DIY: Best and easiest way to clean your engine | FerrariChat
Discussion in '360/430' started by whatheheck, Apr 29, 2018.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    The usual disclaimer:
    Im posting for sharing knowledge and experience. Im not here to debate or argue with anyone.
    Just like anything in life, individual results may vary and you do this at your own risk.
    Here you go for sharing:
    Don’t use Gunk engine cleaner. I hate the residual petroleum smell that stays on the car for weeks. It stinks!
    Never pressure wash or steam clean your engine as water / moisture can get inside the electrical connections and can short out electrical connections or promote corrosion.
    So, here you go, the best engine cleaner in my opinion, and its soooooo easy to do. Takes 10 minutes with very little effort.
    No foul smell, very friendly to the engine, works great on rubber hoses, plastic, great on aluminum, works quick and does a fantastic job.
    Scrubbing bubbles! I have used this stuff many times in all my cars and it works great! I urge you to try and post results.
    Steps:
    Spray on directly to a cool engine, let it soak for about 5 minutes, then hose the engine off with stream of water from the top going down.
    Important: Once you have rinsed the engine wipe down side panels, muffler, etc. to prevent water spots / water stains.
    Start the engine, let it warm up to dry.
    Once water disappears check out your engine and your entire engine bay. It should be so clean like it just came off the show room floor.
    Let me know how it works for you. Oh, get the lemon scented version. It smells better.
    You can find Scrubbing Bubbles at Costco and other grocery stores for about 3 bucks a can.
    BTW, If you want a little bit of shine, not shiny or greasy look at all, my favorite engine bay dressing is Griots Garage engine bay dressing.
    Spray engine bay dressing from the top on a cool engine, then wipe down all areas with microfiber cloth.
    I tell you, cleaning engine from here on cant be any easier. People will admire how clean your engine is and I don’t know of any car fan or mechanic that doesn’t like to work on or see clean engines.
    Another note: The photos & short video below I took right after cleaning with scrubbing bubbles. I have not had the opportunity to apply Griots Garage Engine Bay Dressing.
    Hope that helps.
    Photos below:
    Dan / whatheheck
    RayJohns, Daryl Zernick, Cyt and 3 others like this.
  2. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  3. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    nice very clean
    whatheheck likes this.
  4. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks!
    Here's a short 1 minute video.
    Dan
  5. Raconteur
    Raconteur F1 Rookie
    4,272
    Portlandia, OR
    Frank
    Thanks, Dan! I was planning to do a complete detail in the next couple of weeks with drier weather now here in the northwest. Very helpful advice.
  6. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You're welcome Frank!
    Kindly share before and after photos if you can.
    Dan
  7. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    Dan that looks awesome I will give it a try.
    By the way the scrubbing bubbles take care of the streaks on the black side panels too??
  8. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks.
    The streaks on the side panels are caused by water droplets that dried out due to intense engine heat.
    They can only be removed by paint polish, then application of paint sealant to prevent reoccurrence.
    Sent from my SM-G955U using Tapatalk
  9. Flyingbrick242
    Flyingbrick242 Formula Junior
    693
    Northern AZ.
    Hi Dan,
    That looks showroom new..
    Thanks for sharing this helpful insight.
    K//
  10. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
    How does it work on brake calipers and rims
    Sent from my SM-T580 using Tapatalk
  11. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Sorry I dont know as I've never tried them on rims and brake calipers.
  12. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thank you!
    I've been using this method on all my cars and everyone that sees my engines they all ask How do you get your engine so clean! Must be a lot of work!
    I said actually no, its only Scrubbing Bubbles and Engine Bay Dressing from Griots Garage.
    See below.
  13. LI2782
    LI2782 Formula Junior
    Jul 19, 2010
    917
    Looks good, but your argument against using steam or pressure washing methods kind of gets ruined when you say you rinse this off with a garden hose. Garden hose is actually introducing a much higher volume of water to the engine compartment than a pressure washer or steamer would
  14. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Im not here to argue or debate back & forth but I will go ahead and explain further.
    When you steam clean an engine or jet pressure wash it you will inject water into the connectors and all the other electrical circuits in the engine and engine bay side panels electrical connections. Most electrical connectors in the engine bay are rubber sealed, but if you use a jet pressure washer the high water pressure can penetrate the connectors rubber seals.
    If you use a garden hose without the sprayer and just run a stream of water from above the engine the water will just flow down naturally taking with it dirt, grease and grime scrubbing bubbles removed from the engine.
    So I am not worried about water volume but high water pressure.
    The car is designed to accept water from above and naturally flow down like rainfall.
    I dont think Ferrari ever tested their engine using high pressure washer all over the engine and engine bay as part of their manufacturing process.
    My 2.5 cents as I am no expert.
  15. rennspeed
    rennspeed Formula Junior
    528
    Rennspeed
    wow pretty awesome as usual Dan. QQ when you rinse the engine with water, is it just a trickle or full blast?
  16. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks Phil.
    My technique is to remove the sprayer from the garden hose, then hose the entire engine bay (without the sprayer) using normal full water pressure from house plumbing.
    I've used this technique for over 10 years, shared it my friends and no one has ever had an issue. They are all super happy as it is super easy.
    During last years auto show at my work at Boeing one guy said "Man, you can eat off of that engine, it is so clean". So I shared with him the technique and he sent me a big thank you.
    Here's a photo of my previous 360 Spider after using scrubbing bubbles and applying Griots Garage Engine Bay Dressing.
    killer58, Jackson1019 and rennspeed like this.
  17. Patman
    Patman Karting
    Jul 5, 2014
    80
    Eastvale, CA
    Pat
    Wow that’s beautiful! Will definitely give that a try.
    Been using simple green in a spray bottle on the engine bays of my everyday cars with some moderate success. Will now try your method! Thanks for sharing!
  18. Shinigami
    Shinigami Formula Junior
    Aug 2, 2005
    465
    Gland Switzerland
    Heikki
    So Scrubbing Bubbles is by Johnson&Johnson and marketed as a bathroom cleaner? Can you read out what chemicals are inside, I might be able to find a similar product here in Switzerland.
  19. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    Well I always say no matter how much you have done, you can always learn something new, and I just did. Thanks Dan!
  20. sakodik
    sakodik Karting
    Jun 2, 2016
    169
    Santa Clara
    Dan
    Did you ever need to agitate or scrub after spraying?
  21. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Chemical contents is on SC Johnson website.
    Sorry the chemicals are too long and difficult for me to spell out. I don't know how to copy and paste using my cell phone. My apologies.
  22. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You're welcome! Kindly post photos once you're done so we can see.
  23. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Not on my engine.
    I literally just sprayed it all over the engine, let it soak and let it do its job for 5 - 10 minutes, then hosed it off with water & it came out sparkling clean.
    If your engine has baked on and caked on grease due to oil leaks and lots of dirt and grime you may have to. I don't think any of us have that condition.
    Note: when I first try this method many years ago I wrapped all engine electrical connectors with Saran wrap to protect them from getting wet. A friend said it's not necessary as the engine is designed and built to get wet so it shouldn't harm anything. Just don't pressure wash.
    sakodik likes this.
  24. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
  25. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    But this car in particular is designed and built to get wet because it has open vents, what about the other engines you have cleaned over the years? All engines are designed that way? So it is safe to use this method with all kind of engines?
