DIY Zinc (Cad-lookalike) Plating | FerrariChat
Discussion in 'Boxers/TR/M' started by mtooze, Jul 1, 2012.
  1. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    #1 mtooze, Jul 1, 2012
    A couple of people asked about home based plating, so here is a little demo w/ pics. I decided to try this just because its interesting and I like to do things myself rather than pay a professional.
    All the stuff Im using is available from http://www.caswellplating.com/
    Im using the 3 gallon copy cad (zinc) kit and I also bought one of their power supplies (you need a PS capable of a constant current, not a constant voltage, for reason i will explain later). I wont go into the background on plating, but its high school physics...you can read the basics here http://en.wikipedia.org/wiki/Electroplating
    You can also put together your own kit for much cheaper if you want to experiment with the electrolytic solution etc. I just wanted to try some plating without experimenting a great deal, so i bought a kit.
    First off, heres the set up. 5 or so 5 gallon buckets, each containing:
    1. distilled water
    2. Plating solution
    3. 5% HCL
    4. Degreaser
    5. Blue chromate solution (pic is of the blue chromate...the yellow looks same, but, errr, yellow/orange.
    6. Yellow chromate solution
    Ill explain what they each do in a bit.
  2. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    #2 mtooze, Jul 1, 2012
    Here are the other bits of kit you need:
    1. constant current power supply
    2. pure copper wire to hang things
    3. zinc anode
    4. copper tube for hanging/conducting
    5. temp gauge/water heaters
    6. tank pump for agitating the cad solution while plating.
    The cad solution needs to be at approx 110F for plating, the chromates at approx 80, and the degreaser at 140. One of my tank heaters broke, so i didnt bother heating the degreaser. Also, the ambient temp was 95 anyways, so i didnt really need to switch on the chromate heaters.
  3. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    #3 mtooze, Jul 1, 2012
    Well...just like anything else to do with metal refinishing, the key is in the preparation. The smoother/shinier the raw metal, the smoother/shinier the plate will be. But before I start plating I usually get everything else set up/switched on. I check levels of various baths, and add distilled water if necessary. I went ahead and switched on the cad heater, even though at close to 100F outside, it probably wasn't necessary. I plop the zinc anode in and start the aerator running.
    Can anybody see the mistake in the pic?
    Anybody?
    Yep...wired wrong. I got the negative lead on the zinc anode and the positive on the piece (copper pipe). I didnt realize until a little later when the plating was, well, not happening. I guess i got distracted by trying to juggle the camera etc.
  4. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    #4 mtooze, Jul 1, 2012
    As i mentioned, most of the work is in the metal prep. The metal HAS to be clean as a whistle...just like if you were going to paint it. Sand blasting/bead blasting is the best prep. If you want super shiny parts, you have to wire wheel the steal too. I have two cabinet blasters, one set up with 50 grit, the other with 300 grit. For fine finishes, the 300 grit is excellent (it feels like flour) and cuts surprisingly fast.
    Anyways, I took two nasty pieces from the Healey 100-6 Im restoring, and bead blasted them.
    Sorry about the cruddy pics, Im using an old digital camera from about 10 years ago...its doesnt do macro/close up very well, so the pics are blurry sometimes. The parts have a fine satin finish to them.
    Note: This plating only puts 1 or 2 thousands of zinc on in 20-30 mins. Any imperfections in the metal will be readily evident in the finished parts
    Also, you can only do steel and pot metal. You can do aluminum, but you have to follow and special procedure with different baths because aluminum will oxidize IMMEDIATELY on contact with air (cant see w naked eye) and prevent plating.
  5. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    #5 mtooze, Jul 1, 2012
    OK, so parts are blasted (and you have to wear gloves, even a trace of body oil on the metal will ruin the plating0 and wire up...now you just hang them in the degreaser for 5 mins. After 5 mins in there, you give them a swish in the H2O, then its a 3 second dip in the HCL to remove any final trace contaminants, then another swish in the water, then its into the cad bath.
    So, how much power? And why constant current? Its pretty simple, you have to calculate 0.14a per square inch. I measured approx 18 square inches of surface area on those two parts...I know, sounds a lot and doesnt look a lot, but you have to account for both sides of the pieces AND the edges etc. With this power supply I can do up to 5 amps, so up to 35 square inches. Doing nuts and bolts is a nightmare because of the copper wiring.
    Constant current? Easy. As the part is plated, the resistance increases, thus the voltage must vary (increase) to keep the amps constant and keep the plating going. Many people use a battery charger and lights bulbs to vary the amperage, but the power supply is way easier.
  6. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    #6 mtooze, Jul 1, 2012
    OK, so now you just go do something else while the magic happens.
    Remember my incorrect wiring? well after 2 mins, I pulled the parts out (you can just pull em out with no ill effects) and noticed....nothing. Hmmm.
