DIY 348 Major | Page 2 | FerrariChat
DIY 348 Major
Discussion in '348/355' started by dkny, Mar 27, 2013.
  1. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    My buddy owns the property next to the yard.
  2. phrogs
    phrogs F1 Veteran
    7,367
    Kzoo Michigan
    So did they take that one back? Free lift? haha
  3. want2BSchumi
    want2BSchumi Karting
    May 22, 2008
    86
    Los Angeles, CA
    Russell
    Have you tried putting the scope through the oil drain hole in the pan? That's how I eventually found the washer when I did the same thing a couple of years ago.
    http://www.ferrarichat.com/forum/348-355/308290-first-diy-30k-service-dropped-washer-cyl-head-need-help.html
    Also, if you do end up having to pull the oil pan, be careful to only use a VERY thin film of sealant when putting it back on. I've now had my second engine out adventure in two years due to excess sealant breaking loose in the pan and getting chewed up in the oil pump chain. I used a very small amount of Yamabond 4 when putting the pan back on.
  4. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    If you don't mind my asking, what were the signs/symptoms of a broken off rtv sealant worm? Did you get engine damage due to oil starvation or did you just find pieces at oil change time?
  5. want2BSchumi
    May 22, 2008
    86
    Los Angeles, CA
    Russell
    I found pieces during an oil change. The motor internals looked fine once I everything apart but the oil pump screens were starting to clog up with all of the little pieces and it would have been a problem at some point as more and more of the worms got chewed up.
    I found it strange, that the sealant worms stuck for a number of years (at least 3 since I've had the car) and just decided to come loose sometime last year. In any case the story is in another thread here:
    http://www.ferrarichat.com/forum/348-355/393608-plastic-fragments-oil-what-they.html
  6. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Very good advise about using just the right amount of rtv. Ive seen some mechanics gobbing it on quite heavy when re-seating cam seal/valve covers... Very easy to put too much on as they form perfect oil-hole-sized interior worms as surfaces are torqued together.
  7. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    SO, did you find the washer? Where? How?
  8. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    I ordered some smaller magnetic tools, should be in within the next few days. I am trying some other suggestions that were posted on here by my brothers, so far no luck. But the fight isn't over yet... Will keep you posted
  9. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Run the engine thru an MRI.....it will show up.
  10. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Update please on the washer quest?
    ( P.S. MRI super magnets would try to tear every piece of ferrous metal out of the engine)
  11. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    :) I borrowed my buddies scope one last time. Slide it down into the oil p[assage, and like discovering the lost treasure there it was, 1 inch beyond where I had been using the flex magnet. Put the magnet in (almost out of shaft to grab) and there it was, my washer, in my hands once again. Thanks guys for the ideas... This Brotherhood is great
  12. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Congratulations!!!
  13. want2BSchumi
    May 22, 2008
    86
    Los Angeles, CA
    Russell
    Excellent! I suspected you would find it if you looked long enough. I remember that feeling of relief seeing the washer just sitting there, waiting to be plucked out!
  14. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    So everything is back together, just getting ready to start her up this week and I'm double checking my double checks. a question came up. is there supposed to be clearance between the belt and the belt follower? I left it just above the belt, but I watched a video where the ground away the backside of the follower to allow for more clearance, comments?
  15. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    #40 dkny, Jun 18, 2013
    Finally back together, fired her up for the first time. After sorting out a few minor issues I think we're done. The sound at idle is completely different, we removed all of the emission, not sure if that would make a noticable change of if its just the computer relearning.
  16. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    About the thickness of a matchbook cover clearance.
