DIY : Repair Air-Bubbles in Leather Dash and Airbag Cover | FerrariChat
Discussion in '360/430' started by Trent, Oct 4, 2013.
  1. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    #1 Trent, Oct 4, 2013
    This is a DIY on how to fix any bubbles in your dash leather in the airbag cover or adjacent to the airbag seams using only cat organs.
    For cat lovers, you can also use 3M 08088 spray adhesive. They make a slightly stronger one as well.
    TIME: 2 hours. I could have done it in 1 hr if it was not for documenting it for you guys and letting the 3M adhesive dry.
    DIFFICULTY: 5 (1=wiping yourself and 10=re-soldering components on the hubble satellite in zero gravity while having an annoying gentlemanly itch)
    SUPPLIES: 3M Spray Adhesive 08088 (why is there a leading Zero? Can someone phone 3M and let them know it is an insignificant digit)
    Prep:
    p1. Lubricate your dash leather a day or two in advance with letherique rejuvenator, Lexol, or your preferred stuff. This will ensure the leather will be as soft and stretchy as possible the day of gluing.
    Steps:
    0. Disconnect battery (have radio codes), or at least turn off passenger airbag from the passenger door jam key switch.
    1. Remove glove box. 6x phillips screws
    2. Unplug dash auto-open solenoid. The connector is on the hard to reach side and requires a small flat head and a bit of luck.
    3. Remove emergency red string from passenger air vent. Nice to know where it is I suppose.
    4. Remove 4x allen screws holding airbag in place
    5. NEED AT LEAST TWO PEOPLE (just like during sex): Lift out airbag straight up. A little wiggle is in order, but easy. Then the yellow airbag wire is not long enough to set it down, so hand the airbag assembly to your helper.
    6. Pull airbag connector off of dash mount. Then unplug it.
    7. Remove staples if any block your progress. (in the leather)
    8. Pull back leather. Note that the leather is glued to the foam, and the foam is glued to the dash.
    9. Go outside and practice your marksmanship with the 3M spray. Make sure you are a good aim and understand the spray pattern
    10. USE HELPER TO HOLD LIGHT AND LEATHER BACK: Spray ample amounts of 3M inside the area. I sprayed it on top of and below the foam were applicable. In some parts the foam was glued to the leather, and others the foam was glued to the dash. I basically used the 3M liberally everywhere under the leather.
    11. Rub the 3M adhesive around from above the leather in all directions to get it evenly distributed.
    12. Pull leather tight and seat at the edges.
    13. Put weight on leather with hands constantly and slowly working the leather toward the edges.
    14. Do this for 10-20min. Until the 3M is set up enough to hold the parts together by itself.
    15. If it fails here, just pull it back open and spray some more.
    16. Assembly is the opposite of assembly, apart from the passenger air vent must be removed to fish red thread through to be able to use it in case of emergency. Just pull the vent straight out while wiggling. Its hard. The rubber gasket that connects the vent to the dash vent system is a PIA. But you will get it back together.
    Side Jobs:
    1. I de-stickeyed my little top black air vent above the passenger air vent while I had easy access. I used a purple degreaser, just let it soak while I completed task A.
    2. I adjusted the glove box to where it was sealed much better. Mine had like a 1/4 inch gap.
    .a. There are two 4mm or so allen head screws that you access from the inside of the glove box, that allow the door mating hook to move in and out a few millimeters. It was not a perfect fit, but good enough. Test this with the glove box out of the car. Its easier. See pic.
    RISK: Driving around with a goofy dash vs a repaired dash. Whats the worst that can happen; Heck, if you really screw it up, its an excuse to hire a professional.
    I might post a video if I am feeling the love....
    Video:
    [ame]http://www.youtube.com/watch?v=bxzE6BINbnc[/ame]
  2. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,436
    great write up.looks much better,great job
  3. Moopz
    Moopz F1 Veteran
    5,537
    Orlando, FL
    Holy **** that is awesome. Great job! It looks 1M x better and I am very anal about dash leather.
  4. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    Thanks! You did get to see it pre-fix first hand during our attempt to break the neighborhood land speed record. I have to keep my F430 looking as good as yours. So its either make my car look better or scratch your car :(
  5. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Great write up. I have used the 3M adhesive to glue some leather cloth to a lexan, aluminum, and masonite backings. I did not have good results. In most cases the glue dried but later the leather cloth pulled away. In some instances the glue never set -- it stayed sticky for ever. This was with three cans of their super adhesive.
