Thanks! I just want to add that the guy who makes these kits (George from Dr S / Cambio Manuale) has been amazingly helpful and responsive. He is sending me a heat shield for the clutch line that has been added to the later kits
Next step: Installing the pedals. I was dreading this as I never liked working under the dash of cars with the limited space and awkward positions you have to contort yourself into. I also realized that if the pivot rod was this difficult to remove it would be harder to install correctly. Here we were, the rod slides in the left bushing fine, but it will not go into the right one without a LOT of force. It feels like the bushing is machined too small or the line boring that drilled the part was off and the rod is cocked slightly causing it to bind. Image Unavailable, Please Login The first thing I tried was to clean up the bushing with scotch brite and sand paper but that was getting me nowhere. Even with a screw in the clutch switch hole and some pliers twisting the rod back and forth, I could NOT get the rod into the bushing more than a mm. I realized I'd have to just press the rod in from the left side. To do that I had to bust out the welder and modify my ghetto press tool to work better. So I greased up and set up the pedals and clutch switch bracket and spacer bushings. Image Unavailable, Please Login Image Unavailable, Please Login I welded up the tool to not be so janky, and cut down the sides to fit in the tight space better. Image Unavailable, Please Login One of the keys is to line up the set screw hole before you start pressing the rod in because once it is in there, it is NOT budging a bit to line to hole up if it's off. I realize this is probably just my car being stupid and not by design, but it is annoying as ****. So I lined it up as good as i could and hoped for the best Image Unavailable, Please Login Image Unavailable, Please Login It lined up almost perfect, and I got the clutch bracket installed with the set screw, but the main pivot shaft set screw was just a hair off. The screw would not start no matter what. And I couldn't move the shaft at this point because the clutch switch bracket was holding it laterally in place. Ferrari should have made this set screw hole a mm larger. Anyhow to get around this I ground a screw to a point to better align in the hole and then filed the threads down slightly, NPT-style lol I knew this was not a perfect solution as it would bind up as it threaded in, but once it's in there it will hold the rod solid if the insanely tight interference fit ever gave up for some reason. I loctited the threads just in case. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login And viola! 6 hours later, I have 3 pedals! Just need to hook up the master cylinders and set the travel tomorrow and I will be done under there.
Oh I also had a local shop (RPM muffler Oceanside) weld up the cracks in the Tubi exhaust and add reinforcement brackets. $150, not bad. Image Unavailable, Please Login Image Unavailable, Please Login Wish I could TIG like that! Image Unavailable, Please Login Can't wait to drive this thing again!!
Did a lot of the simple stuff yesterday, removed the TCU, installed jumper to bypass it, removed flappy paddles, etc Then last I had to finish the cables and the clutch line. Image Unavailable, Please Login Feeding the cables through the bulkhead is a huge pain. My friend came over and helped, but they still wouldn't go, and I was tearing up the protective boots trying to jam them through. To make it easy I got out a small round file and ground a few mm in the side of the hole for a spot for the first cable to rest in and give the 2nd cable metal end enough room to slide through. It felt bad filing on the car, but it was ~1mm and it worked great. It will also still be totally sealed by the cable grommet. Image Unavailable, Please Login Ran the line clutch line as well through the center tunnel. I found drilling holes for it's own support worked best and was pretty easy and looks factory and clean. Image Unavailable, Please Login Also ran the shifter cables Image Unavailable, Please Login Image Unavailable, Please Login My friend helped adjust the 2 cables. It's a pretty big pain, and I have no idea how it will actually drive. I feel like after the car is running it will take a lot of fiddling to make it shift perfect. At least it looks cool Image Unavailable, Please Login One thing went super easy and took a lot less effort than I thought it would. Bleeding the clutch was super simple. Used Pentosin CHF11S and hooked this vacuum bleeder up to the clutch bleed. It uses compressed air to run a vacuum and it's super easy to use and well made. Best $40 ever spent. It sucked all of the air out and fresh fluid through in about 90 seconds. WOW. So much easier than pumping for an hour. I just used a bit of teflon tape to seal the bleeder threads so the vacuum would pull perfect. I wish I had bought this tool years ago. Image Unavailable, Please Login I'm just about ready to put everything back together and test it out! Just need to 1. Get the ECU flasher tool in the mail 2. Flash the cluster to manual. 3. Put the exhaust back 4. Fabricate a brackets for the F1 heat shield to cover the new manual shifter stuff 4.5. Install new lower gearbox mount bushing I just got 5. Oil+Filter change 6. Coolant fill and bleed 7. Reinstall interior 8. Put bodywork and engine panels in Hobbes wants a ride when it's put back together.. Image Unavailable, Please Login
Good work. Installing the pedals is an awful experience. LOL. You’ll want to adjust its travel once you can drive the car. Don’t set anything tight yet. If you think running the cables is hard, just wait until to try and install the rubber boot that those cables go through. Unless you already have of course. How awful! Why did you have to drill a hole for the clutch line? The clutch hardline should just fit in the factory clutch hardline hole. It’s there near the top. Huge pain. Is teflon tape recommended on the bleeder valve? I would think you don’t want teflon tape on those threads and there is no reason for it anyways. I could be wrong though. More asking. You will need to adjust the cables once you can drive the car. My recommendation is get it roughly where you need. Especially front and back travel distance. That’s the easy one. Then have it parked and in 3rd gear and go to the back and adjust it right to the middle in that gear. Makes it perfect. Took me like freaking 20 hours until I found out I could just do that and it was perfect. There is no heat shield over the manual actuator. Just store your F1 actuator heat shield away for safe keeping. Enjoy!
