Dino Throttle Cable Bellows | FerrariChat
Discussion in '206/246' started by Jamie H, Mar 21, 2011.
  1. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,425
    Puslinch,ON
    Jamie
    #1 Jamie H, Mar 21, 2011
    Does anyone know where to obtain the rubber throttle cable bellows that fits over the steel tube that the throttle cale passes through in the engine bay. This bellow looks similar to the two clutch cable bellows but with a much larger ID opening (25mm) at the large end.
    I have searched every supplier imaginable and have struck out on this apparently unavailable part. Attached is a picture of my damaged one.
    Any help would be greatly appreciated.
    Thanks,
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    I too have hit a wall looking for the exact same part. I am sure the F-chat legions will come to the rescue on this one.
  3. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
  4. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
  5. Nickrry
    Nickrry Karting
    Jan 4, 2009
    156
    me too please
  6. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    and me also
  7. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
  8. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
    Called them, it seems they make everything custom ($) as they make each individual mould.
    They will call me back...Probably would have to provide a sample. Do all Dino have this part?
    Regards, Alberto
  9. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
    Mc Master Carr: 5298K78
    Round Flexible Bellow 5/16" ID Cuffed End - 1" ID Flanged End
    In stock at $8.82 Each
    As I do not have one to look at, possibly someone can compare size.
  10. abacon
    abacon Rookie
    Mar 2, 2011
    3
    I am in a position to remanufacture the bellows in question from a chemical resistant silicone.
    The bellows could be created in a minimum run of 20 pieces for $35 a piece.
    The material that these bellows would be created from differ from the those at McMaster Carr, mine will be aircraft silicone. M-C's are latex and neoprene, neither material will last long under the hood of a car.
    If i did this project, a sample bellow that could be measured to create the CAD data and the tooling from is required. It would take about 6 weeks for delivery.
  11. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #11 synchro, Mar 22, 2011
    Can you also make the clutch cable bellows?
    It is especially sensitive for contamination at the rear where it opens upwards and dirt/dust could drop down into it.
    This is part of the reason why a clutch job gets expensive - the cable is usually replaced and it is nearly as expensive as the disc/pressure plate.
    I may have an unused NOS to use as a mold master
  12. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
    #12 swift53, Mar 22, 2011
    TWO of each please.
    Very interesting first post, though...
    Regards, Alberto
  13. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    I'm in for one.
    As for the clutch bellows Denis McCann has them and they are pretty cheap. Also if you are really in a pinch some Fiat clutch cable kits come with them. You can buy the whole cable for about 15 bucks, trash it all and us the bellows.
  14. abacon
    abacon Rookie
    Mar 2, 2011
    3
    Allow me to introduce myself. I am Alex Bacon and my company has the ability to create parts and assemblies. The company is design firm with rapid prototyping and short run tooling capabilities. If you would like to see more about it, www.alphastudioonline.com is where you will find us.
    Additionally, I have created a Sports Racer Alfa Romeo that was recently shown at the French Italian show at Woodley park here in Southern California. Below are some links to pictures of that vehicle
    http://picasaweb.google.com/SB.Alfaholic/2010BestOfFranceAndItaly#5537021848527638866
    http://picasaweb.google.com/SB.Alfaholic/2010BestOfFranceAndItaly#5537021853996839858
    http://picasaweb.google.com/SB.Alfaholic/2010BestOfFranceAndItaly#5537021859056040658
    http://picasaweb.google.com/SB.Alfaholic/2010BestOfFranceAndItaly#5537021869731034226
    http://picasaweb.google.com/araknd/2010BestOfFranceAndItaly#5537069507014059250
    http://picasaweb.google.com/araknd/2010BestOfFranceAndItaly#5537069511719978178
    http://picasaweb.google.com/araknd/2010BestOfFranceAndItaly#5537069521629484194
    http://picasaweb.google.com/araknd/2010BestOfFranceAndItaly#5537069532649799074
    http://picasaweb.google.com/araknd/2010BestOfFranceAndItaly#5537069536160529922
    http://lh3.ggpht.com/_-1JV9flNylQ/TNefamMhmTI/AAAAAAAAG4E/k1dCPwEvxMw/s128/100_2876.JPG
    http://www.alfabb.com/bb/forums/picture-room/170453-alfa-sports-racer.html
    We are capable of producing the bellows, but we would need interest in order to produce them.
    If there are other components anyone believes to be required, please let us know.
  15. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Looks like beautiful work. especially the front grills. what was the process there?
    Re group purchase
    Perhaps you could fix a price per unit, with a minimum quantity run,
    perhaps you could take credit card deposits of 10% of the order value and when you have received sufficient orders you could start your work.
    Perhaps if you do not get a sufficient number of orders in a specified period, you could keep the 10% for your trouble.
    Could you make the chrome windshield trim?
  16. abacon
    abacon Rookie
    Mar 2, 2011
    3
    Gentlemen,
    I proposed that for a quantity of 20, we could create the bellows for $35 each. There seems to be a loss in interest for this component in such a large quantity. We are able to create these bellows in lower quantities for the price of $475 each for 2 or $225 each for 4. This does seem like a heavy price, but understand that this would be an accurate reproduction of the orginal for those that are interested. There is a group of owners who find it acceptable to use perhaps a McMaster Carr component. We are not for those owners. We are for the owners who are interested in recreating the original appearance of components. Honestly, a wad of blue silicone would keep debris out and function....
    It's an economy of scale here boys... We are doing CAD work and creating rapid prototype parts and creating tooling..... IF you walked into our studio, we could create a one of a kind component duplicating the subtle nuance of your part.... and it would cost you $1,000... we are attempting to apply our craftsmanship and knowledge paired with our technology to make it less of a pain in the ass for some owners to locate unavailable parts.....
    Our interest in providing parts, handling money down and such is not worth our time. If several of you can get organized, we can create components...
    A good master is of course needed to provide the best components.
    With respect to the last question, we have created window trim components, just not for Dinos. You can expect that in a one off situation these would be pricey, if many were ordered the price would drop. We will, of course, not begin to estimate a price without seeing the trim.
    We can also create components for shifter carts, any shifter cart drivers?
    Thank you.
  17. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
    As previously stated, I am interested in two pieces. Do I hear more?
    Let's get this one rolling, send a check to our friendly purveyor Abacon, and do it once and for all.
    I am almost certain that we could interest Colin at Superformance to order a few.
    I will pass this info to him and see if we can get results. Come on guys!
    Regards, Alberto
  18. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    I am in for One
  19. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    One for me please
  20. 72Dino246GT(Eur)
    Dec 1, 2005
    34
    SFO Bay Area
    Peter Hollyer
    One for me please.
  21. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
    I forwarded the story to Colin at Superformance. We'll see what he says.
    Regards, Alberto
  22. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,425
    Puslinch,ON
    Jamie
    Hi Alberto. I actually have spoken to Colin about 2 weeks ago on this item. He was to speak to his rubber supplier in South Africa and get back to me..he seemed very confident and interested. I will also follow up with him and post results.
    Cheers.
  23. swift53
    swift53 F1 Veteran
    8,339
    E.S.
    Alberto
    Ok, It's a plan.
    Regards, Alberto
  24. DinoDriver
    DinoDriver Formula Junior
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    Hi guys, I was crawling around under my Dino a couple days ago and was reminded (again) that I need a new bellows. Just wondering if there's been any progress on finding a replacement throttle cable bellows. Both threads on this subject died in the March-April timeframe. Apparently, the Porsche 914 idea didn't pan-out.
    Bill
  25. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
