Dino spark pulg gap | FerrariChat
Dino spark pulg gap
Discussion in '206/246' started by raywong, Jan 3, 2005.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    The repair and workshop manual recomands Champion UN19V gapped to 1.27mm.
    The blue manual recomands Champion N60Y gapped to 0.4-0.5mm.
    This forum recomands NGK BP6ES (?gap?).
    Got a lot of misfire above 4000rpm when I gapped the BP6ES to 1.27mm.
    Which one is right?
    Raymond
  2. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    0.6-0.7mm is best. The early manual had a crazy small gap, that was later corrected due to fouling.
    You'll also find a Dino runs sweetest on a fine tip plug, like an EVX or even EVIX (iridium), but a decent tune is important!
    It's also quite normal to have a higher heat range. BP8EVX, so long as your fuel quality is good.
  3. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
  4. Bob Zambelli
    Bob Zambelli F1 Rookie
    3,655
    Manning, SC
    Robert G. Zambelli
    Dinoguys - a gap of 1.27 MM (.050") is definitely on the high side, although the Dinoplex might marginally handle it. The absolute best setup I've found on a Dino with the 'plex bypassed is the NGK BP5ES or BP6ES, set to .035". As the gap is increased, a higher potential is needed to jump the gap and therefore more energy is discharged across it. Less chance of fouling.
    I use the BP5ES in my 330 along with Bosch Blue coils and, in an older car like mine with many miles, it is a prefect setup.
    Bob Z.
  5. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    don't really understand...please tell me more about the physic of gap clearance.
  6. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Apart from the electrical theories of spark voltage, the smaller gap encourages fuel and oil to bridge the gap potentially causing a short circuit.... especially during cold starting and excessive low speed use (traffic)
