Dinoplex Ignition Documentation | FerrariChat
Discussion in 'Technical Q&A' started by alhbln, Dec 17, 2012.
  1. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    I am close to have all the documentation bits online on www.dinoplex.org for the different ignitions in the Dinoplex family. I've started this projects some years ago as there was virtually no documentation available for these ignitions at that time.
    Please let me know what you're missing or what i could do better in terms of structure or documentation, as this only works out as intended if it helps you with any issue getting a Dinoplex setup up and running.
    Thanks,
    Adrian
  2. tazandjan
    39,034
    Adrian- Wow, that is great stuff. Must have taken you a long time to assemble all that data. Fine job.
  3. Gerry328
    Gerry328 Formula 3
    2,335
    Home
    Gerry
    Impressive
  4. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    949
    Arizona
    Jim
    I see you made a number of recent updates. Just wanted to say Thank you. Your web page is my go to source for these ignition units. Great job.
    Since I have an AEC104B780 ignition box that cuts out at 5000 RPM I would be interested in the wiring diagram for the rev limiter. If you are looking for suggestions on what to add next. More than likely I will fix it with an MSD unit per your instructions, but it would be nice to fix the original box.
    Thanks again
    Cheers Jim
  5. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Ok, rev limiter is on the list! If you also need the diagrams for the Countachs Air Injection and Fuel Pump RPM switches, shoot me a mail.
  6. pshoejberg
    pshoejberg Formula 3
    1,792
    Denmark
    Peter H
    Beautiful work. This will contribute to the survival of theses old transistor type units. Are there any sources for the transformer in a Dinoplex C AEC 101 C/D/E unit?
    Peter
  7. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    #7 alhbln, Dec 18, 2012
    Yes, i have a transformer workshop who can build them after my specifications. I can mail you the address if you want to buy one. See below for the original transformer on the left and the new one on the right. I also have a transformer spec sheet on my to do list for the website, so if you have a transformer workshop in your area then they should be able to create a new one for you based on the spec sheet.
  8. tazandjan
    39,034
    Adrian- Even more impressive as I went through all you have on the site. I bought a 1970 Fiat Dino 2400 GT in 1980 that was missing the Dinoplex. Installed an MSD unit with tach output and was amazed at how much smoother the car ran than just on points. Tach worked fine, too. So long ago I do not remember what MSD unit that was.
  9. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Terry, thank you! Indeed, the Dino V6 engine does not run that well with a standard points ignition so i guess most of the owners of an early series Fiat Dino without a Dinoplex have upgraded by now :)
  10. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Jim, i've added the connector/wiring information to the AEC104B660/780 diagram and uploaded a diagram of the Rev limiter including the calibration procedure.
    http://www.dinoplex.org/#Dinoplex_AEC104
    Adrian
  11. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,218
    Sergio Tavares
    Where can I get the tachometer electronics?
    http://www.dinoplex.org/tachoconversion/index.html
  12. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
