DIY Jobs for 360 owner in quarantine | FerrariChat
Discussion in '360/430' started by MarcoB, Apr 20, 2020.
  1. MarcoB
    MarcoB Rookie
    Dec 30, 2017
    11
    Mark B
    Quarantine question. I am not a hardcore DIY mechanic, but I am capable of taking my time and following Instructions - example going to replace the Alarm Siren in 360.
    what jobs would you recommend doing yourself that either improve the car / save money / will upgrade generally but don’t need an engineering degree!
  2. tifosi101
    tifosi101 Karting
    Jun 12, 2013
    90
    France
    I would recommend
    treating the leather seats and accessories, treating sticky buttons and accessories and washing the rims and the engine compartment in detail.
    No need to be an Engineer for that, just use your elbow grease !
    MarcoB likes this.
  3. MarcoB
    MarcoB Rookie
    Dec 30, 2017
    11
    Mark B
    I am nervous about cleaning the engine bay for some reason - any top tips?
  4. hessank
    hessank Formula 3
    1,921
    Canada, Florida
    Fred
    #4 hessank, Apr 20, 2020
    When was the last time your coolant was flushed?
    Would be good for the car, the HX and non technical enough not to require you to be an F specialist.
    Only thing is you'd need an Airlift Tool and small Air Compressor
    I'm 360 Canuck likes this.
  5. MarcoB
    MarcoB Rookie
    Dec 30, 2017
    11
    Mark B
    Thanks, in fact I have very recently but I will remember this for next time - any instructions?
  6. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    de-sticky.
    battery
    brakes
    spark plugs/coils
    MAf's
    air and cabin filters
    challenge grille
    update bulbs to some LEDs?
    new stereo head unit
    fluid change, if youre gutsy :)
    O2 sensors...but can be tricky if they get stuck.
    I recommend ordering parts first as they may be hard to come by.
    one4torque likes this.
  7. hessank
    hessank Formula 3
    1,921
    Canada, Florida
    Fred
    Lots of Youtube videos such as this one.
    MarcoB likes this.
  8. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    use scrubbing bubbles bath cleaner. works great. rinse off with low power pump sprayer and don't inject wiring ares's too much. I've never had a problem doing it. I use reverse osmosis water for a spot free dry. cheers
    MarcoB likes this.
  9. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    As above, if your battery is getting to be 4 or more years, time to think about replacing it. Lots of pics on f chat on how to replace it.
    Windshield wipers, when was the last time they were replaced.
    Maybe a nice detail, clay bar, polish and then a sealant like carnauba wax or one of the new synthetics. Clean the leather, then leather conditioner. Lots of good info on the f chat showroom and detailing sub forum.
    Spend 10 minutes and sign up for the Ferrari club of America
    Sent from my iPad using Tapatalk Pro
  10. HNL29
    HNL29 Rookie
    Jun 16, 2013
    34
    Pittsburgh PA
    Any suggestions on how to "de sticky"?
  11. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Lots of threads on this, but 91% isopropyl alcohol seems best and safest (make sure you are in ventilated area). All will remove any painted on lettering.
    HNL29 likes this.
  12. I'm 360 Canuck
    Nov 21, 2015
    1,911
    Lars!
    If you need something more aggressive than alcohol, oven cleaner worked for me,
  13. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Works but the active ingredient in oven cleaner is concentrated lye, which is very aggressive and harmful to organic tissue.
    Flavien Sicre likes this.
  14. HNL29
    HNL29 Rookie
    Jun 16, 2013
    34
    Pittsburgh PA
    So it essentially makes the switch/button "not sticky" but also removes whatever lettering was printed on (describing the function of the switch/button)?
  15. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    I used denatured alcohol and Q-Tips on my 430. Carefully wiped in one direction using new QTips after every 2-3 passes. The only lettering that came off were the "LOCK" on the handles and "MODE SET" on the left panel. That was expected. All the switchgear lettering remained intact.
  16. hessank
    hessank Formula 3
    1,921
    Canada, Florida
    Fred
    +1
    Same as above. I did the same last year with these results.
  17. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    Only lettering Iost were the arrows on the A/C vents in my 360. Isopropyl alcohol and microfiber cloth plus Q tips.
