Distance from top of shift gate to center of shift ball | FerrariChat
Discussion in 'Technical Q&A' started by Steve Magnusson, Mar 13, 2023.
  1. Steve Magnusson
    26,932
    Looking for the (stock) dimension from the top of the shift gate to the center of the shift ball on:
    TR = ?
    308/328 = ?
    TIA
  2. Rifledriver
    37,288
    #2 Rifledriver, Mar 14, 2023
    What degree of accuracy do you need?
    Can I stick a ruler down into a shift box or?
    waymar likes this.
  3. Steve Magnusson
    26,932
    Eyeballing a ruler (or tape measure) is fine -- say +/- 1/4", but just go from the top surface of the shift gate to the center of the shifter knob ball.
  4. Rifledriver
    37,288
    Glad I asked. I thought you were speaking of the ball on the bottom of the shift rod.
    308 is 7 3/4 to 8 inches. TR has to wait until home.
    waymar likes this.
  5. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,537
    Tuscaloosa, AL
    Drew Altemara
    I seem to remember the shift rod to be shorter on the carb 308 and longer on the 308QV. Or is my memory failing.
  6. Ricambi America
    Sponsor Owner
    Doesn't the position of the lock nut for the shift ball also somewhat affect this measurement? I'd guess there is about 7-12mm of 'thread' on the shaft which could affect the height of the ball, depending on the lock nut.
    waymar likes this.
  7. Rifledriver
    37,288
    It can vary but as delivered they were screwed most of the way down the thread.
  8. Steve Magnusson
    26,932
    I'm not looking for a super-exact number -- just what the ballpark is (and realize that there's some adjustment uncertainty, but bonus points if you give the exact F model measured).
  9. Rifledriver
    37,288
    I have both here and they measure the same. They are different part numbers but length does not seem to be the difference.
    It was in vogue at one time to cut them down. That may have been the reason for your recollection.
  10. Dockboy
    Dockboy Formula Junior
    630
    Maryland
  11. Steve Magnusson
    26,932
    I'm thinking that this is true as well. Just scaling a photo of my ex-308 carb, I get a number like Dockboy's (~6"):
    but believe Rifledriver's measurement, too. The SPCs also indicate there was a part change for the shift stick lever from carb 308 (108822) to 308i-2V, 308QV, 328 which all use 116738. Anyone got a photo like Dockboy's, or mine, handy for a 308i-2V, 308QV, or 328 to post? An about 2" difference should look obvious.
  12. Dockboy
    630
    Maryland
  13. Steve Magnusson
    26,932
    Yeah, have to say that is longer.
  14. Dockboy
    630
    Maryland
    No Steve....that is of my car again....same 6 inches
  15. Steve Magnusson
    26,932
    My bad ;) - thought that you were saying "here you go (a picture of a 308i-2V, 308QV, or 328 you requested)".
  16. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,233
    Georgia
    Wade Williams
    1990 TR 6 1/2
    1977 308 carb, dry sump, 5 3/4
    1989 328, ABS, 7
    1987 328, 7
    1999 355, 6 1/2
    1983 512 BBi, 6
    That is just what I had close.
  17. Rifledriver
    37,288
    All very interesting. Last night I measured the 328 and TR and as others have reported both are around 7 inches. This AM I remeasured the 308GTSi and QV here and both are closer to 8 than to 7. All 4 cars have the ball screwed almost all the way down on the threads. Only the QV has a non OE ball. It is larger so measured at the middle its about 1/4 taller which makes sense.
    Anyway I assume this exercise it to decide how tall the shifter should be in the new car?
    Very cool car by the way. 2 cars I always wanted to build for myself, one was a 67/68 Mustang retro rod sort of thing with a lot of grunt. Had a girlfriend many years ago with a 67 GT500. With an iron 428 it handled abominably but it was fun to drive and looked good. With a modern lighter engine and real suspension should make a really good car.
  18. Drew Altemara
    Feb 11, 2002
    1,537
    Tuscaloosa, AL
    Drew Altemara
    This is from a failing memory so take it with a grain of salt:
    I've had 2 carb and 1 QV 308.
    I seem to remember being told that some customers had complained about the heavy clutch and shifting on the carbed 308 and that the shift rod was lengthened and angle at which you push the clutch was changed on the QV to make it a little lighter. But that was when I was buying the QV so might have been a sales pitch.
    Is the QV easier to shift?
  19. Steve Magnusson
    26,932
    Exactly ;). I definitely prefer a shorter shift lever, but it's hard to compare, and make a decision, without actually being able to sit in the car (and it has a non-stock center console and transmission so not even sure where the shifter is located relative to stock).
    I'm hoping so. The basic overall structure/chassis is almost identical to a TR except for the engine placement -- and I'm thinking along your lines that that won't be much of a penalty with the lower and lighter powerplant (and it has ~80 more HP). One thing that I'm looking forward to is that the 5-speed Tremec that I've selected has a much larger spacing between the gears so in 1st gear it's like an American Muscle Car with a 4.11:1 differential (so good grunt), but, in 5th gear, it's taller than a TR -- having a 2.50:1 overall drive ratio (so good freeway cruise MPG). I stayed away from going to a modern 6-speed (although I'd like having that) just because they are so much physically larger that the center console and transmission tunnel have to be made much larger and bulkier. The Shop doesn't seem to be in a rush to complete it (because, being in MN, they can't test drive/sort it until after the snow melts) so I'm hoping to get it in about mid-late April -- will post pics.