    Oops...quick check of the wires...FAIL. Wired things up properly and dumped the parts back in. Now, what I SHOULD have done is cleaned the anode as it was now contaminated from running the system backwards. I didnt, as as you will see, the final plate didnt come out quite as shiny as it should. Oh well....just doing it to show you guys.
    I dumped the pieces back in for 20 mins....and voila. PLated parts. As I said, you get about 0.001 for every 20 mins. You can leave in as long as you like. The parts look kinda like raw steal, but pay attention to the copper wire...see how it has a nice zinc plate too?
  7. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    #7 mtooze, Jul 1, 2012
    The final step is chromating. You can leave the zinc plate raw, but it doesnt hold up so well. The chromating process makes the plate last longer. You can read about it here: http://en.wikipedia.org/wiki/Chromate_conversion_coating
    All you do is dip the piece in the chromate bath you want for the finish you want. I only have a blue and yellow bath...you can get black and drab olive too, but you are all most familiar with the blue and yellow.
    The blue chromate finish isnt really blue at all...its actually clear. You do get a faint iridescent kind look, kind of like oil on water, but for the most part, it looks like raw metal. The yellow chromate of course gives you that "grade 8 bolt" look and finish, with the same irredescance. My camera did a crap job of showing the finish....but you get the idea. I generally leave the pieces to dry overnight, then they are ready for use!
  8. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    #8 mtooze, Jul 1, 2012
  9. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    I plated a 6" long piece of 1" angle iron, used typical prep methods, and plated for 30 mins (so 0.0015 plate thickness). I threw it outside next to my stand pipe on the grass about 3 months ago now....out in the open air, no shelter, just sitting in the grass. Still looks as good as when I plated it. Im just going to leave it there for a few years and see how well it holds up. Kinda like my own salt spray test, but no salt, and using Nebraska summer and winter instead!
    Marcus
  10. Red Head Seeker
    Red Head Seeker Formula 3
    2,443
    San Francisco Area
    Mark
    Hello Marcus; VERY MUCH appreciate the time & effort it took for you to write up & photo document the plating process....THANKS!!!!....roughly in terms of cost....how much to get a system "Up & Running"?......Mark
  11. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,977
    Great write up. Do you know what chromium compound is used for the chromium coatings?
  12. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    Costs: the 3 gallon kit is 200 bucks, and the power supply is 179. The only other thing u need to source is distilled water, hcl and copper wire, all a few dollars from the hardware store
    You could get by using an old school battery charger ( no load protection) and maybe source a big rheostat for a few bux then youd have a power supply you could adjust. If i wwere buying again, id get a 10 amp so i coukd do pieces that filled my bucket.
    Chromium: i have no idea...the chat lists on caswell are very active, but its easiest to call and ask the man himself, the guy that owns it frequently respon to tech questions online etc.
    I have been tempted to try tge chroming too, but usually the pieces i want to do are bigger...bumpers etc.
  13. mwr4440
    57,853
    Bavaria, The 'Other' Germany
    Mark W.R.
    And tell me chemists, metalurgists, what EXACTLY is happening to the integraty of the parts?
    Hint. The PROs charge out the wiz wang for this stuff for a reason.
  14. mtooze
    mtooze Karting
    Jan 30, 2009
    70
    lincoln, ne
    marcus tooze
    #14 mtooze, Jul 2, 2012
    Zinc plating introduces hydrogen embrittlement. You can relieve hydrogen embrittlement by baking the parts for a few hours at about 200 degrees C.
    Note...check with an expert, that bit of wisdom is remembered by me from metalwork class at a sub par high school in the UK over 25 years ago...now where did i put my keys?
    Experts?
    M
    P.s. U will find zinc plating is relatively cheap...i dont have numbers handy, but i recall maybe $10 a pound for nuts and bolts with maybe a 5 or 10 ib minimum. Frankly, if i was worried about cost, id continue to use the plating shop in omaha! Its more about the skill/learning. Now, CHROME plating is a different world...way more prep needed, nastier chemicals, etc etc, so yes, chrome plating does get expensive...and it also cause the same hydrogen embrittlement.
  15. spinmd
    spinmd Rookie
    Sep 8, 2006
    1
    Hi mtooze,
    Just came across your post about DIY plating as I'm considering DIY or getting it done. DIY looks like a hobby I might need to shy away from since I never seem to have enough time as it is.
    I noticed on your last post you mentioned a plating shop in Omaha. I'm in Davenport, Iowa, straight west and am having difficulty locating any platers here - both of mine went out of business due to EPA issues. Do you know if the shop takes mail-in items, like bulk nuts and bults, or is it walk in only? Can you provide the name of the company?
    Thanks,
    Ron
