DIY Oil Service 360
Discussion in '360/430' started by Black360, Nov 24, 2012.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. Black360
    Black360 Formula Junior
    Oct 11, 2010
    267
    FL
    Steve
    #1 Black360, Nov 24, 2012
    Greg:
    I put all the information into an Excel file. The file contains three worksheets; one for supplies, one for tools, and the last one is "how to."
    Note: There are no documents in the Exel file; click on the blue links for pictures and associated documents.
    I've attached pictures of the worksheets (below) just to illustrate the layout; I'll post the Excel file next.
    Hope that someone finds this helpful.
    BTW: Thanks for your help!
  2. Black360
    Oct 11, 2010
    267
    FL
    Steve
    #2 Black360, Nov 24, 2012
  3. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,442
    Dublin, Ireland
    Greg
    Ahh Steve, this is excellent.
    I've just downloaded the Excel file and have checked out a couple of the links. It's super. Really well done. Fair whack to you for putting it all together. Excellent work.
    I particularly like the 2nd option for the Oil Filter wrench. It's actually the tool I have. Upset though to see it for Stg£4.50. I think I dropped Eur€9.99 for mine! :D
    Working my way through it all now...... but wanted to post my appreciation.
  4. kdumph
    kdumph Karting
    Sep 9, 2012
    157
    Colorado
    Kit
    Sweet thank you for this! Perhaps this is Sticky material?
  5. FerrariDublin
    Jun 14, 2009
    3,442
    Dublin, Ireland
    Greg
    I'll second that! (..... and I'm only scratching the surface of the work at this stage).
  6. Black360
    Oct 11, 2010
    267
    FL
    Steve
  7. Tired of seeing this ad? Upgrade now
  8. FerrariDublin
    Jun 14, 2009
    3,442
    Dublin, Ireland
    Greg
    Thanks again Black - doing engine and gearbox oil today and I knew precisely where to come for the various torque specs for the multiple components.
  9. vincep99
    vincep99 Formula 3
    Silver Subscribed Owner
    Jun 8, 2009
    1,458
    Black,
    Thanks a million! Am just about to do my first oil change and had been looking exactly for these kind of instructions!
    (and to add to the validity: my car is even the same color!)
  10. Black360
    Oct 11, 2010
    267
    FL
    Steve
    You are obviously a person of discriminating taste :)
    If you find errors in the information, or have questions, please post so that I can correct or clarify.
    (If you find bonehead errors, I’d prefer that you send me a PM.)
  11. Zcobra1
    Zcobra1 Formula Junior
    921
    So Cal
    Bert
    Hot tip:
    Guy on EBay, from England, is selling the oil filter wrench tool for around $13 plus ship,
    A little over $20. A lot less than he usual Ferrari parts guys........
  12. FerrariDublin
    Jun 14, 2009
    3,442
    Dublin, Ireland
    Greg
  13. Zcobra1
    921
    So Cal
    Bert
    Just bought this one, ships to the Colonies and other parts of the globe.
    Cheapest I found for the US....Ebay
    321062831423
  14. Tired of seeing this ad? Upgrade now
  15. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    2,658
    Beverly Hills, CA
    Jay
    And Walah! $500 saved!
  16. whatheheck
    whatheheck Formula 3
    1,928
    Seattle, Wa
    Dan L.
    Just want to say thanks very much for this great info.
    Dan
  17. Black360
    Oct 11, 2010
    267
    FL
    Steve
    You are welcome; glad you found it helpful.
  18. Kevin Rev'n
    Kevin Rev'n F1 Veteran
    Rossa Subscribed Owner
    Nov 29, 2009
    9,623
    Honolulu
    Kevin
    Thanks, saved!
  19. Falcon Wing
    Falcon Wing Formula 3
    1,221
    Colorado Springs
    On an 01 360 Spider, do you have to remove the undertray for an oil change? I can see access holes....are those for both of the oil bots?
  20. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    My 360 Modena has similar holes. I have been tempted to try an oil change without removing the undertray; however, I have always come to my senses before actually doing it.
    I'm pretty sure I would wind up filling the undertray with dirty hot oil and making a real mess. Removing the undertray is a PITA, but I do it anyway.
    I don't have a lift. If I did I might try it if I could press up on the undertray and/or cut up a plastic milk bottle to make some shields or hot oil deflectors. But I'm not going to try that on a set of jack stands.
    If you give it a try, please report back.
  21. Black360
    Oct 11, 2010
    267
    FL
    Steve
    #19 Black360, Jan 13, 2014
    Takes about 15 minutes to remove my undertray, using a floor jack, and wooden blocks under the tires. See Post #6 above if you are interested.
    Removing the undertray also allows easy access to the "Oil Suction Fan," which is supposed to be serviced at each oil change.
  22. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Sorry for the ignorance but what is the Oil Suction Fan and what is it's purpose?
    Alan
  23. Mozella
    Mar 24, 2013
    905
    Piemonte, Italia
    "Oil Suction Fan"? I never heard it called that. This might be an example of typing after happy hour, I don't know.
    In any case, the part shown is the fine mesh screen protecting the engine oil pump from picking up any trash from the oil sump. I check and clean mine every time I change the oil.
    The transmission/differential lubrication pump (not the F-1 transmission shifting mechanism pump) has a similar fine mesh screen to protect that lubrication pump. It's more difficult to access and therefore tends not to be cleaned as often (and perhaps never) because you have to remove the rear bumper to remove the screen.
  24. Black360
    Oct 11, 2010
    267
    FL
    Steve
    #22 Black360, Jan 14, 2014
    Ricambi calls it an "Oil Suction Fan."
  25. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Okay -- it's an oil pump screen. :)
    Alan
  26. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,654
    Henderson, NV
    Roberto Bellezza
    That is the transmission filter ... right ? To remove that, you have to take the back bumper down ... now we are talking a real PITA, not because is hard but it's a real time consuming to re align when put back, anyway it's amazing how much time consuming is to change engine oil/filter and tranny oil/clean filter on these cars !
  27. Black360
    Oct 11, 2010
    267
    FL
    Steve
    #25 Black360, Jan 14, 2014
    Actually, no. There's two: One for gear oil, one for engine oil.
    You may wish to check the illustrations in Post #6 (above). Also, Post #2 has more illustrations, torque specs, etc.
    Below is one of the pictures from Post #6:
