DIYers Thread | Page 3 | FerrariChat
DIYers Thread
Discussion in '360/430' started by AandSC, Nov 23, 2020.
  1. AandSC
    AandSC Formula Junior
    942
    Jax, FL
    Allen
    One4torque, I also have an extensive spreadsheet that shows every expense and service (by year and mileage). Comes in really handy when I’m figuring out what needs done year to year. Also, like you, I have no plans to sell this car while I’m vertical. The next owner is going to get a really well maintained Ferrari though, whenever that is.
  2. AandSC
    942
    Jax, FL
    Allen
    Finished my annual in three days this year vs the 15 days last year. Worked about four hours a day and took my time. I found the white board with all my steps on it to be pretty helpful. Had a good 60 mile test drive afterwards with no issues. Had no unscheduled maintenance in the past twelve months, hoping the next twelve months will be the same. A few pics to show my methods. The rear fender cover was homemade from four Harbor Freight microfiber towels that my wife sewed together.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  3. RichardCH
    RichardCH F1 Rookie
    4,661
    excellent I am one of you guys too
    one4torque, AandSC and armedferret like this.
  4. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,094
    Josh @jtcarprojects
    This is the thread that should make most F owners see its not hard to work on your own car.
  5. colorfull
    colorfull Formula 3
    2,308
    Franklin Park, New Jersey
    John Napoli
    +1 on DIY'ing whatever I can and for all the reasons listed
    Before I bought this car, didn't think I would ever work on it, before seeing it, figured it was too exotic and tricky
    08 F430 turns put to be one of the most approachable cars to work on, especially with all the help from FCHAT. Thank you all. Not like driving it fun, but definitely fun.
    Super jealous of you guys that can do hard-core work.
    I'm using QuickJacks heavy duty units, they're awesome.
    Got it in September, had it converted to 6spd, so far:
    -Lots of cleaning all mechanicals
    -Replaced cats with Capristo test pipes
    -Removed shocks and had them rebuilt and shortened 20mm, installing this weekend
    -installed the stock exhaust (after variators were installed 4 me)
    -Undertray repair
    -Replaced lots of mismatched bolts and screws
    -K&N air filters
    -fuel filler bib
    Coming up:
    -install Kline exhaust
    -install BigDaddys
    -install Sport seats
    -install custom brake/clutch faceplates
    -install Android head unit
    -capote elastics replacement
    -install bullet dash enclosures
    -install taillight reinforcement kit
    Wishlist
    -scuderia yellow dash faceplate install
    -replace suspension joints
    -lots of carbon fiber if I get any cash, mostly want to do the steering surround if anyone has an F430 gated and wants to get in on it, @becausephilchow needs 4 more takers
    -Scuding light kits
    -wheels, possibly challenge style
    -frunk strap replacement
    AandSC and RANDY6005 like this.
  6. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,614
    San Jose
    dc
    #56 Sj_engr, Jun 12, 2021
    I'm on the team too:
    -Stripped and repainted scratched up interior (replaced LOCK w aftermarket decals on doors)
    -Conditioned & cleaned all leather, shampooed carpets & mats
    -Painted exposed area after adjusting gauge cluster leather lid (shrinkage of leather)
    -Repaired BE 6112 single DIN Ferrari stereo and updated to v4.0 GPS (long process w hacking CF card w 2015 Audi maps) added aftermarket bluetooth streaming via mini-ISO input
    -Added Scuderia Audio super amp and swapped rear "subs" to Pioneer
    -Added front bumper skid guards, new CF front sill and new front under-body front black panel. Repaired any crack in other under car panels w epoxy
    -Painted and epoxy repaired all scuffs on rear diffuser plate
    -Epoxied rear tail lights to prevent structural failure
    -Epoxied repair of the cracked Ferrari side markers w Mini Cooper sockets (made wiring adapter to keep wiring sockets stock)
    -Ordered like 50x replacement missing/mismatched bolts + new leather strap for trunk tool box
    -Oil, gearbox oil/filter, F1 fluid changed, New BMC air filters installed + New spark plugs
    -Adjusted micro switches in the doors and cut open the siren and tossed the 15 year old batteries & soldered in USA replacements to fix the alarm
    -Wired CTEK adapter behind driver seat for battery maintainer
    -Cleaned, repacked and re-clamped passenger CV joint
    -Fixed broken tabs on front bumper w epoxy and fiberglass weave
    -Transmission mount & engine mounts replaced with new
    -New TB boots installed due to wear from engine movement
    -Added transmission mount heat shield
    -Replaced missing rain drain + rubber access ports on bottom, new cabin filter
    -Replaced AC dryer, vacuumed system and recharged AC
    -Replaced thermostat and flush/fill new BMW blue coolant
    -New Ferrari emblem rim inserts + new TPMS sensors and tire valves
    -Added LED drl strip to headlights
    -Replaced front brake rotors & added SS lines. Flushed all brake fluid w Motul
    -New serpentine belt installed
    To Do:
    -Replace front/rear sway bar bushings + high perf grease
    -Inspect and replace any other worn suspension parts
    -New F1 accumulator bulb
    -Add new mic for driver speech navigation
    -Remove dash and install aftermarket metal vents to resolve minor shrinkage
    -Actually drive car
  7. AandSC
    942
    Jax, FL
    Allen
    Sj_engr and colorfull, glad to see some others on here in the same boat. Thanks for the input, it’s always good to see what others are working on and doing for that time when we need some help, or just morale support.