    Alan
  6. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    great write up and good timing for me...but one favor, could you go buy a 360 and do it on a 360 so that I can see what work it takes on the 360 :)
    I assume its all about the same on the 360 to remove the airbag, etc. my dash has shrunk around the airbad opening (not the airbag itself) and by how fast it happened, i assume the glue let go and it shrunk a little, not bad but its visible. Over winter plan is to take out the airbag and try to fix it and if not remove the dash and have it redone.
  7. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    Find me a good deal and sure, will pick one up. But wouldn't it need to have a shrunk dash, and if so, it won't be a "nice car".
    Don't fear this DIY, jump in.
  8. Quadcammer
    Quadcammer Formula Junior
    Jun 29, 2005
    500
    Clifton, NJ
    Oliver
    ok, what the hell?
    My 2005 mercedes has a leather dash that looks perfect and the car sits outside all day, every day, 365 days a year for the past 6 years.
    Why can't ferrari formulate a way to get dash leather not to pull up, bubble, or shrink? I'm guessing you garage this car?
    what is the deal here?
  9. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    My 430 dash delamination, along with my rubberized buttons and such going STICKY, and my speakers delaminating (cone from metal surround), all happened in one 6 week stretch last year.
    My headers failed and Ferrari of Palm Beach left my 06 F430 Spider outside while waiting for replacement OEM headers from italy for 6 weeks in the July-Aug time frame. I am sure my interior was between 180-200deg F for weeks. More damage was done in those six weeks than the entire time I have owned the vehicle. Their service dept failed. Period.
    Now NJ and FL are different regions with different average temps and humidity. But I do agree that my Porsche leather dash looks as new with no de-lamination and its been a FL car most of its life, albeit garaged.
  10. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    958
    Valrico, FL & Franklin, NC
    Joe Gliksman
    Thank you Trent for this write-up. It helped me do mine!
  11. martiy1971
    martiy1971 Formula Junior
    Jun 2, 2015
    647
    Alberta
    Robert Martineau
    Great write up - Mods, this should be in the DIY section
  12. Buster 1
    Buster 1 Rookie
    May 7, 2016
    24
    Joplin, Mo
    Greg Neely
    Thank you such an informative post. Your UTube video made it seem simple enough for even me to attempt .
    As you said . " if I fail I'll let an expert repair my mess up"
    I also have dash shrinkage in the same general area. It's pulling away from windscreen.
    Hopefully I'll follow your procedure and make the necessary repairs there as well !
    Great helpful post !
  13. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,104
    South Florida
    Greg S
    Great job! I will need to do mine soon
  14. gsworld2014
    Dec 23, 2014
    1,104
    South Florida
    Greg S
    Is your car Rosso scuderia?
  15. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,981
    St. Louis, MO
    Eric
    I did this yesterday, but now the airbag light is on. I made sure to disable the passenger airbag first, but that didn't keep the airbag light from popping on. Crap.
  16. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Did you turn off battery first?
  17. Eric C
    Mar 20, 2009
    10,981
    St. Louis, MO
    Eric
    Nope. I thought that you could either disco battery or turn the bag off. I guess not.
  18. ph12
    ph12 Karting
    Jun 28, 2015
    178
    Los Angeles
    your shop with the proper tools should be able to reset the airbag light. just get it done at the next oil change
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Always turn off battery when un plugging airbag. With the 355, you need an SD or equivalent to reset the airbag - I'm speculating the same with the 430.
  20. bellwilliam
    bellwilliam Formula Junior
    Oct 25, 2014
    399
    Anyone done this mod without setting off airbag light ?
  21. Eric C
    Mar 20, 2009
    10,981
    St. Louis, MO
    Eric
    I went through all that trouble and I couldn't even get my leather to stretch enough to wrap it around the edge. I leatheriqued it the day before to soften it up and even heated it up with a hairdryer, but that didn't do anything to help stretch it.
    I'll need to get it recovered, but will someone be able to match the grain of the leather to make it match?
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Eric, Johann at Coachtrim in CT is your guy. He has absolutely the best matching leather to Ferrari I could find. Give him a call and let him know I sent you - he will take good care of you.
  23. Eric C
    Mar 20, 2009
    10,981
    St. Louis, MO
    Eric
    Do you know if airbags are safe to ship?
  24. yangstein
    yangstein Formula Junior
    Mar 23, 2015
    571
    Orange County, CA
    Brian
    I see so many talented owners of Ferraris here and always get amazed what you can do to your cars... Excellent.. Wish I had the same level of craftmanship... Washing, clean wheels, plug the battery tender and put seat covers, covers for the car are my limited talent... Of course driving, YES... Wow... Great job...
  25. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I've ship 2 of mine with no issues and others have shipped theirs to Coachtrim upon my recommendation.
