Do I need to do 30K service again after 4K miles and 15 years? | FerrariChat
Discussion in '348/355' started by SPOM13, Sep 14, 2022.
  1. SPOM13
    SPOM13 Karting
    79
    Thats simply it! My 1994 348 spider has 22K miles on it. 30K service done at 18Kmiles, 15 years ago. Just looking for advice on this so I can order up parts from Ricambi (or other?) TIA
  2. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,617
    VA
    Brendan
    After 15 years, yes you want to do a timing belt service for sure. Belt cracking and deformation would be the main potential issue.
  3. BONNEFOND
    BONNEFOND Rookie
    Jun 30, 2020
    14
    France
    PHILGOOD
    FloridaIsland348 and SPOM13 like this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,584
    San Carlos, CA
    Mitchell Le
    Oh hell yes. Don't even turn it on.
    Senshi458 and SAFE4NOW like this.
  5. SPOM13
    SPOM13 Karting
    79
    Hahahaha Ya that was my initial thought!
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    It’s your car so you do not need to do anything
    My opinion if it was my car would be yes you should for sure
    IvanRico likes this.
  7. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,021
    NE FL
    Ken
    [QUOTE="USCDOC, post: 148737565, member: 176231"so I can order up parts from Ricambi (or other?) TIA[/QUOTE]
    I've pretty much switched to eurospares... so much cheaper especially with the exchange rate right now
    and yes, do the belts... cheap insurance
  8. lanab
    lanab Formula Junior
    Feb 21, 2016
    512
    Stockholm, Sweden
    The belts are dry after 15 years...change it asap.
    SPOM13 likes this.
  9. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  10. Rifledriver
    37,114
    There is a 550 being talked about right now in the 550 section that was disassembled 15 years ago. Engine was destroyed by a broken belt at 16,000 miles and 8 years old.
    When Ferrari says 5 years it is good advice.
    2NA, randkin and SPOM13 like this.
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
  12. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,238
    CT
    John Kreskovsky
    What you need are belts, and to be safe, tensioner bearings. You don't need a valve adjustment at 4k miles. Seals, water pump, spark plugs, other things, inspect and do what is needed or what you please.
    SPOM13 and 2NA like this.
  13. m.stojanovic
    m.stojanovic F1 Rookie
    3,241
    Serbia - Niš
    Miroljub Stojanovic
    Also check the outer fence of the belt driving sprocket. If its outer fence is loose or, perhaps, welded before, replace it. There is an improved version with stronger fences.
    The outer fence on the sprocket on my 348 was very loose (I could spin it around) after just ~15 k miles:
    The improved sprocket:
    SPOM13 likes this.
