disassembling a Kyosho - how to? | Page 2 | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by bigodino, May 1, 2005.
  1. bigodino
    bigodino F1 World Champ
    12,626
    The Netherlands
    Peter den Biggelaar
    Well, I guess I like to take things apart. :)
  2. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    48,596
    @ the wheel
    Andreas
    Taking it apart is easy. Good luck on the assembly. That's why I'm rather conservative on what I disassemble and what not.
  3. Gimme Fuel
    Gimme Fuel F1 Veteran
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    #28 Gimme Fuel, May 9, 2005
    Peter, the guys says THANX A LOT!!!!!!:D:D:D:D:D:D
  4. tifosi12
    Oct 3, 2002
    48,596
    @ the wheel
    Andreas
    For them it is a lot easier to disassemble these cars, they got smaller hands and tools.
    Aren't you worried that the masked dude one day will get his chain caught up in a timing belt and that'll be his demise? I see a gruesome story in the making...
  5. Gimme Fuel
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    LOL - I'll make that one, but not here - try www.chainsawmassacrechat.com LOL
    I can REALLY picture it for me...your idea that is :D got to be a meeeeeeeess! :D
  6. tifosi12
    Oct 3, 2002
    48,596
    @ the wheel
    Andreas
    Too bad for him, but think about all the expensive valves and pistons killed in the process...
  7. Mule
    Mule F1 Rookie
    3,752
    Alaska
    Mule
    #32 Mule, Feb 19, 2012
    Google search "disassembling a Kyosho 328" and this thread is the first search result.
    I am reviving this old thread because I am working a new project. I have a 1:18 Kyosho 328 GTB red/black, and a 1:18 Kyosho 328 GTB black/tan. I want to swap the colors and have a black/black and red/tan. Keeping the black/black, ebay the red/tan.
    I pulled the screws out underneath for the front valance, and the rear valance/muffler. Pulled the center one out halfway down the chassis. Underneath the valances were two more in front, two in the frame rails, and two up in the engine bay (when looking from underneath).
    The front end of the chassis is loose from the body, but the back end seems stuck around the engine.
    So what is my next step, and is the interior attached to the body or the chassis?
    Thanks for the help - if you help me achieve the black/black one, the red/tan is up for grabs.
  8. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #33 bigodino, Feb 19, 2012
    I've taken pictures of the disassembly of the 308. I guess the 328 should be basically the same.
    1. Remove the rear lower valance. Be careful for the muffler. It's glued into the valance with small pins. It's almost impossible to not break the pins off. So you'll have to glue the muffler back on once you're done assembling.
  9. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #34 bigodino, Feb 19, 2012
  10. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #35 bigodino, Feb 19, 2012
  11. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #36 bigodino, Feb 19, 2012
  12. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #37 bigodino, Feb 19, 2012
  13. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #38 bigodino, Feb 19, 2012
  14. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #39 bigodino, Feb 19, 2012
    7. Now you can take the body and interior off the chassisplate. But be careful: the engine is still connected to the rear part by the engine mount and some lines. I don't think there's a way without breaking those lines.
    Once you've removed screws #7 and the engine, the interior should come out easily. Mind the steering column though.
    If you want to switch the door panels as well: good luck! They are glued into place with two large pins in holes inside the doors. Try to gently wriggle them loose. Be carful not to tear the panel. It's only plastic! The window glass is tucked between the door and the door panel.
  15. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #40 bigodino, Feb 19, 2012
  16. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #41 bigodino, Feb 19, 2012
  17. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #42 bigodino, Feb 19, 2012
  18. Dino2010
    Dino2010 F1 Rookie
    4,852
    Belgium
    Anyone 's thought about buying it eventually????:D
    Like that you keep the GTB and you got an original GTS as well... something you'd definitely consider in case we were talking about scale 1:1.....
    http://ascari.over-blog.com/article-17471587.html
  19. Mule
    Mule F1 Rookie
    3,752
    Alaska
    Mule
    Peter - unbelievable! Thank you, thank you, thank you. The screws in the wheel wells are what stopped me. I will post progress over the next few days.
    My end goal is to have a 328 GTS black and black. Since I can't find a Kyosho GTS right now, I figured I would make a GTB black and black without any aftermarket painting. Then maybe spray a little satin black to look like a GTS roof.
  20. bigodino
    12,626
    The Netherlands
    Peter den Biggelaar
    #45 bigodino, Feb 20, 2012
    Glad to help. GTB to GTS you say? Been there done that! :)
  21. Mule
    Mule F1 Rookie
    3,752
    Alaska
    Mule
    #46 Mule, Feb 20, 2012
    I will start with baby steps. I do have my Anson version, that I painted the interior and changed the wheels.
  22. Mule
    Mule F1 Rookie
    3,752
    Alaska
    Mule
    With your instructions, I disassembled one on 4 minutes. Are the interior door panels glued or screwed, since I have to change those, too?
  23. Mule
    Mule F1 Rookie
    3,752
    Alaska
    Mule
    #48 Mule, Feb 20, 2012
