DIY: Valentine 1 + Dashcam Power Wiring - Cali T | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by whatheheck, Jun 3, 2020.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Here you go for sharing:
    My usual disclaimer, I'm posting for sharing.
    Im not here to debate or argue with anyone as I have better things to do.
    If this post has helped you - a simple thanks goes a long way.
    If you dont like what I do or you disagree with my approach or my choice of parts or my workmanship - it's OK, it's my car. You too can do whatever you want to your car.
    Your life, your car, do whatever makes you happy.
    To each his own.
    Now that we have that out of the way, here you go:
    All done. Hardwire for Valentine 1 Radar Detector and Dashcam power.
    It's 12V switched wiring so power is normally off, power is on once engine is on so it will not drain your battery.
    For complete details and parts used please see attachments.
    Important notes:
    Always disconnect battery power when working with electrical stuff.
    Do not forget to perform an ECU reset once the battery power is reconnected. Procedure attached.
    Hope this helps some of you.
    Dan
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Flea7 and Andrew Pour like this.
