DIY Ferrari 360 Titanium Power Steering Cap | FerrariChat
Discussion in '360/430' started by Bonefingah, Feb 12, 2019.
  1. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    After too much time-wasting, trying to find an aftermarket 360 Titanium Power Steering cap, I decided to DIY it. This thread is created with the hopes that it will help and/or motivate someone else with similar desires...
    I started buy buying two F430 Titanium fuel caps from the local Ferrari dealer and who would have EVER thought to get a bangin' deal at the dealer?! 100 Euro plus tax a piece which amounts to about $150 each. The most inexpensive one on eBay is $490 so yay for me.
    Part number is: 70001217
    I made one for the oil cap as well and will post a link to that after I write it, after this one. That one is a tad more involved...
    - First, remove the two roll pins in the original cap (I drilled them out).
    - Remove the clip from the 430 fuel cap and disassemble it, until only the titanium and aluminum parts remain.
    - Thread the plastic cap back onto your car Power Steering reservoir and mark the top (so you can later ensure the "Cavallino" is prancing upright and not playing dead bug).
    - Lay the plastic cap onto the titanium cap and eyeball which of the plastic bits (wings) you will need to Dremel off of the original cap (it will only be 4 of the 8 wings. I marked them with an "X'", using a silver Sharpie.
    - Dremel off the plastic. The plastic will melt and spit during cutting. WEAR EYE PROTECTION!
    - The original cap has an IMPORTANT off-gas port. Plug that port with something you can later pull out while the glue is hardening. This is just to ensure you don't accidentally get something in said port.
    - Hand-fit everything to make sure it's ready for the irreversible gluing step.
    - Double-check the Cavallino is indexed to your earlier-made "up marker"!
    - Glue the original plastic cap into the new titanium cap, ensuring the off-gas port is clear and the two caps are flush. I did this by balancing the cap onto the dipstick portion and eyeballing that the titanium cap was flush with the surface. It would suck to have a cool cap that is cocked-off when installed...
    - Drink victory cocktail.
    I hope this helped someone.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    imahorse, whatheheck and tifosi101 like this.
  2. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    whatheheck likes this.
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    That a whole lot of horses you have there just my very humble opinion, I have always thought less is best
    Flea7 likes this.
  4. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    About 400 of them... ;)
  5. tazandjan
    39,166
    Bet if you inserted the caps first and marked them before gluing, you could get the Cavallinos to line up for those who are really anal.
    RANDY6005 likes this.
  6. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    That's exactly what I wrote for you to do. The reason they don't line up perfecty is because the glue hadn't set yet when I took the pictures and I didn't want to torque them out of alignment by tightening them...
  7. RedNeck
    RedNeck F1 World Champ
    12,286
    The CSA
    Me
    I like it. Good work.
  8. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    Thanks RedNeck!
  9. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    Sweet!
    Sent from my Galaxy
  10. Jgivoo
    Jgivoo Formula Junior
    437
    New Jersey
    Now if you could figure only figure out how to convert the coolant reservoir Cap
  11. tazandjan
    39,166
    That was done by somebody on FChat, but I believe he used an aluminum fuel cap over the rad cap.
  12. fatbillybob
    Aug 10, 2002
    28,991
    socal
    That was me...I cut the oem neck off the radiator overflow bottle and welded on a standard STANT style fitting so I could use standard STANT raditor caps that do not fail. Then cut an OEM oil cap and embeded the STANT cap into the OEM oilcap.
    Bonefingah likes this.
  13. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    NICE job Fatbillybob! Never even crossed my mind to do something like that...
