Do I need to pull engine to R/R mounts? | FerrariChat
Discussion in 'Technical Q&A' started by christopher, Mar 25, 2006.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello Fellow "F"-chatters,
    Do I necessarily need to pull the entire engine out of my 79 308 GTB in order to R/R the engine mounts?
    I’m trying to avoid straining the drive axles by lifting the engine approx 1-1/2” to 2” needed to clear them out for installation of new ones.
    What I’ve done: I’ve disconnected the muffler, disconnected that shift (R/R-ing that too), loosened the front mounts to just a few threads holding them, will R/R rears first then fronts last. Disconnected the top torque shaft as well. Am I missing anything?
    Thanks for your help.
    Chris.
  2. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    They've got to move a fair amount to get them out. I think I disconnected (+ drained) the coolant tubes too.
    Test them for uniformity of compression when you pull them. And note any spacers too. I used to test the height of the bottom of the mount to the frame -- will tell you if any are collapsing.
    Usually the motors leak around the studs holding the mounts into the block. You might also think about draining oils, pulling studs, cleaning threads and then using thread sealant like Permatex on the stud threads when you reassemble.
    Have fun, it is not a tough job.
    Philip
  3. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Will I put a strain on the CV-axles in rising the engine that far up? Especially since their positioned in place.
    Thanks, Chris.
  4. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Would anyone like to weigh in on this as well?
    I appreciate all forms of assistance!
    Thank you!
    Chris.
  5. Matt Morgan, "Kermit"
    Matt Morgan, "Kermit" Formula Junior
    Nov 12, 2003
    405
    Ferndale, WA
    Sounds like you have a good start, Chris. I use a hydraulic ack WITH a plate or piece of wood to spread the load, and jack the motor up from underneath. The CV's should be OK, but you can check them by turning the wheel as you slowly lift to make sure.
    Pulling the rears can be easier by loosening the bracket that bolts to the motor/trans, as it woill move a bit, and reduce the motor lifting needed. Make sure you keep track of the spacers and washers, as Phil mentioned. Not the worst kob to DYI, but it can be challenging.
    Good luck.
  6. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Good info... I've been wondering this myself, but it sounds as thought I'd be better off just waiting until my next 30k.
    Aaron
  7. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    I appreaciate your input!
    Thank you!
    Chris,
    BTW- the C/V Axles look as if they're being strained....
  8. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,391
    E ' ' '/ F
    Enzo Gorlomi
    My mechanic replaced the mounts in my 328 without removing the engine. One at a time, lifting the motor with a jack and a large flat piece of wood. I tried to do it at home, but couldn't get the torque to release the lower bolt. I need to step up to air tools :D
  9. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    I pulled the engine on my 308 QV and do not recall any spacers or washers between the mounts and the chassis. I assume their purpose is to level the engine. What is the procedure to determine if they are required?
  10. Matt Morgan, "Kermit"
    Nov 12, 2003
    405
    Ferndale, WA
    There should have been spacers. In the front, they are conical shaped, a 2" base and just under 1" tall. The rear are washer looking, about 5/16" thick.
    The bolt goes thru the center. Without them the motor isn't in the correct position, and shifting, etc, can be off.
    They all seem to have the same ones, Mondy's included so I don't think that they are a measured shim type, so setting them isn't critical just have them
  11. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    I think originally they were designed to go on with the pointy piece facing upwards. Soon after production, I believe this was changed so that they are "ice cream cone" oriented. The logic, I believe, was to ensure that should the bolt securing the engine mount to the frame fall out the motor would stay in-situ given the shallow depression in the fat end (now uppermost) of the spacer.
    I remember getting mine all crossed up (hadn't paid enough attention when removing them) and had to look at the frame depressions plus talk to the chief tech at one of the dealers to understand.
    Philip
  12. Matt Morgan, "Kermit"
    Nov 12, 2003
    405
    Ferndale, WA
    That is a new one for mee Phillip. Makes sense in a way thhough. Iv'e never seen them with the wide part on top, and my parts manuals show it down, but that doesn't mean they are right. (we learn that one once in a while)
    I see it that they are a spacer, meant to put the motor in the right plane so that the linkages clear and work properly. I would tend to think that making a spacer is easier, and lighter compared to the effort necessary to rework the rectangular tube crossmember to get the clearances they need. JMO.
