Direct replacement for 430 OEM muffler | FerrariChat
Discussion in '360/430' started by Mazzyman, Mar 9, 2024.
  1. Mazzyman
    Mazzyman Rookie
    Jan 24, 2020
    24
    Mark watters
    I have the usual white powder problem coming from my OEM muffler. I don’t want to change the exhaust system, just the muffler. Is there an alternative muffler which bolts directly to the OEM flanges?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    PD Gough in Nottingham will make you one to suit, they make all sorts
    Mazzyman likes this.
  3. Mazzyman
    Mazzyman Rookie
    Jan 24, 2020
    24
    Mark watters
    Thanks Mike, I’ll check them out.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Be sure you talk to them about noise level as they can change it, also think about fitting rockwool as the insulation. I think the white dust from the oem is calcium silicate, so rockwool does not go to dust. Think about a removable cover rather than welded on
