Dino - steering rack | FerrariChat
Discussion in '206/246' started by FDino246GTS, May 24, 2016.
  1. FDino246GTS
    FDino246GTS Rookie
    Nov 26, 2006
    42
    Sydney Australia
    James S.
    #1 FDino246GTS, May 24, 2016
    Hi All -
    just tidying up the steering rack on my Dino as part of a slow resto.
    Wondered if anyone knows what the finished product for the SUPPORT MOUNTS is supposed to look like?
    I have one that I've cleaned and the other still on the rack. However, the one on the rack looks like it is covered in over-spray and the likes so I can't tell if it was originally painted black or not.
    thanks heaps
  2. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Not sure which series you have or if that makes any difference but painted semi gloss black seems right.
  3. rosemeyer
    rosemeyer Karting
    Aug 13, 2010
    155
    #3 rosemeyer, May 25, 2016
    James,
    I agree. Here is a photo of the assembly along with other related steering bits post restoration. Hope this helps and good luck with your project.
    Best Regards,
    Paul
  4. pshoejberg
    pshoejberg Formula 3
    1,828
    Denmark
    Peter H
    #4 pshoejberg, May 26, 2016
  5. FDino246GTS
    FDino246GTS Rookie
    Nov 26, 2006
    42
    Sydney Australia
    James S.
    thanks gents - much appreciated... semi-gloss black it is then :)
    *Paul (rosemeyer) Those nuts and washers look like they were cad plated or something... super shiny!! wow!
  6. FDino246GTS
    FDino246GTS Rookie
    Nov 26, 2006
    42
    Sydney Australia
    James S.
    #6 FDino246GTS, May 30, 2016
    almost all done and dusted.....
    got some washers and nuts to replace existing and that's probably it for the supports and rack (have done the rest of it).
    Have left 'some' of the patina on the steering rack still in place vs painting everything on it... this will be a driver vs garage queen.
    cheers
  7. swift53
    swift53 F1 Veteran
    8,330
    E.S.
    Alberto
    Peter, what is the serial number for the bearings?
    Thank you.
    Regards, Alberto
  8. pshoejberg
    1,828
    Denmark
    Peter H
    I reused the original bearings inside the rack. The skf bearing you see on the picture is the bearing for the lower steering shaft. I can find the serial number on that one if you like?
  9. swift53
    swift53 F1 Veteran
    8,330
    E.S.
    Alberto
    Sure, that would be great! Thank you Peter...
    Regards, Alberto
