Do I need two tester cable 146196 and button 145810? | FerrariChat
Discussion in '348/355' started by zakeen, May 5, 2007.
  1. zakeen
    zakeen Formula Junior
    Aug 29, 2004
    989
    Czech Republic
    Do I need two of each for each ECU? or is one enough to find out these codes?
    thanks
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    You only need one cable and one push button to download the codes from one ECU. You can swap the parts from one ECU to the other, or install a cable and a pushbutton on each ECU.
    But I'm not sure if the ECU in a European market car has the "pigtail" on the harness to plug in the cable and the pushbutton. It would be easy to check and find out. Also, the 2.5 Motronic ECU (as used on the very early cars) does not have the ability to store and download fault codes. You must have the 2.7 Motronic ECU's as used on most 348's.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    What Miltonian said, plus you'll need to install bulbs in your CEL areas in your dash pod.
  4. zakeen
    Aug 29, 2004
    989
    Czech Republic
    well I have the plugs that they go into. I just dont have the bottons and the cable. but when I was reading some info it made it sound like I have to press both buttons at the same time to get the codes starting, making me think I need two buttons? but you guys are saying 1 is enough?
    I dont think I need the CEL lights in the dash do I? Arnt these the slow down 1/4 and 5/8 lights? I see them on startup. Is that enough?
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yes, you need the CEL bulbs. CEL bulbs are different than your SLOW DOWN lights.
    Yes, you just press the button on the right side ECU to get the CEL 1/4 error codes. Press the button on the left side ECU to get the CEL 5/8 error codes.
    The error codes are "flashed" on your CEL bulbs.
  6. Ricambi America
    Ricambi America F1 World Champ Sponsor Owner
    Dec 7, 2003
    16,459
    Winston Salem, NC
  7. zakeen
    Aug 29, 2004
    989
    Czech Republic
    Sorry for dumb questions, are these a standard bulb and where do they go in the dash?
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    You can remove your two seat belt warning bulbs and pop them into the CEL 1-4 and CEL 5-8 slots behind your dash pod. Won't cost you a penny/Euro.
  9. Ricambi America
    Dec 7, 2003
    16,459
    Winston Salem, NC
    Dang that's clever. I'm such a dork, I would have driven around town for hours looking for the bulbs. The seatbelt lights are a total waste anyway. Kill the mouse, live happily ever after.
  10. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yes! Kill the mouse (poor Euro/Asia guys won't understand our USA joke, though).
    Great price that you've got on the test cable/button. Kudos to Ricambi!
  11. zakeen
    Aug 29, 2004
    989
    Czech Republic
    thanks for your help!
  12. zakeen
    Aug 29, 2004
    989
    Czech Republic
    Just before I start hacking my dash apart. Is there anything I should know before I try and pull it apart to replace these bulbs? Any hidden release switch or anything?
  13. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    "Hacking my dash apart" - goodness, what a thing to say!
    It's VERY easy. Just remove the two Phillips screws on the lower edge of the instrument pod, tilt the steering column down, pull the pod up, undo the five multi-pin wiring connectors (each has a push tab to release it), and it's off. Takes less than five minutes.
  14. zakeen
    Aug 29, 2004
    989
    Czech Republic
    Thanks for your help.
    I have the dash off now, I pulled the light from the hand brake and but it on the bottom left side(where a white fake light was).
    Turned the key to on(where only lights come on but engine does not start). Hold button for 2.5 seconds and got nothing......
    What am I doing wrong?
  15. zakeen
    Aug 29, 2004
    989
    Czech Republic
    You know I do everything right.... I think.
    I put the hand brake light where the CELs are meant to be, bottom left(5-8). Turn the key to on. Lights come on and go off. Start the car. Lights go off. Push button for 5 seconds and nothing happens.
