were getting adjusted and that all held together. Pressure on the oil line at the heat exchanger is good news. Go get 'em!