@collegeboy Thanks for all the useful advice! Luckily the boot came on the cables and with my friend, the boot went it fairly easily. I was very surprised. Re: clutch line hole, I didnt even see the hole in the top rubber, I looked and I see it now and yes that would be a pain. I'm kind glad I drilled the holes in the bottom rubber Re: Teflon tape, I don't normally use teflon tape, but I just used a small amount at the top of the threads away from the fluid and bleeder sealing surface. The idea is to not suck air through the bleeder threads when I put a lot of vacuum on it and it works well. As long as you are careful with it and it doesn't get in the system it's not goign to hurt anything. So I adjusted the cables to the middle of 3rd geat like you say, but you're saying after I drive it, everything will move around and settle, and I'll have to re-adjust back to the middle of 3rd? I put the heat shield back on over the manual actuator just to keep cat heat away from everything. I don't think it could hurt anything right?
I've gotten a lot of stuff done the last few days and I'm starting to button everything up. I ziptied the F1 electricals out of the way. There's no way to easily remove them from the harness so I just hide them away. Image Unavailable, Please Login Added some gold heatshield to the homemade shield above the right side exhaust. The car was missing this shield when I got it. I'll make a matching one for the drivers side eventually. Image Unavailable, Please Login You can see the differences in the shields here: I Iike my more robust metal one better Image Unavailable, Please Login The old lower gearbox mount. I'm sure it's original but they both look fine. The mount in the dogbone and the mount in the trans. Oh well I have a new dogbone mount so I'll replace it. Image Unavailable, Please Login The aluminum in the mounting ears looks terrible though. That's because of the horrible OE mounting system. Luckily Ferrari upgraded later and I have the upgraded parts. Image Unavailable, Please Login You can see the old style on the right, it's just a sleeve that get torqued between the ears with a small surface area and eats them up. . The new style on the left is 2 sleeves with flanges to distribute the load on the soft aluminum. however.... Image Unavailable, Please Login It is too wide for my early style mounting ears. Image Unavailable, Please Login So I grinded one of the ears down until it fit perfect Image Unavailable, Please Login Old sleeve fits: Image Unavailable, Please Login Now new sleeves do too: Image Unavailable, Please Login Then I press out old rubber bushing, easy stuff Image Unavailable, Please Login And press in the new one and install it! (sorry no pic of that) Image Unavailable, Please Login So with all that and tons more little things done I'm here: 1. Get the ECU flasher tool in the mail 2. Flash the cluster to manual. 3. DONE Put the exhaust back 4. DONE Fabricate a brackets for the F1 heat shield to cover the new manual shifter stuff 4.5. DONE Install new lower gearbox mount bushing I just got 5. Oil+Filter change 6. Coolant fill and bleed 7. Reinstall interior 8. Put bodywork and engine panels in This weekend I'm going to a trackday at Buttonwillow though so will be doing less Ferrari work.
Nice. Perfect. That should get you a great start with the shifter cables. Just drive it, pay attention if anything looks off or feels off, and then crawl under and double check/adjust. When you drive it things might be different. That's all I mean. But if when you shift from 3rd to 4th the shifter shaft is the same distance from the front when in 3rd and from the back when it's in 4th, then it's centered front to back when parked. If then when it is in 3rd or 4th, adjust the cable to the extreme right to where it just touches the shifter gate half a turn at a time. Then adjust it to the extreme left where it just touches the shifter gate half a turn at a time. Then it's centered right and left when parked. That's a VERY good start and may be all you need. Then drive and just see how it goes. It does sit slightly different when gears are actually turning, so just tweak accordingly, and be sure to keep track of how many half turns you adjust from your center F-B and center R-L. It shouldn't be much. Nah, the shield won't hurt anything. It's just not needed, so I'd say remove it to help unclutter things. But either doesn't matter.
