DIY for coolant flush? | FerrariChat
Discussion in '348/355' started by Shootfighter65, Apr 7, 2015.
  1. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    Can find brake flush...couldnt find coolant.
  2. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  3. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
  4. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  5. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #5 drbob101, Apr 7, 2015
  6. GTSNJ
    GTSNJ Formula Junior
    Jan 18, 2015
    478
    I like supertech for coolant it never failed me in all makes and models. I use a coolant testr and flush every two years. Mercedes benz orange is the absolute best on the market. Have you ever looked inside a motor that ran this coolant exclusively ? Never a sign of corrosion , but I never tried retrofitting it into another make (would have to thoroughly flush the system first).
    For motor oil I use Mobil 1 always.
    Diff/gearbox - Mobil 1 syn or valvoline gl5, my current one has swepco 201, its a little thick when cold but otherwise seems the same....
  7. Rice-Racer
    Rice-Racer Formula Junior
    Jan 10, 2015
    252
    You can use Valvoline Zerex G-05, get it at Walmart or.....
    It's the substitute we can use in our Mercedes vehicles, works just fine.
  8. WATSON
    23,816
    WI
    My research suggests (and I maybe wrong) that there is a chemical difference between green & orange (Dexcool) coolant. Make sure you read up on that before deciding which direction is best for you and what the hazards maybe of mixing them.
  9. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    #9 emac, Apr 8, 2015
    FWIW, I am a big fan of BMW coolant. Years ago (many) BMW had a lot of radiator problems. Phosphates in the antifreeze reacting with the AL (Al phosphate) and killing the rads. They developed the BMW antifreeze and the problem was fixed. Whatever you use, make darn certain it is phosphate free and safe for AL rads. I would guess most stuff is nowadays.
    I have used the Orange Dexcool in my Fords and it seems to give a residue over time. I dont know if it is just more visible than the BMW antifreeze, but I never see that with the BMW stuff. Of course I change my BMW fluid more often than the Fords!
  10. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    As Watson said above, the key seems to be not to mix the two colors. I have seen first hand two Vettes that did and it turned in a Jello type consistency. Not pretty and hard to clean.
  11. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I think you can mix G-05 with green. That's what I bought and I'm guessing there will be some residual green in my system.
  12. GTSNJ
    Jan 18, 2015
    478
    Supertrch and peak mix with ALL colors. That's why I love it. Never had a gelling issue I use it in a fleet of cars for top up and flush. Mercedes Benz coolant is THE gold standard.. Google it.
  13. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Any tricks to burning the system ?
  14. GTSNJ
    Jan 18, 2015
    478
    No tricks the coolant tank is the highest point in the system. There is a bleed valve on top of thermostat to be used if you can't burp it with the cap off. Run heat while burping too.
  15. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Where can you buy Mercedes gold? I want it shipped
  16. fatbillybob
    Aug 10, 2002
    29,162
    socal
    Maybe your buddy DR knows.
  17. WATSON
    23,816
    WI
    DOH! :)
  18. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    I feel like I'm in high school again
  19. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I changed mine , no burping, no fuss, no drama.
    Some of the respected techs on here suggested BMW and that's good enough for me.
    It's not a big deal to do. It is messy though. Promise.
  20. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    That's what I heard. Some guys said they put a little kids blow up pool underneath . Did you do yours on a lift or jack stands?
  21. WATSON
    23,816
    WI
    Seriously? Just when you think you heard it all. The mental picture is kinda funny though.
    I have done mine twice now. It is a mess, but it is no worse than prying hoses off of radiators as in my old Brit cars. I put down a plastic tray designed to hold winter boots. It catches the stray streams that seem to show up.
    Be careful with the plastic radiator plugs. In fact, buy a couple extra from Daniel just to have on hand.
  22. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    #22 Shootfighter65, Apr 8, 2015
    Did you do a fluid exchange or full flush? I mean did you run it with distilled water and drain it a couple times. Then add new antifreeze? Also wondering if I should change the thermostat?
  23. WATSON
    23,816
    WI
    #23 WATSON, Apr 8, 2015
    When I first got the car I dropped all the radiator fluid. Refilled with just distilled and ran it around the block a couple of times. Drain & refill with BMW fluid.
    I had a hose rupture last year and ended up draining everything just to be safe. Refill & go.
    Unless you suspect the T-stat is bad, leave it alone until your next major.
    Since you asked about plastic drain plugs....If you snap the head off...as is common from time-to-time. Heat up a flat head screwdriver and stick it into the stub being careful not to hit the threads. Twist & remove.
  24. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I have a lift.
    Thinking back on this, the biggest PIA was getting the rubber plugs hiding the radiator drain plugs back into their holes. Reminds me I need one new one as I destroyed one with a screwdriver trying to get it in.
    What is the suggested method for putting those things back in besides just messing with it until you get it?
  25. fatbillybob
    Aug 10, 2002
    29,162
    socal
    It just takes care and slowness to prevent crossthread. You have to make sure you are perfectly lined up too. It is like putting implant screws in. Careful no force predictable advancement. You can also use the trick of lining up well then turning CCW and feeling the click of the threads riding off each other then going gently CW. Try that on an implant. There are some implants very precise and well engineered that screws go right home even when you are in odd positions with difficult access. Then there are some implants companies where the screws are trickier to screw in. I'm sure you know what I mean.
