News
DIY Changing Air Filters in the California
Discussion in 'California/Portofino/Roma' started by Bill Phillips, Apr 14, 2021.
  1. Bill Phillips
    Bill Phillips Karting
    212
    New Orleans
    Bill
    I decided to replace the factory air filters in my 2013 Cali-30 with a high performance set from BMC. Looking at the procedure in the workshop manual it seemed pretty simple and straightforward, and while it’s not as simple as unscrewing the wing nut on top of the carburetor on a ‘65 Corvette, it just takes a little longer and is easy enough for anybody. Here’s a step-by-step run through with pictures.
    Remove the right, left and then the front engine compartment cosmetic shields, in that order (workshop manual p. 905) by unscrewing the hex screws located around the perimeter. Five on the right and left and six in front. One screw on each side goes through both the side panel and the front. The side panels pull forward and up, the only minor snag being the windshield washer filler pipe on the drivers side.
    All three shields removed.
    Remove the six screws holding the air boxes, three in front and three in back of each.
    Loosen the two large diameter hose clamps at the front of each intake. If they are the crimp type you can pry the crimp open about 1/4” with a flat blade screwdriver. Lift each air box cover up and pull it forward to remove it.
    If you thought your engine compartment was really clean, think again. You just couldn’t see the grunge under the cosmetic shields. :( I took this opportunity to clean everything while the shields were out. :)
    My filter has slightly different components than what is shown in the workshop manual and the exploded parts diagram at Scuderia Parts. Those two show a second, thin filter and a thin bracket on top of the main filter, all three of which lift out after the air box top is removed. Mine has a thicker pre-filter for leaves and bugs strapped to the bottom of the main filter. Obviously Ferrari changed the design somewhere along the line. Here’s my original filter, upside down.
    New BMC filters in place and engine compartment deep cleaned.
    Everything goes back in the reverse order. Make sure the shields fit properly against the weather stripping around the engine compartment. They actually go back into the correct position pretty easily. If you loosened the original factory crimp hose clamps you’ll need a crimping tool to tighten them back up.
    All done and looking good.
    Beach Boy, cali2012 and Randy R like this.
  3. cali2012
    cali2012 Rookie
    Apr 27, 2020
    38
    Giulio
    Thank you Bill! I love it! awesome Do it yourself!
    Bill Phillips likes this.
  4. Bill Phillips
    212
    New Orleans
    Bill
    Yep, it makes me feel more like I’m one with the car.
    LaPerfectionLouis likes this.
  5. cali2012
    cali2012 Rookie
    Apr 27, 2020
    38
    Giulio
    Bill do you feel any difference in sound?
  6. Bill Phillips
    212
    New Orleans
    Bill
    I don’t think so, but I do feel that it revs a little smoother.
  8. cali2012
    cali2012 Rookie
    Apr 27, 2020
    38
    Giulio
    Where did you buy the filters if I can ask Bill?
  9. cali2012
    cali2012 Rookie
    Apr 27, 2020
    38
    Giulio
    Thank You Bill!! $219.00 for 2 filters? awesome! I just bought them!!
    thank you so much for your time and guidance
  10. Bill Phillips
    212
    New Orleans
    Bill
    Any time, glad to help
  11. To remove this ad click here.
  12. LaPerfectionLouis
    Mar 13, 2021
    8
    South Florida
    Aurelien Aurelien
  13. Beach Boy
    Beach Boy Rookie
    Apr 1, 2021
    9
    GREAT write up - thank you for this.
    Can you please go into more detail about loosening the clamps? Where do you insert the screwdriver?
    And re-clamping them is just squeezing, or bending over also?
    I tend to wind up breaking these on other vehicles. Not what I want to do with this car!
  14. Bill Phillips
    212
    New Orleans
    Bill
    #12 Bill Phillips, Jun 10, 2021 at 5:40 PM
    I understand completely. The factory clamps are crimped (just squeezed) at the top and it makes a little mushroom shaped protrusion. Imagine a pair of pants that are way too big in the waist. You could grab a handful of material, making them fit snugly. To loosen the clamp insert the end of a flat blade screwdriver into that protrusion from the front, that is 90 degrees to the band, and twist it and move it back and forth sideways so that the band around the hose becomes a little loose (only enough to be able to slide the hose off). Just like relaxing your grip on the waist band in the pants analogy. The catch is that you need the heavy duty crimping tool shown in the picture above, nothing else is strong enough or shaped properly. It’s like a giant pair of pliers only the ends will slide under the loosened crimp and tighten it back up when you squeeze the handles together.
    If a factory clamp becomes unusable for any reason (the metal band can only be worked back and forth so many times before it will break) you can just go to an auto parts store and get a large (4” IIRC) adjustable clamp and replace it. Those can be tightened and loosened an unlimited number of times. Of course you can also order new hose clamps from the factory.
    The crimp in a factory clamp...
    A factory clamp and an adjustable replacement...
  15. Beach Boy
    Beach Boy Rookie
    Apr 1, 2021
    9
    Awesome explanation, sir! I shall remember the loose trousers analogy forever.
    Thanks for taking the time to do that!
  16. Beach Boy
    Beach Boy Rookie
    Apr 1, 2021
    9
    And yes, I was considering the gear clamp - just prefer the OEM look. ;)
  17. Beach Boy
    Beach Boy Rookie
    Apr 1, 2021
    9
    And I have some blacksmith's tools to re-crimp the stock band. They were intended for use on a different kind of horsepower, but should be as effective on a prancing pony as on any other thoroughbred.
