"disegno di Pininfarina" badge placement | FerrariChat
Discussion in '206/246' started by mkeith, Feb 6, 2013.
  1. mkeith
    mkeith Rookie
    Mar 15, 2009
    46
    Houston, TX
    Michael Keith
    This is for a 74 GTS. It was recently painted; so I ordered all new badges. The car came without the Pininfarina badge on the RH fender, & now I would like to add it. The holes have long since been filled in. Therefore, I would like to know if there are any measurements that would help me place the badge correctly. From photos of other cars, I can see approximately where it should go, but I would like to get it as close to the right location as reasonably possible.
    I was not able to turn up any measurements with an archive search. Thanks in advance for any input.
  2. vrooom
    vrooom Formula Junior
    Jan 29, 2007
    457
    my 73 gts has it 1 " down from the crease (top of emblem ) and 5" over from the door opening (top right corner of emblem ) the car was painted many years ago so i don't remember if there were holes in the body to position it or if it was stuck on "close enough " hope someone else can also measure for you. dan
  3. mkeith
    mkeith Rookie
    Mar 15, 2009
    46
    Houston, TX
    Michael Keith
    Thanks Dan. That tells me what I need to know. In other photos I've seen, that appears to be about where the badge is positioned. So I'm confident that yours is in the correct position, & having some actual measurements really helps.
