355 - Disable Automatic Door Lock | FerrariChat
355 Disable Automatic Door Lock
Discussion in '348/355' started by C-speed, Aug 9, 2022.
  1. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    Hello,
    Is there a way to disable to the automatic door lock? It’s rather annoying having to manually unlock the doors when I want to exit the vehicle.
    Thanks.
  2. Qavion
    Qavion F1 World Champ
    14,263
    Ian Riddell
    #2 Qavion, Aug 9, 2022
    You have an automatic door lock? Sounds like a fault, not a feature.
    When does it lock?
    Make sure that your door switches are hooked up to the correct plugs. When I bought my car, I recall the fog light switch was hooked up to one of the doorlock plugs.
  3. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    Hmm… interesting. The doors automatically lock as soon as I hit the gas pedal and start moving.
    The lock/unlock switches and remote work normally.
  4. Qavion
    14,263
    Ian Riddell
  5. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
  6. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    Automatic door locking of this type might be mandatory in certain markets.
  7. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    I have 97 Spider US model. I couldn't find any info on automatic door locks on Google or on F-chat. I'm thinking it might actually be a bug, not a feature lol.
  8. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    Ok, I just did some testing. The car doesn’t have to be running or moving. If I turn the key to power up the car, as soon as I step on the throttle the doors lock. I can repeatedly step on the gas pedal and the door locks won’t try to activate again. If I unlock the doors and step on the gas pedal, they will lock again.
  9. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    Update: the key doesn’t have to be in the ignition and the doors will lock if I step on the gas pedal.
    Strange.
  10. m.stojanovic
    m.stojanovic F1 Rookie
    3,217
    Serbia - Niš
    Miroljub Stojanovic
    It may be due to some additional installation by the dealer or the PO. Look for a micro switch somewhere on the gas pedal.
    Qavion and 308 GTB like this.
  11. Qavion
    14,263
    Ian Riddell
    Someone else is having issues here....
    https://www.ferrarichat.com/forum/posts/148679921/
    As Miro says, it may be a modification, so check for a switch on the accelerator pedal. Or perhaps there is some wiring behind the pedal that is shorting out when you push it ???
  12. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    Thanks big time for all the help everyone! I took apart the pedal cover and front center console and discovered that the throttle cable was pinching a bundle of aftermarket wiring for the radar detector/laser jammer which was causing the door lock switch to activate.
    All fixed now! Woot!
    308 GTB and Qavion like this.
