DIY: Best and easiest way to clean your engine | Page 7 | FerrariChat
Discussion in '360/430' started by whatheheck, Apr 29, 2018.
  1. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    To make a Scubbing bubbles even more effective buy garden spraying and a couple gallons of distilled water and a disposable paint brush for a super deep clean and no water spots, you would be surprised at how much minerals are in regular water and work its way down in nook and cranny's minerals are deposited , and you do not even have to dry off the water distilled has no minerals no spots . Wend using a garden sprayer has very little water pressure so want do not worry so much about over rinsing and getting in to the electrical system. Another must have tool air compressor is fanatic for blowing out dust from hard to reach places. I have never use regular water hose on my 360 just blow off every thing with compressed air and spray wipe. I would like to take credit for all this stuff but I can not, I learn this from other OSD car nuts and mechanics this is there old tricks for detailing and long use and care
    obertRo, sampelligrino and whatheheck like this.
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    This with no wax or engine dressing
    sampelligrino likes this.
  3. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    $100.00 a can? Yikes! It's $12.00 at Costco for a pack of 4.
    You're welcome.
    Dan
    JonM likes this.
  4. cole328
    cole328 Formula Junior
    May 9, 2014
    882
    So seriously,,... the scrubbing bubbles doesn’t degrade any of the wiring? If not, the looks are simply incredible. Dans the man
    whatheheck likes this.
  5. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    ******** . Is there any way to restore or clean the red covers without a spray paint job ?
    Mine have faded into oblivion
  6. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    It depends on how bad it is.
    Kindly post pictures.
    _JERRY_ likes this.
  7. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    Any cleaning solution i use seems to just take off more of the color
  8. GSF355
    GSF355 Karting
    55
    Brisbane
    Have you tried Costco?... I'll go there in the next couple of weeks and have a look and will post back here with my findings.
  9. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    @Jerry:
    Thanks for posting photo.
    Wow, 1st just want to say it got that bad simply due to years and years of neglect................
    2nd and before I forget, your power steering cap is seeping oil. Replace that ASAP to keep your engine clean. No need to buy Ferrari Power Steering Cap. They are outrageously expensive. Our power steering cap is the same as what they use on BMW's. BMW power steering caps are much much cheaper without the Ferrari Tax. I have a post on that subject here somewhere. Kindly do a search and replace that cap ASAP to keep your engine bay clean.
    3rd: Follow my procedures and clean your engine bay with scrubbing bubbles and it will be super clean. You will be amazed as your engine bay will look brand new.
    Now back to your question: You can probably polish that by following the same technique as detailing car paint. But I doubt it will look as good as new.....
    That may need to be repainted. And it shouldnt be that expensive. Just find a reputable local paint shop close to you.
    Hope that helps.
    Dan
    _JERRY_ likes this.
  10. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    Dang ok man , muchos gracias. The power steering cap is the black cap ya? With the rubber housing ?
    When you say scrubbing bubbles , you’re referring to the toilet foam/gel cleaner right ?
  11. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Yes there is.
    Go and buy Mequires Hot Tire Shine. It is around 90% silicone.
    https://www.amazon.com/Meguiars-Shine-High-Gloss-Spray/dp/B0009IQXXG/ref=sr_1_3?keywords=meguiars+hot+tire+shine&qid=1558788429&s=gateway&sr=8-3-spell
    Using a stencil brush (what I use)
    https://www.amazon.com/FolkArt-50614E-Stencil-Original-Version/dp/B01LSY3J68/ref=sr_1_15?keywords=art+stencil+brush&qid=1558788615&s=gateway&sr=8-15
    work it into your surface, don't spray it on. Let is set for a few minutes then wipe off with a MF towel. Works excellent on faded black items as well. By wiping it off you lose the gloss. Also this stuff once dry does not wipe off or rinse off with water. Additionally by wiping it off, much like the Groits, it will be a satin finish. Again do not spray it.
    You will be amazed.
    _JERRY_ likes this.
  12. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    Danke! Will try this for sure. Should I try this first or the scrubbing bubbles clean?
  13. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    I would make sure it's clean, so yes.
  14. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    Sadly scrubbing bubbles isnt readily available where i'm from. Would make it quite costly to ship it over :(.
    This will probably be off-topic, but have you tried "Simple Green" products?
    and/or is there a secondary viable alternative?
    Need to find something available locally, otherwise the shipping might cost more than the product itself.
    Cheers!
  15. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    I use simple green pro HD cleaner and degreaser (diluted). Works great. We have scrubbing bubbles in our house but I haven’t tried it on my car. It’s great on toilets though lol
    Whatever you use, you will have to use something after to bring back the shine/colour. I use Gunk engine detailer. Really shiny.
    I suppose armour all would work too if you have some lying around,
    _JERRY_ likes this.
  16. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    Have u tried without dilution ?
  17. I'm 360 Canuck
    Nov 21, 2015
    1,911
    Lars!
    The one I use is meant to be diluted, as a concentration.
    Haven’t found the need to use full strength.
    _JERRY_ likes this.
  18. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Yes and Yes.
    The power steering cap is the black one. Always refer to your Owners Manual. Read it front to back often so you get to enjoy your nice car to its fullest.
    And yes, Scrubbing Bubbles bathroom cleaner. I used it again on my F430 Engine today and it looks awesome.
    Dan
    _JERRY_ likes this.
  19. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    #170 _JERRY_, May 28, 2019
    Can’t get hold of scrubbing bubbles locally , sadly . Have opted for simple green extreme Motorsports degreaser and finish with armor all silicon tire foam, will feedback here if it’s remotely decent heh.
    If anyone has tried either and had bad results , feel free to give me a heads up.
    Thanks guys !
    (NB: just trying to follow the same concept as suggested here , with whatever I can get my hands on locally.)
    I'm 360 Canuck likes this.
  20. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    I'm back with some updates on having tried my modified version using the same concept as the OP.
    Using "Simple Green extreme Motorsports degreaser" in place of "Scrubbing bubbles" and then finishing up with "Armor All detailer's advantage tire foam".
    BEFORE:
    AFTER:
    Was pleasantly surprised by the results.Decently successful i think. Many thanks to the guys who gave me the ideas here. Glad i didnt have to do a re-spray. Happy "Ferrari-ing" !
  21. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Looks really good!
    Great job!
    Dan
    _JERRY_ likes this.
  22. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    All thanks to you for starting the idea buddy. [emoji23][emoji1303]
    “Sharing is Caring...”
  23. GSF355
    GSF355 Karting
    55
    Brisbane
    No joy at Costco Brisbane....
  24. Buzios
    Buzios Karting
    Aug 5, 2018
    56
    Did anyone end up trying scrubbing bubbles on other parts (e.g. calipers)?
