distributor advance | FerrariChat
distributor advance
Discussion in '308/328' started by johnvwatts, May 10, 2010.
  1. johnvwatts
    johnvwatts Formula Junior
    Jul 7, 2007
    522
    England
    John v watts
    Can anyone tell me how I can check whether the advance on my single dist euro 308 is sticking? One minute it runs ok the next with a terrible misfire. When started sometimes the rpm go crazy but the cable isn't sticking. The revs are also erratic occasionally. Checked all the usual culprits - plug extneders,leads cap etc.
  2. BigTex
    79,386
    Houston, Texas
    Bubba
    Well, you can read the timing marks thru the inspection plate on the flywheel, but to "calibrate it" properly you really need the antique distributor calibration machine that matches the car......
    It's rather a 'plug and play' situation once they are in the car.......
    Lubing the advance mechanism is a function on the Service Interval........maybe someone more versed than I, could walk you thru that.....it does indeed cause wonky behavior if it malfunctions....it's strictly centrifical based on the weights and springs...
