DIY Brake Pad Change Scuderia Spider | FerrariChat
Discussion in '360/430' started by Teachdocs, Jul 16, 2013.
  1. Teachdocs
    Teachdocs Formula Junior
    Sep 3, 2012
    568
    Kansas City area
    Chad
    I could not find much info on changing brake pads on a Scud so I made one myself.
    This simple video shows the right front pad swap.
    The rears are similar, but there is no cross bolt to remove as they are only 4 piston calipers.
    I changed the OEM Pagid pads for the new Pagid RSC1 pads.
    Trying to save the CCM rotors a bit with these new pads while at the track.
    Will likely swap back to OEM pads for street use.
    Scuderia 16M Front Brake Pad Change
    Comments and suggestions are welcomed!
  2. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    What did you do, mount a gopro to your face?? :)
    I've owned my 360 for less than a year, and I hate the brembo pins... not that they are a problem, I just think there are different systems out there that are better suited to frequent pad changes.
  3. jrodrig688
    jrodrig688 Formula Junior
    Dec 3, 2012
    397
    FL
    Jose Rodriguez
    Excellent. Quick swap.
  4. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    I put a Like comment on the Video (Melo user id is me). Did you record a disc thickness so you can compare how much better these Pagid pads are then the original pads on the discs?
  5. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
    Eye of Mine HD video glasses. You just wear them like regular glasses and record.
    Took longer to remove and install the wheels than it does to swap pads.
    How many pad change will the pins sustain before they need to be replaced?
    Easy and quick.
    Yes, recorded both. OEM pads have lost 0.7 mm in 4200 miles (garage queen til 2000 miles, then spirited street and one track day). Rotor thickness is unchanged from factory new specs.
  6. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
  7. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    I don't know about the pins... I've done maybe 10 pad swaps and they were still fine. I assume yours are the same just bigger. I couldn't easily find replacement pins alone.. But they were still doing their job keeping things in place. I really like the bridge system on the stoptechs that I have in front now...
  8. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    It struck me as the pads were coming off that they had loads of "meat" on them. Why change with so little wear?
  9. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Because they are supposed to be more gentle on the expensive rotors especially if you drive the car at the track.
    My part 2 question is why swap the back for the street? I know some people do that with performance pads on steel rotors but I thought that was mostly due to the squeaking. I don't switch my track pads back to streets between track events on my track Porsche car. But I don't drive the track focused Porsche car on the street very much.
  10. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
    Changing out OEM street pads for pads better suited to track. I am going with the new Pagid RSC1 pads as they are supposed to be similar to RS19's but a bit less wear on the CCM rotors.
    Will likely swap back to OEM pads after the track event.
    Also something to keep in mind.....never go more than 50% wear with the CCM setup. That is apparently very destructive to the rotors.
  11. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    ^Good points thanks! I guess I was typing my response at the same time as you :)
  12. cjpatel
    cjpatel Formula Junior Silver Subscribed
    Nov 18, 2012
    317
    NYC
    I've got the CCM's as well, were the 4k track or street?
  13. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
    Most of 4K miles on the street. Only 1 track day on the OEM pads consisting of 5 separate 20 minute runs with cool down between.
  14. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Gotcha! (and sorry, should have read your first post - must have just dived into the video :) )
  15. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Thanks for sharing. FWIW, I use a brass head hammer instead of a steel one for the pins, as well as a brass punch. There is also a two-paddle tool for spreading the pads/pistons that works better than the single paddle one used in the video.
  16. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    Contact MArtin at Girodisc, big supporter of 360/F430 brakes and owner of GiroDisc in Washington State.
    He has the best pad spreader in business, I use it all the time.
  17. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Yes, no doubt the best, and really quick. But it's $225!
  18. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Good tip! A tad pricey but if it helps keep you from damaging the brakes its well worth its price.
  19. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
    Can never have enough cool tools. Going to order one of these today.
  20. E60 M5
    E60 M5 Moderator Moderator Owner
    Jan 2, 2006
    8,165
    Wash DC area
    Robert
    Thread added to DIY under Scud/16m section.
    Great stuff, thanks for sharing!!
  21. Teachdocs
    Sep 3, 2012
    568
    Kansas City area
    Chad
  22. V8Fun
    V8Fun Karting
    Aug 16, 2010
    135
    Chicago West Suburbs
    Sorry if these are newb questions, I have an F430 w/CCM's and I'm considering installing the same pads (Pagid RSC1) as my OEM pads are toast (19k miles, 7 track days being gentle with them). I've never swapped pads myself before, but after seeing friends swap pads at the track on other cars, and watching this video, I'm considering it.
    My question are:
    1. Will any standard brake cleaner work without fear of ruining the CCM rotors? I've always heard not to get anything on them, even if it says it is safe for steel rotors.
    2. Did you open the brake fluid resivoir before spreading the pads? If so, any concern about it overflowing?
    Anything else that may have been assumed that the video didn't cover that a total newb might need to know?
    Thanks!
  23. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Can't help with No.1 but if in doubt don't use the cleaner product. Maybe just wipe down the calipers and don't touch the discs unless someone can actually recommend it.
    No.2 - unless you've topped up the reservoir while the pads have slowly worn out then the fluid level should only go back to standard and only then if you change all the pads to new. I generally change one at a time and then pump the pads back into contact with the discs before I move on to the next one. This minimises the risk of overflow.
    Changing pads is easily done (particularly with the video in this thread) and satisfying to do yourself as you can detail the wheels and inspect the tyres thoroughly as you go.
  24. V8Fun
    V8Fun Karting
    Aug 16, 2010
    135
    Thanks for the reply.
    The pads have worn over time (3 years) and I've had the brake fluid flushed each spring, so I'm thinking I will need to be very cautious not to overflow the reservoir. I may need to take some fluid out. I like the idea of doing one at a time and pumping the pads back into contact with the disks each time to minimize the chances of overflow, thanks for the suggestion!
    Anyone else know about the brake cleaner spray and CCM rotors? The video clearly shows this being done, looks like a standard brake cleaner spray. I could skip this part, but if it is safe I would love to get things really cleaned up.
  25. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    For some reason on my Safari browser the video skips from around 12 seconds (as you are talking about the size of the socket) right to the end.
    Hmm
    Alan
