Dinoplex AEC 104 BK for 512BB | FerrariChat
Discussion in 'Technical Q&A' started by Drew Altemara, Jun 26, 2017.
  1. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,537
    Tuscaloosa, AL
    Drew Altemara
    Is there a way to test this Dinoplex? Having a spark related problem. In reading through the history someone said that you could short (small jumper) the 6 pin plug going to the Dinoplex temporarily just like the Dino wiring does. They suggested jumping between pins 3 and 4 which would be K (Coil - ) to Tach which does not seem right. Looks like 1 to 3 would be the sequence magnetic pickup to K (Coil -)
    Appreciate.
    Drew
  2. Stefan Elshout
    Stefan Elshout Karting
    Dec 1, 2011
    168
    Holland
    I don't think that's a smart thing to do. If you have a distributor test machine (or know someone that does) you could bench test the system on it.
    Also with a function generator you can generate the sin-wave signal from the magnetic pickup to test the AEC104 and coil.
    First option would be the best because you also test the magnetic pickup / advance etc.
    The second option is the easiest.
  3. Drew Altemara
    Feb 11, 2002
    1,537
    Tuscaloosa, AL
    Drew Altemara
    I do not have access to thay type of equipment but it is a good suggestion.
    I'm going to check the resistance on the coil and check the distributor cap carbon tip.
    After that I can check the wiring.
    What's left is the magnetic pickup and Dinoplex. Go from there.
    Good project for the weekend.
    Thanks,
    Drew