    colorfull and one4torque like this.
  8. colorfull
    colorfull Formula 3
    2,308
    John Napoli
    I have so many questions for so many of you and am so impressed with everyone's work, would it be inappropriate to just start firing away with them?
    This is def my new favorite thread!
    kes7u and AandSC like this.
  9. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,094
    Josh @jtcarprojects
    Ask away. No one person knows everything and us like mined people are a special group. Love to learn help and pass any information that I might know. I might be a young one in this group but can get down with it.
  10. eric355
    eric355 Formula 3
    1,215
    Toulouse (France)
    Eric DECOUX
    #61 eric355, Jun 14, 2021
    Nice brakes !
    Just a detail but, AFAIK, on the calipers "Ferrari" is usually written from top to bottom (F on the side of the bleeding screws) ;)
  11. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    Yes, I have to agree. The F is on the side of the bleed nipple.
  12. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,094
    Josh @jtcarprojects
    That
    I
    That is the way I did it
  13. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,094
    Josh @jtcarprojects
    I did one way upside down
  14. TuttoBene
    TuttoBene Karting
    Sep 6, 2020
    78
    Doug
    I watched the ratarossa 360 belt change video and decided that it looked like fun. Bought a 360, changed the brake fluid, and headed to the track. The car ran great, but the headliner fell so I DIY'ed that one. It turned out great and once I have my life in order I"ll post pictures and a how-to of the approach I took. While I was there I hard-wired a radar detector.
    After bringing the car out of hibernation I did an annual service for gearbox and engine oil. I have a lift, so it wasn't too bad. My bumper has larger gaps than I would like, though. I'll fix that during next annual.
    This spring I took on the 30k service. I didn't think that it would be that much tougher than the belt service, but I was very wrong. That entails doing engine seals, gaskets, and spark plug O-rings. That cam cover is a giant pain to take off and put back on. I had to do it twice. A fun part of this adventure was having to re-degree the cams after I replaced the seals. I followed the Aldus procedure which involved measuring valve movement 1.66 and .60 mm +/- .08 mm while turning the engine by hand repeatedly to/from exact degrees. Eventually I got a perfectly tuned engine down to the millimeter.
    Of course the insides of the car had to come out in the process, so I took on a side quest to do some detailing. All of this involved me obsessively replacing missing or worn bolts, running everything through a parts cleaner, and cleaning all the bits that nobody else will see. That's part of the reason I like doing all of this myself. Not only do I know that it's being done correctly, but i leave my 360 better than I found it every time I touch it. Except for the handbrake. The handbrake on this car seems hopelessly terrible.
    I have more work left, like tiny drops of power steering fluid coming out of a hose. And I'm inspired by this thread to clean my intake plenum and maybe try to fix my noisy flappers. But right now I just want to keep driving it hard on and off the track. I do not baby this car and I think it seems to work better the more I drive it. If I leave it alone for too long, it idles rough.
    x431 tells me that I'm at about 70% with my clutch. That's a job I might leave to the pros.
    AandSC, colorfull and armedferret like this.
