DIY timing belt progress...we have liftoff!!! | FerrariChat
Discussion in 'Boxers/TR/M' started by MonoSpecchio, Mar 8, 2014.
  1. MonoSpecchio
    MonoSpecchio Formula Junior
    Dec 7, 2006
    421
    SoCal in the IE
    #1 MonoSpecchio, Mar 8, 2014
    Liftoff was successful but two mistakes were made.
    1. I bent the hell out of my shifter rod. I really should have removed the shifter rod instead of just pushing it forward. I was watching it carefully but It caught on the fan belt while almost all the way up. I will take it to a machine shop to be repaired, but I was disappointed that I damaged a part.
    2. The throttle cable is stuck on a bracket under a mess of hoses behind the fuel distributors as seen in the last pic. Any tricks for pulling it through?
  2. MonoSpecchio
    Dec 7, 2006
    421
    SoCal in the IE
    #2 MonoSpecchio, Mar 8, 2014
  3. MonoSpecchio
    Dec 7, 2006
    421
    SoCal in the IE
    #3 MonoSpecchio, Mar 8, 2014
    You can see the ratcheting straps I used to secure the rear of the car to the lift. I was afraid the car might be a little nose heavy with the engine out. I'm going to be doing the timing belt work under the car so I really want it to be secure. I should have a couple more feet of headroom to work with once I get the throttle cable removed.
  4. MonoSpecchio
    Dec 7, 2006
    421
    SoCal in the IE
    #4 MonoSpecchio, Mar 8, 2014
    The throttle cable seems too thick to get through the hole in this bracket. Is there something else I need to remove to get it off?
  5. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Holy moly. Brother don't you know it's always better to give then receive. Jesus. Next time keep your ass down for gods sake! Lol.
    R
  6. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Let me know where on the car you need help with as I have loads of photos.
    P
  7. fatbillybob
    Aug 10, 2002
    29,061
    socal
    LOL! people give me cr@p all the time about "crawling in" To me it is the only intelligent way to do it.
  8. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Look how far up in the air his ass is. Lol.
    Gotta bust your nuts Lol. Just a little
    R
  9. MonoSpecchio
    Dec 7, 2006
    421
    SoCal in the IE
    LOL...you kinda have to do that so you don't crush expensive parts in that area. :D
  10. Testarossa Lover
    Testarossa Lover F1 Rookie
    Dec 31, 2006
    3,622
    Newport Beach, CA
    Haig Barsamian
    Mr. Chairman was easy on you...:)
  11. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,425
    Alabama (was Mich.)
    Jeff
    Did you remove the fitting at the end of the throttle cable? There should only be the threaded stud at end of the cable, or you will never get it through the fuel distributor base-housing.
  12. ago car nut
    ago car nut F1 Veteran
    5,506
    Madison Ohio
    David A.
    I lay a piece of plywood on top of the injectors and lay on the injector manifold and work on the throttle cable
  13. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
    1. Yes, I too did that same stupid maneuver. Must take it out. I straightened in a vice. You'd never know.
    2. You must remove the fitting from the end of the throttle cable till there is just a threaded rod on the end of the cable. You're gonna have to put the car back down to do that though.
    BTW - Nobody wants to see your rear end. Just your cars, or your wifes...maybe. And get that ladder off the wall before you F up your paint!
  14. MonoSpecchio
    Dec 7, 2006
    421
    SoCal in the IE
    Good ideas, thanks!
  15. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    LOL! I'm so glad to hear two other idiots bent their shift rod the first time they did an engine out. Mine was also straightened in a vice.
    You must remove the fitting at the end of the throttle cable. The only thing left should be the threaded rod. It is no thicker than the cable housing itself. Don't lose that tiny little cotter pin!
    BTW - I'm not gay. That pic made me throw up a little in my mouth.
    Also, that first pic made me think of a lifted off road testarossa. KEWL!!!!
  16. ago car nut
    5,506
    Madison Ohio
    David A.
    There are more than two that bent the shifter rod! Next engine out the shifter rod is coming off first.
  17. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,718
    wisconsin/chicago
    bo
    I took the motor out with shifter rod connected... But I had to balance the motor at a 60 degree incline to do so... Not fun...
    I wonder why most of the threads suggest to leave it in... Is disconnecting it difficult? Doesn't sound like it... But you do risk screwing up your shifter alignment...
  18. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    forget crawling on top of the engine... skip the potential damage.
    a four section ladder folded into a scaffold fits over the back of the car just fine - a cut to fit sheet of 1/4" plywood makes it comfy.
    rgds,
    vincenzo
  19. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,962
    The Cold North
    Tom
    Or just undo everything before you drop the engine..
  20. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,546
    romano schwabel
    #20 turbo-joe, Dec 24, 2015
    how do you take the engine out when the shifter rod is still connnected? this is impossible or I undertsand under shifter rod something other than you?
    you have to remove the screw no. 27
  21. bpu699
    Dec 9, 2003
    17,718
    wisconsin/chicago
    bo
    I just followed the threads on here...
    You tilt the motor upwards at the front as you lift the car... this keeps the shifter from hitting anything...
    works... but its a pain...
    Plan to remove the shifter when putting the motor back in... I didn't even know removing the shifter was an option... I just didn't see anyone doing that in the posts...
    You live... you learn...
  22. turbo-joe
    Apr 6, 2008
    9,546
    romano schwabel
    it is impossible to take the motor out when you do not disconnect the rod no 43 and no 6, and this you can only do by removing the screw no. 27
    you put in 2nd gear, remove the screw 27 and the the shifter you put to 3rd, so you have place to take the motor out
  23. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
  24. bpu699
    Dec 9, 2003
    17,718
    wisconsin/chicago
    bo
    Phil! It was your guide I used off Scrib-d. Thanks for doing it, it was very helpful...
    Tilting the engine, and disconnecting the airconditioner, were the biggest pains in the rear...
    Nicely done summary!
  25. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    The trick is in moving the engine rearwards as the car lifts upwards. Leaves loads of room for the shifter shaft :)
    Summary, Hmmmm beer :D
    P
