DIY: Best and easiest way to clean your engine | Page 4 | FerrariChat
Discussion in '360/430' started by whatheheck, Apr 29, 2018.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Wow, that is super clean!
    If you want a little shine you can apply Griots Garage Engine Bay Dressing.
    Thanks for sharing.
    Dan
  2. KBR54
    KBR54 Karting
    Sep 23, 2017
    154
    Sylvan Lake Alberta Canada
    David Garratt
    whatheheck likes this.
  3. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  4. jcurry
    24,153
    In the past
    Jim
    I tried this on an older vehicle in the wheel well area. It resulted in removal of some paint and other protective finish. I don't plan on using it anywhere else. YMMV.
  5. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks for sharing.
    I've used this method for 10 years on my engine and engine bay and not once I've had paint peel off.
    But then again, I've never used it on wheel well area as I have no reason to keep that area super clean and shiny
    Thanks again for the info.
    I will try the wheel wells on my wife's BMW and see what happens.
    Sent from my SM-G955U using Tapatalk
  6. Dewinator
    Dewinator F1 Veteran
    7,781
    WA
    Could you elaborate? Did you do scrubbing bubbles? Or engine bay dressing? Did you just rinse off or do anything else to it while the product was pn there?
  7. jcurry
    24,153
    In the past
    Jim
    I sprayed Scrubbing Bubbles in wheel well area, including body, suspension linkages, hoses, calipers, etc. Let sit for 4-5 minutes, then rinsed off using very light water pressure. Some paint was removed from body and oil cooler, also some corrosion type finish on suspension components. It was not widespread, just localized in a couple spots.
  8. Dewinator
    7,781
    WA
    Interesting, that’s a bummer but thanks for sharing your experience that there can be some areas where it can cause problems. I didn’t have any problems using it on my engine but I think I’ll avoid using it in the wheel wells and painted areas.
  9. jcurry
    24,153
    In the past
    Jim
    I don't believe the particular area is the issue. Rather age or any deterioration of material. So even in the engine bay if there were any surfaces where a coating is beginning to flake off I would be hesitant to apply any product that would get underneath and tend to 'lift' the coating. I tried it first in the wheel well because 1/it should have benefited in the same manner as an engine bay and 2/it is an area where if something did go wrong it would be less noticeable. I don't know enough about the chemical make-up and how it works to say my issues were strictly due to use of Scrubbing Bubbles. There are a few warnings on the internet regarding use on paint, offset by as many or more opinions on a great outcome. Unfortunately my experience was such to give me pause.
    Bob in Makiki and whatheheck like this.
  10. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  13. f355spider
    f355spider F1 World Champ
    18,056
    #89 f355spider, Jun 3, 2018
    Hi Dan. I did the Scrubbing Bubbles engine clean yesterday and very pleased with the results! I sprayed the entire engine bay, though I tried to avoid the CF bits where I could, for no reason other than I they really didn't require cleaning. I let it dwell for 5 or 6 minutes and hosed it off. I reapplied a couple dirty areas on the lower areas of the transaxle and repeated the process, then wiped down with a towel. The only thing of concern, was I noted the lower portions of the air boxes, which are painted glossy black, seemed to take on a bit of discoloring. The gloss black became milky in spots. Now I cannot say for certain it was not already like that or not. I ended up polishing that area with some paint polish on a cloth and it removed most of it, so not a huge deal, but in the future I will probably avoid spraying that area with the Scrubbing Bubbles. I prefer not to apply any engine gloss or treatments, leaving it alone, and looks great now. Thank you
  14. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  16. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Excellent!
    Thanks for sharing Dave!
    Dan
  17. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    520
    Sweden
    I also have this issue with dirt under the side panels. Anyone ever cleaned this area with water?
  18. 8202632
    8202632 Karting
    Jul 9, 2017
    177
    Memphis, TN
    CDC
    Well. There goes my weekend! Will do the cayenne and Carrera first!!!
  19. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Sounds good. Kindly share before and after photos.
    Here's after photo when I did my BMW M6 Coupe.
    Image Unavailable, Please Login when I
    Dan
    Flea7 likes this.
  20. mnogj
    mnogj Karting
    Jun 17, 2005
    57
    Michael
    Thank you Dan!
    I just bought the Scrubbing Bubbles for my newly acquired F430 which has a very dirty engine compartment.
    I would like to know if you need to cover any electrical connections/wires from the spray and water.
  21. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Hi Michael,
    First, congrats on our F430! An outstanding machine!
    Some people ask me why clean the engines? Well, I say why do we clean our homes?
    Because we like things clean, because the cars we drive and the condition of it is a reflection on us just like how we live in our homes in my opinion.
    Anyway, I've been using the scrubbing bubbles method for over 10 years on my BMW's with zero issues.
    Ferrari may be a different animal, a little finicky so based on my experience with my 360 and F430 and what others have posted here, here are the issues identified.
    Avoid side panels and carbon fiber as you may experience water spots.
    I encountered issues with oil pressure indication so perhaps cover the oil pressure sending unit connector with saran wrap.
    I had some issues with variator control solenoid valves so perhaps cover those connectors as well.
    You can find those parts & its location at Ricambi or Workshop Manual.
    I am not aware of any other issues identified by anyone except the above.
    So I say just follow the procedures I identified on post number 1 and what others here have suggested.
    And kindly share before and after photos.
    Hope that helps.
    Dan
  22. 8202632
    8202632 Karting
    Jul 9, 2017
    177
    Memphis, TN
    CDC
  23. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    919
    TX
    HOLY! My cayenne turbo hasn't looked anywhere as clean as this in a LOONNNGGG time!
    8202632 and whatheheck like this.
  24. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Damn, that looks better than new!
    Thanks for sharing photo.
    Dan
    8202632 likes this.