Thanks for the comments and help! The conversion work is complete except the ECU and dash computer flashing. I ran into issues, probably because my ECUs are super early and weird is my guess. We're troubleshooting it now. In the meantime I've been working on slowly putting everything else back together. I'm taking my time, cleaning everything, properly zip-tying wires and hoses up, fabricating bits needed where stuff had been broken or neglected. I did an oil change as it's been 2800 miles and 2.5 years since the PO had a shop change the oil. Image Unavailable, Please Login At first I thought the drainplug had a magnet, but it's this wierd rubber thing. Any idea why this is like this? Image Unavailable, Please Login Oil pickup screen had a few tiny bits of metal, but nothing alarming. I used compressed air and tweezers to clean it out. No brake cleaner as it's plastic and has o-rings and I didn't want the brake cleaner to damage either Image Unavailable, Please Login ahhh better Image Unavailable, Please Login Tried to change the filter, and none of my oil filter strap wrenches were big enough, so I went to buy the real oil filter tool. Hill engineering has a beefy oil filter wrench for like $100 after tax+shipping. I didn't want to pay $100 for an simple filter tool so I found this one on Ebay for $40 Image Unavailable, Please Login That shop that did the oil last must've used an impact to tighten the damn filter because trying to remove it just started to damage the tool! The filter still wasn't budging. Image Unavailable, Please Login Image Unavailable, Please Login So I busted out the big guns... Image Unavailable, Please Login Welded an old socket to the tool, and success! It seriously took about 60 ft-lbs on my 1/2 inch breaker bar to get the old filter off. Image Unavailable, Please Login Image Unavailable, Please Login For the new filter, I lubed up the o-ring and torqued it to 25 Nm Image Unavailable, Please Login Then I started assembling the rest of everything, cleaning it up all nice first. Image Unavailable, Please Login Image Unavailable, Please Login I'll pick up the repaired and re-painted rear bumper tomorrow, install that and then we're getting really close! Last weekend went to the Petersen Auto Museum in LA and did the "Vault tour", highly recommened! Right now they have the first Ferrari ever made down there Image Unavailable, Please Login If you made it this far, Hobbes says hi Image Unavailable, Please Login
I want to replace the airbox mounts--the rubber isolators, because mine are starting to shift and crack and fail. They are part #142202 and the cheapest I can find is $15 each! And the airbox needs 6. Hmm not really looking to spend $100+ on this after tax and shipping so I looked on Mcmaster carr and found identical size mounts for $4 each https://www.mcmaster.com/9225K65/ I ordered 6 and it's $35 to my door. They dont look as nice without the metal end caps, but I am sure they will work just fine. I researched the neoprene material properties and it should be fine in the engine bay environment. I bet they last longer with the beefier rubber section too Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Image Unavailable, Please Login Image Unavailable, Please Login I love how fast mcmaster carr is, 8 hours to my doorstep These look absolutely perfect
While I had the bumper off I decided it was time to get it fixed. There was a previous repair done very poorly and the idiots who did the work declined to reinstall the stock heatshielding on the diffusor part of the bump that's right next to the cat. So over time of course the paint blistered and cracked and was damaged. I decided to take it to the local high-end body shop and have them repaint it and also repair the damaged fiberglass itself so it's done right. It was $2k uughhhhh I could've done it myself, but I really didn't want to work with fiberglass for a whole weekend. Image Unavailable, Please Login Image Unavailable, Please Login Missing heatshielding.. Image Unavailable, Please Login Repaired and repainted Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login I fabricated new shielding from Thermotec bulk stick-on shielding. Image Unavailable, Please Login Image Unavailable, Please Login I made a few layers where it is closest to the exhaust for extra protection. Image Unavailable, Please Login Image Unavailable, Please Login Reinstalled and looking great! Image Unavailable, Please Login Then I refilled the cooling system with the Airlift bleed kit. I was skeptical, but it worked AMAZING. It sucked in all of the coolant and hopefully there are no air pockets or bubbles in the system. I'll probably end up cracking the bleeder once the car starts just to verify that it worked. Image Unavailable, Please Login I used the Airlift bleeder/filler tool that this guy uses
Sunday I was just putting everything back together. It's a slow process, cleaning every part, replacing missing and mismatched hardware, ziptieing everything lose, fabricating little brackets and such. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login I did all that Sunday, then today finished the ECU stuff, and started it up. Started right up and ran perfect Oil level was good, coolant was perfect and didn't leak, thermostat is now working properly, etc Drove it around the block and it shifts like butter, perfect through all 6 gears The clutch doesn't have great feel, but that's pretty normal for a hydraulic clutch in my experience. It felt great to drive around and double clutch and rev match and everything I've been missing, this is what a Ferrari should be It's pretty loud and hot driving it with the engine going a foot behind you and no cover or anything!
Congratulation on the completion! And amazing job fixing all the other stuff along the way! "Last weekend went to the Petersen Auto Museum in LA and did the "Vault tour", highly recommened! Right now they have the first Ferrari ever made down there" Is it the real one? Value is estimated to be 100 million dollars if it was to be auctioned (the most expensive car in the world) so it's amazing that it's just parked there without any barriers and with people walking around (and hopefully not taking out some chrome piece as a souvenir
