Disconnecting power to go on vacation | FerrariChat
Discussion in '348/355' started by bballto, Aug 20, 2015.
  1. bballto
    bballto Karting
    Mar 10, 2014
    155
    I'm planning to go on vacation for 8 days. What are the thoughts on disconnecting the power on a 348 to prevent battery drain. Thanks
  2. 2MS
    2MS Formula Junior Owner Silver Subscribed
    Oct 5, 2004
    342
    Bay Area, CA
    Mark
    You could either disconnect the battery entirely or go with a tender. Then you won't have to perform the start up process when you get back. 8 days is not that long without starting it.
  3. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    That's what I was thinking. If your battery is going dead in 8 days you have a serious drain or time for a new battery. I leave my cars 8 weeks at a time during the winter with no tender and they (usually) start.
  4. 8500rpm
    8500rpm Formula Junior
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Disconnecting the battery forces you to adjust the clock and radio presets (if you have any on this car) when you get back from your trip.
    If your battery is any good, it should be able to last for more than that on such an old car with few electronic systems to power when parked.
  5. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    Clocks in the 348 always need resetting, even with power never being disconnected.
  6. Stentboy
    Stentboy F1 Rookie Owner Rossa Subscribed
    May 8, 2008
    2,816
    Texas
    Ron
    I've always just disconnected it using the knob under the bonnet. Has worked fine for me for the last 22+ years.
  7. troppoveloce
    troppoveloce Formula Junior
    Jan 25, 2006
    268
    New Hampshire
    Tom
    It's always a good idea to keep these cars on a trickle charger.
    I learned the hard way years back with my Lotus Esprit. After sitting for a while, the battery got weak and when I tried to start the car, the low voltage caused an amperage spike that fused my starter into the "start" position. The only way to stop the engine was yank the battery and stall it in gear. Very ugly.
    Ever since then, I've been a firm believer in trickle chargers. With my 348 I rigged a trickle charger that runs directly into the cigarette lighter. Easy in, easy out.
  8. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Theres no problem disconnecting the power while your on vacation.
    Thats what the switch is there for
    Resetting the clock or radio is a non issue.
  9. Oengus
    Oengus F1 World Champ Rossa Subscribed Silver Subscribed
    Sep 29, 2004
    10,841
    Between timing belts/chains or West Palm Beach FL
    Chas
    trcikle charger
  10. frezza
    frezza Rookie
    Sep 26, 2013
    19
    no doubt
  11. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    A trickle charger keeps trying to pour electricity into a full battery. You really want something smarter that only that only "pours" when needed, i.e. a battery tender.
