DIY: Best and easiest way to clean your engine | Page 5 | FerrariChat
Discussion in '360/430' started by whatheheck, Apr 29, 2018.
  1. jcurry
    jcurry Two Time F1 World Champ Silver Subscribed
    Jan 16, 2012
    24,026
    In the past
    Jim
    The above post got me to take another look at the areas where I had previously said paint had been removed. Turns out I was wrong and just experienced the same, but very heavy, milky residue. As mine had dried it took a bit of effort to remove, but did get most of it. Possibly I did not thoroughly rinse, although both regions in questions were vertical surfaces. Could be there was excess dirt that the SB's did not fully loosen and the stuff sort of soaked into the dirt and thus did not rinse out completely. Something to watch for.
    So, I'll retract my comments about paint removal, and apologies to Dan and anyone else if I caused any alarm or hesitation on having used the product.
    Will try again on some vehicles that are less, um, nice.
  2. Dewinator
    Dewinator F1 Veteran Silver Subscribed
    Jun 22, 2017
    7,576
    WA
  3. whatheheck
    whatheheck F1 Rookie Owner
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks for sharing info Jim.
    No apologies needed.
    Dan
  4. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Wow! Super clean!
    Thanks for sharing photo.
    Dan
  5. Dewinator
    Jun 22, 2017
    7,576
    WA
    Thanks! My second application of scrubbing bubbles, first application of Griot’s Engine Bay Dressing. I did plastic over the oil pressure sensor and cam solenoids this time just for caution!
  6. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Good for you! Better safe than sorry.
    My oil pressure sensor started malfunctioning and its still unreliable / intermittent so I will replace it soon.
    I dont know if its because it got wet or its simply reached the end of its life as my car is a 2006 so its 12 years old.
    It also threw some codes & idled a little rough (I have a post here somewhere) and threw a CEL so I cleaned the variator control valve solenoid connectors with contact cleaner and let it completely dry.
    Did an engine reset and CEL is now gone and car is back running with no idle issues.
    I plan to replace the variator control valve solenoids sometime soon just as preventive treatment as they are known to go bad after around 30K miles or 10 years.
    At least that's what I read here.
  7. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
  8. Dewinator
    Jun 22, 2017
    7,576
    WA
    Is that TDF??? AWE SOME
  9. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    Yes sir!!! My fave color by far on a 360 or almost any model!
    Cheers!!
  10. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
  11. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  12. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  13. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    Thanks...couldn't get Enzo to look in the camera that day! Shy I guess!
  14. mnogj
    mnogj Karting
    Jun 17, 2005
    55
    Michael
    Dan,
    Thank you for the advise. Tried looking up where the oil pressure sending unit and variation control solenoid valves are but no luck.
    Can you post a pic and circle which items should be wrapped for a newbie .
    Will post before and after pics.
    Thanks in advance!
  15. sakodik
    sakodik Karting
    Jun 2, 2016
    169
    Santa Clara
    Dan
    whatheheck and mnogj like this.
  16. mnogj
    mnogj Karting
    Jun 17, 2005
    55
    Michael
    Thank you for the pics!
    Appreciate it!
  17. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks Dan for sharing photos of F430 Oil Sending Unit location.
    Michael, here are the locations of variator solenoid control valves.
    Based on our experience these may be sensitive to liquids including the connectors so if you plan on cleaning your engine I highly recommend you cover the ones circled and arrow pointed (variator connectors) issues.
    Hope that helps.
    Dan
    Photo courtesy of member Mark Stewart.
    Image Unavailable, Please Login just to play it safe and avoid possible
    mnogj likes this.
  18. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,943
    Melbourne Florida
    KGC
    Thanks for the tip. It works good. Didn't see a big difference but I have a pretty clean engine compartment.
    Two things:
    It did turn my air boxes a powdery gray. Solved it with an application of WD40 and wiped down. WD40 applied and wiped down works good on all parts. I've done that for years on my cars to "wet out" the black plastic and metal parts-- even hoses. Gives a nice look without that slimy Armour-All look.
    I did get some water spots but was able to wipe the side panels and such with a damp cloth and they were gone. So I suppose it would be a good idea to dry the panels with a towel.
    I can see where it would be a good way to go on the suspension parts, inner wheels for brake dust, and other undercarriage parts. Going to give it a try there.
    whatheheck likes this.
  19. 550nitis
    550nitis Formula Junior Silver Subscribed
    Feb 3, 2016
    759
    Houston
    Great post, very informative!
  20. craigburton
    craigburton Karting
    Aug 27, 2016
    60
    Very nice post and thanks for the info Dan. Can anyone tell me what the UK equivalent of scrubbing bubbles is?
  21. Dewinator
    Jun 22, 2017
    7,576
    WA
    Hehe is there a “Sowrry! We’ll scrub while you have tea and crumpets then guvnor!” product over there? :)
    obertRo likes this.
  22. phil the brit
    phil the brit Formula 3
    Jul 7, 2013
    1,215
    Colchester+Clermont
    Phil Taylor
    It can be bought in UK from Amazon
  23. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Sorry I dont know the answer to that question.
    Hopefully someone here from the UK will chime in.
    Dan
  24. Dewinator
    Jun 22, 2017
    7,576
    WA
    Good point I just got mine from Amazon anyway, like most everything else.
  25. Flyingbrick242
    Flyingbrick242 Formula Junior Silver Subscribed
    Feb 26, 2017
    673
    Northern AZ.
    Red 27 and whatheheck like this.