  15. Mbelliss
    Mbelliss Karting
    Mar 28, 2018
    76
    Michigan
    Mark B
    Lot’s of great work here. some I’d do, some I wouldn’t have the confidence to do. For me, replaced front rotors/pads, resprayed rear challenge grill, replaced the right recumbent mechanism for the top (snapped a rivet when opening), tightened front challenge grills (removed front bumper), repaired cracked inner wheel well fiberglass panels, replaced alarm, replaced door speakers and added wireless bluetooth…. Image Unavailable, Please Login
  16. AandSC
    942
    Jax, FL
    Allen
    @TuttoBene nice work! I think if you can degree your cams and replace the belts then you can do the clutch. I plan to take on clutch replacement when/if the time comes. Awesome that you’re tracking your car too!
    @Mbelliss welcome to the club also! Great to see another DIYer digging into their own work!
    TuttoBene and colorfull like this.
  17. AandSC
    942
    Jax, FL
    Allen
    #68 AandSC, Apr 28, 2022
    I was supposed to be headed to Connecticut to pick up new wheels but my wife came down with a bad cold so it’s annual service this weekend. My third one. No unscheduled maintenance between services. I’ve decided I’m not changing coolant and gearbox oil every year given the under 1500 miles a year I’m driving, so those are going to every other year. This year’s tasks are:
    - Oil and filter
    - F1 flush
    - Brake fluid flush
    - Power steering fluid flush
    - New motor mounts
    - Change pollen filter
    - Inspect the gearbox mount with my new bore scope and replace if needed
    - Clutch relearn
    - Inspect variator connectors for oil
    - Inspect front and rear suspension (I’m getting a squeak out of the left rear corner at first extension of the drive, hoping to resolve that)
    I’ve been wanting to shift my annuals earlier in the year when it’s cooler, so this is a step in that direction. Will report back when complete or if any issues arise.
    cavlino likes this.
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,817
    Central NJ
    Dominick
    I still believe there is more you can move to at least every 2 years
    one4torque likes this.
  19. AandSC
    942
    Jax, FL
    Allen
    Which items would you move to two years Dominick? I’m doing power steering fluid every two years already.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,817
    Central NJ
    Dominick
    If you drive 1500 miles and do more than 20 miles or so each trip (not just a start and store or a 2 mile trip) and you keep indoor in a semi climate controlled garage no track time .. basically everything can be done every two years
    Use a high quality brake fluid ..like ate 200 or better
    Oil coolant power steering F1 gear oil etc all can last (not just saying ..I have scientifically proven it over and over using oil analysis) even more than 2 years ( minus the brake fluid)
    Pollen filter ..hard to say ..when they get dirty or smelly ..that could happen quicker or last 3 years ..all depends on if driving in a humid environment or dusty environment and you use the air alot
    In the end it comes down to what you feel comfortable with ..you will get 10!different opinions but I will say mine is pretty much fact based
    cavlino, ditpixs, one4torque and 2 others like this.
  21. swc5150
    swc5150 Formula Junior
    707
    Wisconsin
    Scott Calderwood
    I'm a new 430 owner, and all service is up to date, but I couldn't help but start perusing the engine bay as I diy my other cars (Porsche, Lexus). For simple fluid changes, the F car drain ports and filter location are much more accessible than the others. Like others here, I'm simply going to document everything I do with the max detail. I already noticed 3 missing diffuser bolts, and that's after dealership and top indy services. No one will take better care of your property than you:)
    Quick question for the group. My driver side exhaust tips are a little loose. Is a new weld the only fix, besides obviously replacing them?
    Extreme1, Flea7, AandSC and 1 other person like this.
  22. 67bmer
    67bmer F1 Rookie
    2,878
    MD
    It's always interesting (to me) the hodgepodge of miscellaneous and missing screws on the underside photos of BaT listings! The price of the car is irrelevant...
    AandSC and swc5150 like this.
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,817
    Central NJ
    Dominick
    I think unless you take the time and put loctite the vibration drives the screws out seen it happen on my car
  24. AandSC
    942
    Jax, FL
    Allen
    Completely agree. This is why I do my own maintenance. I can take my time and make sure everything’s done right.
    Glad to see I’m not the only one that notices this!
    MiBe likes this.
