What's the best and easiest way to disable ignition on a 360? I just want the engine to turn over but do not the spark plug to fire or spray fuel. TIA
Well... if you are referring to the RSR muffler. Then yes yours truly. Just too lazy to turn the engine by hand... Need to rotate it couple of times.
Why not leave the car alarm armed (blinking LED). It will turn over, but not start. Am I missing something?
With the alarm disarmed and the immobilizer activated, the engine should turn over but not start. The immobilizer activates 120 seconds after the alarm is disarmed with the fob if the engine is not started. Alternatively, if you turn off the engine, remove the key, and open the door, the immobilizer activates 60 seconds after the key is removed. Taz Terry Phillips
