Do I hopefully have a bad battery | FerrariChat
Discussion in '348/355' started by speeder37, May 21, 2012.
  1. speeder37
    speeder37 Karting
    Nov 18, 2003
    96
    Chicago
    Matt
    The car is a 99 GTS.
    It has been the best car one could ask for. I have owned the car since 2000 and it has never left me stranded or needed service other that three majors.
    The car has been sitting for three weeks not on a tender. I started it today and pulled it onto the driveway. I let it idle for about five minutes. While I was in the house, I heard the motor shut down.
    When I turned the key, nothing came on. No electrics whatsoever. I pushed it into the garage and placed it back on the tender.
    When the key is in position, there is a clicking noise coming fromwhat weems like the rear of the car and under the dash.
    I am thinking a ccompletely fried battery.
    Any aditional thoughts?
  2. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    31,564
    Seattle Area
    Dave
    If it started normally, I would not be suspecting the battery....
    Jedi
  3. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,086
    Honolulu - Seattle - Okinawa
    Steve
    My first thought would be the alternator, not battery. The car may have drained the battery while idleing because the alternator wasn't charging it. Now the battery may be too dead to get enough power to the starter for it to turn at all, hence the clicking. Also supported by no electronics coming on. Charge the batter overnight and see if it starts the next day.
  4. plugzit
    plugzit F1 Veteran
    7,674
    Redondo Beach, CA
    Bruce Bogart
    Check the connections
  5. tcannon
    tcannon Formula 3
    Feb 18, 2009
    1,763
    Norman, OK
    Todd Cannon
    Check your connections. Then charge the battery. Then test the voltage output of the alternator. If the alt is putting out good voltage, then have your battery load tested.
  6. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    The alternator is not charging the battery at idle. The idling probably completely drained your battery.
    As already mentioned, check connections, charge battery and start her right up...
    Kai
  7. plugzit
    plugzit F1 Veteran
    7,674
    Redondo Beach, CA
    Bruce Bogart
    Be glad it ain't a Fisker
  8. Kaivball
    Jan 11, 2007
    35,997
    Kalifornia
    Lol.
    Kai
  9. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,398
    Richmond
    Pete
    In 5 minutes? I don't think a battery would have enough juice to start a car and then die in 5 minutes at idle, even with every single electrical accessory on the car turned on. I'd be more inclined to think you have a lose connection at the battery or something like that. It could be an internal short in the battery, they do all kinds of weird things when that happens.
  10. speeder37
    speeder37 Karting
    Nov 18, 2003
    96
    Chicago
    Matt
    I charged the battery overnight with a Baterry Tender. It did not go to a full charge. I'll take the battery out this morning and have it tested. This will give me a chance to check the cables as well.
    I'm leaning towards a short in the battery.
  11. WATSON
    21,726
    WI
    Epic answer :)
    How old is the battery? Little used and untended batteries can fade pretty quickly.
    Seems odd that it would start the car and run for 5 minutes and then shut down.
  12. TomPDX
    TomPDX Formula Junior
    Mar 28, 2008
    558
    Oregon
    Tom
    I have to respectfully disagree. Batteries die in very strange ways. If it was a little short of fluid, the plates can warp, touch, and thus fry. If the OP hasn't ever replaced the battery, which from his OP it sounds like he hasn't, it may very well have been dry. (I've owned at least a dozen British cars, so I know all about the myriad ways batteries die!)
    But as you and our learned F-chatters above have suggested, it does sound like it might just be a corroded battery post, or some other connection.
  13. tcannon
    tcannon Formula 3
    Feb 18, 2009
    1,763
    Norman, OK
    Todd Cannon
    I have designed and built many electric cars including an open wheel electric racecar. I have seen batteries do some really strange things. They can go from perfect to junk in seconds. So nothing surprises me when it comes to batteries. It can still be a bad connection as well. But charging and load testing the battery is a good start.
  14. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,398
    Richmond
    Pete
    I was disagreeing that it was an alternator issue, not that it couldn't be the battery (as I suggested in my post).
  15. TomPDX
    Mar 28, 2008
    558
    Oregon
    Tom
    Sorry, didn't get that. I thought you were disagreeing that the battery would die so quickly, in response to the OP, then suggesting an alternate diagnosis. My bad.
  16. speeder37
    speeder37 Karting
    Nov 18, 2003
    96
    Chicago
    Matt
    Some closure:
    For those of you that diagnosed this as a battery. You were absolutely correct. It does seem odd that the car would start and die in the next ten minutes. The battery must have shorted while it was running. I always thought that a car would run on alternator without a battery.
    Regardless, this has been the most reliable car that one could ask for. I couldn't think that it would have a problem at this stage in our relationship.
    The battery was more than eight years old.
    Thanks for the advice.
  17. tcannon
    tcannon Formula 3
    Feb 18, 2009
    1,763
    Norman, OK
    Todd Cannon
    Alternator needs the battery to work. It needs the battery to build the electromagnetic field in the windings. I am glad to hear that you are back up and running. ;)
  18. TomPDX
    Mar 28, 2008
    558
    Oregon
    Tom
    Excellent news. Glad to hear about a reliable 355 ... and any F car with an 8-year old battery!
  19. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Thanks for posting your results speeder.
  20. Kaivball
    Jan 11, 2007
    35,997
    Kalifornia
    You can run a car without battery (that's why you can jump start pedal clutch cars when the battery is dead).
    But at idle the alternator does not generate enough current.
    Read somewhere that you need to have RPM above 1600 or so to actually charge the battery.
    Glad you got it taken care off.
    Kai
  21. tcannon
    tcannon Formula 3
    Feb 18, 2009
    1,763
    Norman, OK
    Todd Cannon
    Actually, it depends on whether or not the alternator is self exciting or not. If not, you need the battery to build the field to start making current. If the alt has magnets to make an initial field then you can start making current with rpm. Usually when the battery is dead and you push start it, the battery is too low to crank the starter but still has enough voltage left to build the field the make current.
  22. modena2904
    modena2904 Formula Junior
    Jul 6, 2007
    917
    Ellicott City, MD
    Eric
    Batteries are funny things. Over the winter, my battery stopped taking a charge on the tender, and was struggling to turn over the motor. Battery was 5+ years old, and a new battery fixed the problem. When I took the old battery into the store for replacement, they put it on the tester and said it was still good. No idea why...
    Anyway, glad this problem was sorted easily.
    - Eric
