Disgustingly short key fob range. | FerrariChat
Discussion in 'FF/Lusso' started by astrotheide, Aug 5, 2021.
  1. astrotheide
    astrotheide Karting
    May 3, 2017
    58
    Tampa, FL
    Andrew
    I’ve owned a 458 and an f12, both have had disgustingly short ranges for the key fobs.
    Italian engineering at its finest.
    Anyone run into this issue and have a solution?
    PJxxx likes this.
  2. soulsea
    soulsea Formula 3
    1,387
    29464
    Don't sweat the small stuff?
    otakki, Falcon7x, dustywusty and 3 others like this.
  3. Da Butcher
    Da Butcher Karting
    Jan 9, 2018
    219
    Jose Marie Alandy
    From a different but positive perspective, the shorter key fob range distance may be a blessing especially if there are car thieves around with a digital scanner that can decode, copy and mimic your car's distinct key transmitter code to steal it sometime later.
    A tried and true process to somehow lengthen its transmission distance is to place the key fob directly under your chin which will make your entire corpus as an antenna transmitter.
    It also used to bother me but after I found out about car thieves sophisticated Modus Operandi, I only trigger my key fob when I'm close to my car.
    Bas and SAFE4NOW like this.
  4. nickorette
    nickorette Formula Junior
    375
    Canada
    I have to be about 2 feet away for the F430 fob to work. But I think my alarm battery might be on the way out...
  5. jamie140
    jamie140 F1 Rookie
    3,298
    GTA/Marco Island, fl
    Jamie
    Replace the battery.
    Exercise gratitude that you can own the car.
    TimboSlice and FerRrari like this.
  6. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    You'd think that replay attacks were well understood by the automotive industry
    I know the LandCruiser guys replaced the key antennas in their cars for extending the range, I wonder if something similar is possible
    https://forum.ih8mud.com/threads/mod-extending-range-of-keyless-entry.1113795/
  7. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    Usually it's due to Ferrari's wonderful placement of the antenna.
    This was a common issue on the 360; if you search the 360 forum, you should be able to find the fix. I did it on my 360 and range went from about 2 feet to 50-75 feet. You basically just have to move the antenna so it's not blocked by a bunch of metal.
    Ray
  8. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    Antenna/Sensor needs to be replaced on F12s. Warranty case normally.
    Just done on my F12 tdf.
    Marcel Massini
    ryalex likes this.
  9. Adamas
    Adamas F1 World Champ
    12,008
    Out of town
    This has been a gripe of mine forever.
    Embarassingly bad.
  10. Solid State
    Solid State F1 World Champ
    10,589
    Maximus Decimus Meridius
    I don't know what you're talking about. I can get at least six feet on a good day. Seriously, do the under chin thing if it bothers you. It works on all key fobs.
    ryalex likes this.
  11. astrotheide
    astrotheide Karting
    May 3, 2017
    58
    Tampa, FL
    Andrew
    Ha, I feel blessed with 6 feet.
    I was standing by the driver side door the other day when I posted this thread and it wouldn’t unlock. The world was against me for a couple seconds there haha
    Solid State likes this.
  12. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    I can get probably 50m with each key fob. Not been an issue for me beside the time the batteries ran out.
    vraa and Napoli like this.
  13. Napoli
    Napoli Formula Junior
    Nov 18, 2017
    958
    NOYB, Ray!
    I can get it from inside my main house to the guest house garage approximately 100 feet away. Yes, I feel lucky.
    vraa likes this.
  14. Solid State
    10,589
    Video or it didn't happen. :)
    ScottS and vraa like this.
  15. Napoli
    Nov 18, 2017
    958
    NOYB, Ray!
    How come no one trusts anyone on FChat? :(
    Falcon7x likes this.
  16. ScottS
    ScottS F1 Rookie
    2,937
    Winter Park
    Scott S
    It’s a funny thing. But my son and I discovered that if you hold the Ferrari key against your cheek it works for much farther away. It probably has something to do with the antenna and power on the key it’s self as opposed to where the intent it is on the car. We discovered this while looking for our car at Disney. He said dad watch this and in fact it did work from much farther away.
    This Maneuver subsequently worked with the 488, F12, Lusso, and F8 and 812 currently. So it is not generational.
    I’m not suggesting that this should be how we normally use the key of course, just giving a data point.
  17. astrotheide
    astrotheide Karting
    May 3, 2017
    58
    Tampa, FL
    Andrew
    LOL LIES
  18. astrotheide
    astrotheide Karting
    May 3, 2017
    58
    Tampa, FL
    Andrew
    I tried that and it doesn’t seem to help any. I was thinking about replacing the battery in the key maybe to see if that’d help.
  19. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    As said before (post #8) one has to replace sensor/antenna in the roof, not just batteries in the key.
    I did all of that ten days ago on my F12 tdf. Under warranty.
    Marcel Massini
  20. Napoli
    Nov 18, 2017
    958
    NOYB, Ray!
    Facts! Now, piss off, troll!
  21. astrotheide
    astrotheide Karting
    May 3, 2017
    58
    Tampa, FL
    Andrew
    Hey man I’m the one that started the thread. If I could have my unlock and lock button work more than 10 ft I’d be blessed.
  22. ryalex
    Aug 6, 2003
    25,990
    Las Vegas, NV
    Ryan Alexander
    Nature's antenna. I do it instinctively now.
  23. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    My bet is that it's the alarm module antenna location. As mentioned above, it was a common issue on the 360. Here's a thread about it; on page #3, I show how I resolved the issue on my car:
    https://www.ferrarichat.com/forum/threads/distance-on-360-alarm.111841/
    Might be a similar issue on your car?
    Ray
  24. Solid State
    10,589
    Sir, is that the flat 'shark fin' on the roof top itself or, as some say, imbedded in the rear glass? If on the roof, did they indicate to you that the ceiling liner had to be removed?
  25. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    Not the shark fin on the roof.
    Marcel Massini
