Dino vent window latches | FerrariChat
Discussion in '206/246' started by Daryl, Sep 27, 2004.
  1. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,035
    Barrington Hills, IL
    Daryl Adams
    The vent window latch on the driver's side has gone missing from my Dino Spyder. Anyone have an opinion on the best source for replacements? Thanks.
  2. dm_n_stuff
    Dec 10, 2003
    43,710
    26.806311,-81.755805
    Dave M.
  3. need4speed
    need4speed Formula 3
    Nov 3, 2003
    1,616
    Pacific Palisades
    I was told by the shop that resprayed my Dino to leave them off. I have both sides. I was told that the glue doesn't hold well and they will fall off. And then you'd be left with a vent window with a circle of glue.
    What are other Dino owners' experiences with these little things? Do they stay on?
    Thanks,
    Manny
  4. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,035
    Daryl Adams
    It's true, the bonded latches don't hold. My car's previous owner had the latches in an envelope in the glovebox. I glued them back on with the usual rearview mirror adhesive and simply never latched them, avoiding any stress on the latch. While out at Concorso in August I parked the Dino in front of the hotel and paid the valet to "watch" it. I noticed the latch missing the next day. I suspect someone may have tried to do me a "favor" and latch the window, with the latch coming off in their hand. (Could have at least left my the latch!)
    Thanks for the sources. I'll chase one down over the winter.
  5. yasmin
    yasmin Formula Junior
    There's some on Ebay now...Ferrari Dino window latches, item number 7925768053.
    worth a look.
  6. tx246
    tx246 F1 Veteran
    6,659
    Texas
    Shawn
    mine are off my car and residing in the glove box. they do not hold. i have seen more than one car modified. one had a new glass insert that allowed for a solid latch (through the latch), the other had a sliding mechanism that was nicely executed. this issue has come up many times before. i figure that i never going to park my dino where it would matter that the car is 100% secured anyway, so what is the point of trying to theft proof the car anyway. the daytona's have the same problem.
  7. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    I tried epoxy, fell off the third day. tried crazy glue, fell off the next week.
    The other side has never came off, so it is possible. I might try again with steel fibre epoxy.
    Don't worry, you can easily remove all the glue with a razor blade.
  8. dm_n_stuff
    Dec 10, 2003
    43,710
    Dave M.
    #8 dm_n_stuff, Oct 2, 2004
    You need to be a little careful gluing and using the latches. I had my passenger latch actually take some of the glass with it when it came off for the prior owner.
    The best arrangement I've seen involves making a wrap around bracket and getting it chromed.
    One of these days I'm gonna get a set or two fabricated, and sell them to all of you guys, too.
    Here's a picture.
  9. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,250
    NYC. / E. Hampton
    Michael
    I have owned 5 different Dinos through the years, it wasnt until the last one that I figured out the Answer... Tape a dime to the vent window exactly where the latch mount will adhere.....then mask off the area surrounding the dime to about a 3 inch radius....carefully remove dime and with 600 wet/dry paper, stroke the exposed area lightly ,just enough to put some teeth into the glass so that the glue has something to hold onto.also put some teeth into the contact patch of the latch...A small dab of 2 stage 5 minute clear Epoxy will do the trick and the wetness of the glue will fill in any minor abrasions that the sand paper made on the glass. It worked for me.
    Good Luck.
  10. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    Thanks. That makes a lot of sense.
  11. dm_n_stuff
    Dec 10, 2003
    43,710
    Dave M.
    I tried the wet/dry sanding, followed by 2 part epoxy, in my case, JB Weld, which worked like a charm. I actually had a fairly large chunk out of my window glass, filled it with JB Weld, let that set for a couple of minutes, then affixed the latch.
    Holding like a charm.
    (Keeping fingers crossed.)
